POV-Ray : Newsgroups : povray.binaries.images : Rusty Thing on Beach Server Time
19 Mar 2026 14:55:50 EDT (-0400)
  Rusty Thing on Beach (Message 1 to 10 of 20)
Subject: Rusty Thing on Beach
Date: 22 Aug 2009 06:31:03
Message: <4a8fc8e7@news.povray.org>
To accomplish its task efficiently, radiosity needs to keep track of how
far other objects are. Isn't it a shame to leave this information to
radiosity alone, when it would come in handy for a proximity pattern?
This shot is proof of that concept.
Download 'proximity.png' (276 KB)
Preview of image 'proximity.png'
Subject: Re: Rusty Thing on Beach
Date: 22 Aug 2009 07:17:29
Message: <4a8fd3c9@news.povray.org>
   Very promising... I'm already impatient to try it. Indeed, the wet-sand
beach surface is also very nice, and intriguing.
jaime
Date: 22 Aug 2009 13:51:00
Message: <4a903004$1@news.povray.org>
I'm quite confident to finish it up in time for beta 35 ;-). ATM it only
works with texture maps - which of course is flexible enough, but I'd
prefer to make it work with pigment and normal maps, too. (No way of
making it work with pattern functions though. At least not as long as it
re-uses radiosity data.)
I came across the wet-beach idea by accident. It's basically just a bozo
texture map with a dry-beach (= diffuse only) and a wet-beach (= highly
reflective) texture. Except that I also did make use of that proximity
pattern to force the wet-beach texture in the proximity of "the Thing",
to give the illusion of a washed-out channel around it.
Date: 22 Aug 2009 17:20:01
Message: <web.4a905f7daa8d7a4e773f09f50@news.povray.org>
And a good proof it is! I do like proximity patterns :)
To be truly useful though, the effect must be a pattern or a function so you can
use it in any material block.
Will the effect remain the same even if you change the camera settings?
Sam
Date: 22 Aug 2009 19:43:49
Message: <4a9082b5@news.povray.org>
I guess details may suffer when too far away from the camera (due to
radiosity code maintaining some maximum sample density, which depends on
distance from camera), but they'll just get less precise, and don't seem
to "shift" (that was a problem initially).
See attached shot.
One thing that bothers me though is that the proximity pattern is highly
sensitive to final-render-sampling artifacts, so it requires a
higher-resolution pretrace.
Download 'proximity.png' (215 KB)
Date: 23 Aug 2009 03:30:48
Message: <4a90f028$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4a8fc8e7@news.povray.org...
Indeed it is.
Looks a lot like Sam's proximity pattern... :-)
Date: 23 Aug 2009 15:55:00
Message: <web.4a919e60aa8d7a4e1ce3d770@news.povray.org>
That's good to know, since a shifting pattern can lose all semblance of realism
during animation.
> See attached shot.
It seems to behave itself well enough.
There's always a trade off somewhere :(
Sam
Date: 23 Aug 2009 16:10:01
Message: <web.4a91a13caa8d7a4e1ce3d770@news.povray.org>
> Indeed it is.
I think C. Lipka's pattern is more like ambient occlusion and less like an
averaged object pattern. With the latter you can apply colors and patterns to
outside edges as well as the inside ones. With the former you can only get
inside edge information and can't do nifty things like scratch up a box's edges
while leaving the sides untouched. I hope I'm wrong though :)
Sam
Date: 23 Aug 2009 18:58:11
Message: <4a91c983$1@news.povray.org>
You're not - you're actually perfectly right.
Radiosity doesn't collect edge proximity information (it doesn't need
it), only crevice proximity - which I think is the more important of the
two. (As you wrote, there's always a trade-off somewhere.)
For a full-fledged stand-alone proximity algorithm, I guess a voxel-tree
based approach would do fine. But that would mean a lot more of coding
effort - and somputational overhead for data that can't be shared with
any other features.
(BTW, someone's asking in povray.newusers for advice on your fastprox
macros... and speaking of them, do you have them for download anywhere?)
Date: 24 Aug 2009 03:20:10
Message: <4a923f2a$1@news.povray.org>
Sure, a new one is in p.text.scene-files.
I had a lot more to say, but Thunderbird let me send it into the void
accidentally. Basically, I was getting into the possibility of reversing
inside/outside surface evaluation to obtain both inside/outside edge
data and displaying it as a pattern: where black is a crevice, gray is a
flat surface, and white is a peak. It might take twice as long to parse
though :(
Sam
