POV-Ray : Newsgroups : povray.binaries.images : Rusty Thing on Beach Server Time
29 May 2026 12:21:51 EDT (-0400)
  Rusty Thing on Beach (Message 11 to 20 of 20)
Subject: Re: Rusty Thing on Beach
Date: 24 Aug 2009 03:53:25
Message: <4a9246f5@news.povray.org>
stbenge schrieb:
> I had a lot more to say, but Thunderbird let me send it into the void
> accidentally. Basically, I was getting into the possibility of reversing
> inside/outside surface evaluation to obtain both inside/outside edge
> data and displaying it as a pattern: where black is a crevice, gray is a
> flat surface, and white is a peak. It might take twice as long to parse
> though :(
You're making a point there. Strange that I didn't think of that myself:
After all, I did come up with that backside illumination thing, which
(among other) engages radiosity in just this manner. So yes, the
radiosity code /could/ just as well be used to detect outward edges as well.
If it's done smart enough, the radiosity code could be used in a
"lightweight" variant for surfaces that want edge proximity but not
backside radiosity illumination, so that could somewhat keep the
rendering time from exploding: After all, in those cases sample rays
need to be shot only to determine the distance to nearby objects in that
direction, without the need to do any texture computations there.
Date: 24 Aug 2009 03:57:34
Message: <4a9247ee@news.povray.org>
clipka wrote:
> (BTW, someone's asking in povray.newusers for advice on your fastprox
> macros... and speaking of them, do you have them for download anywhere?)
There is a pattern which is much easier to use than fastprox. I posted
it also to p.t.s-f. It's actually much more accurate than the "fast"
prox macros, as evidenced by the attached image. It also produces
outside edge data.
Sam
Download 'edge_pigment.png' (48 KB)
Preview of image 'edge_pigment.png'
Date: 24 Aug 2009 04:17:11
Message: <4a924c87$1@news.povray.org>
Wait up! You haven't dismissed it as a curiosity, have you? I think even
if it makes a cameo appearance in a beta somewhere, I might like to see
  it :)
> well.
Now, is this a process that follows from screen-level evaluation? Or
does the sampling fill 3D space evenly? Both? I guess what I mean to
ask, is will there be a change in the pattern between animation frames?
Date: 24 Aug 2009 04:21:00
Message: <4a924d6c$1@news.povray.org>
> outside edge data.
It also seems to give much cleaner results than my reusing radiosity data.
A drawback I see is that it gives only a falloff to a certain distance
from edges and crevices, then stays level, right?
At the same time there are benefits of course:
- It can be used to model an object with dirty crevices and worn-out
edges that has recently been transported to someplace else; my approach
can only detect proximity to /any/ geometry, and cannot easily be
limited to a subset of the scene geometry (let alone some geometry that
isn't even in the scene).
- It is a true 3D pattern; my approach is only suitable for object
surfaces, and is therefore unsuited for use in media density, or in a
pattern function (which in turn could probably be used to generate a
smoothed version of the object using isosurfaces - what a powerful tool
for beveling that would be!).
Maybe it would really be a good thing to go for a voxel-based approach,
in hope to combine the quality of your approach with the speed gained
through caching data (you wouldn't want /all/ those N inside-tests to be
executed for /each/ iteration step of /every/ ray-object intersection
test to be performed on an isosurface... >_<)
Date: 24 Aug 2009 04:26:39
Message: <4a924ebf$1@news.povray.org>
Being based on radiosity, it follows the same principles when to take
samples - that is, it is entirely screen-level driven - but using the
radiosity save/load mechanism will allow you to carry over samples from
one scene to the next.
Date: 24 Aug 2009 04:49:41
Message: <4a925425@news.povray.org>
>> outside edge data.
In a way, this is true. But my methods wreak havoc upon memory and CPU
usage.
Right. A disruption in space by an object continues only to a finite,
specified distance from the object by way of 3D averaging of point data.
Objects must be predeclared which is a big drawback.
Is this good or bad for your method? It seems that having access to
~any~ scene geometry is good. My method is restrictive and costly for
high numbers of objects.
That's the best part I suppose, it's 3D. But I've used it for
isosurfaces and media, and let me say, the results are a mixed bag. Good
surface exploration, sure, but bad, bad render times.
You're very right, I wouldn't and I don't. What looks good as a pigment
becomes very ugly when used as an isosurface. Actually, it looks great
when you overload pigment_pattern lists with 256*256 pattern samples,
keep the accuracy low and the max grad high. Not that I've done it, not
that I want to, not that I need to learn patience some time ;)
Date: 24 Aug 2009 04:57:13
Message: <4a9255e9$1@news.povray.org>
Well, I'm all for this idea of yours. I think its a good, low-cost
method which will become very accessible to a lot of people. /every/
surface, eh? Good stuff indeed :)
Date: 24 Aug 2009 08:06:50
Message: <4a92825a@news.povray.org>
>> data.
> usage.
Sure they do - unless they're implemented in a compiled language and the
data cached.
>> approach can only detect proximity to /any/ geometry, and cannot
>> easily be limited to a subset of the scene geometry (let alone some
>> geometry that isn't even in the scene).
I'd say it depends on what you want to do. At the moment, neither method
seems to be the silver bullet.
Date: 24 Aug 2009 17:32:39
Message: <4a9306f7@news.povray.org>
stbenge wrote:
>> myself: After all, I did come up with that backside illumination
>> thing, which
>  it :)
This is what I get for not paying attention. It looks like I'll get to
play with this feature in about an hour :)
Date: 24 Aug 2009 17:47:04
Message: <4a930a58$1@news.povray.org>
>> even if it makes a cameo appearance in a beta somewhere, I might like
>> to see  it :)
The peculiar thing is that right until now, that former comment of yours
perfectly slipped me, even though I had replied to the post and it
really wasn't long... so much for not paying attention :-D
