POV-Ray : Newsgroups : povray.binaries.images : A long track to go Server Time
29 May 2026 12:22:56 EDT (-0400)
  A long track to go (Message 30 to 39 of 39)
Subject: Re: A long track to go
Date: 25 Aug 2009 19:02:26
Message: <4a946d82$1@news.povray.org>
s.day schrieb:
> http://www.irtc.org/ftp/pub/stills/2006-08-31/oldroyal.jpg
> I even had a go at animating the wheels..
That's really impressive quality. (You're aware though that the
animation must be from a train going downhill? The reverse lever is
apparently at neutral, effectively locking the valve in dead center
position so it doesn't admit any steam to the cylinder...)
Would you mind me using parts of your code? (Probably not, or you
wouldn't have published the code in the first place, but I rather ask
anyway.)
Date: 26 Aug 2009 01:25:05
Message: <web.4a94c6fdd8f21fa2cf6723b90@news.povray.org>
> anyway.)
I didn't know how the levers work and the train was modelled from photos found
on the web so I was pretty sure it wasn't very accurate as most of the images
didn't show the wheels/levers in enough detail to model and I had no idea how
they should move.
When I modelled the train I had lots of scenes in my head that I was planning to
use it in but never got the carriages finished (I ran out of steam :~o ).
I would be glad to see any part of it in another picture so you are free to use
it (if you can make anything from my poorly written/commented code).
Sean
Date: 26 Aug 2009 03:52:08
Message: <4a94e9a8$1@news.povray.org>
AWESOME good looking animation! Just let the wheels turn in the right
direction...
The wheels turn clockwise when the motive gear turns anti-clockwise? Is this
an error in the animation or am I missing something? Even going downhill the
wheels should turn the same direction as the gears.
BTW: here's a link to an animation (less beautiful - more technical)
http://en.wikipedia.org/wiki/File:Walschaerts_motion.gif
"clipka" <ano### [at] anonymousorg> schrieb im Newsbeitrag
news:4a946d82$1@news.povray.org...
> That's really impressive quality. (You're aware though that the animation
> must be from a train going downhill? The reverse lever is apparently at
> neutral, effectively locking the valve in dead center position so it
> Would you mind me using parts of your code? (Probably not, or you wouldn't
> have published the code in the first place, but I rather ask anyway.)
Date: 26 Aug 2009 04:10:01
Message: <web.4a94ecfed8f21fa22d3f6ffc0@news.povray.org>
> direction...
Thanks for the link, the wheels are turning in the right direction, it is just
an illusion that make it look like they are not. The whole wheel object is
rotated so if they were not turning the correct way the part where the lever is
attached would also go the wrong way.
Even though I knew this I had to colour the spokes individually to make sure I
had not made some mistake somewhere as the effect just doesn't look right.
Sean
Date: 26 Aug 2009 05:18:02
Message: <4a94fdca$1@news.povray.org>
"s.day" <s.d### [at] uelacuk> schreef in bericht
news:web.4a946587d8f21fa2b51465700@news.povray.org...
> This reminds me of a train I modelled several years ago (the royal scot)
> it was
> pretty much the last image I did, in fact the effort probably finished be
> off..
> ;-) Hope it doesn't have the same effect on you..
That was an inspirational image, I remember. Still one of my top favourites.
I sincerely hope you will be back with us. Pity to have stopped...
Date: 26 Aug 2009 06:20:00
Message: <web.4a950bb2d8f21fa22d3f6ffc0@news.povray.org>
> Thomas
Hi Thomas,
Thanks, I'm glad the effort was worth it. I recently found out the IRTC has been
resurrected so with only 2 weeks to go have attempted to put together an image
for the first round (this made me realise how rusty I am though, can't believe
it was 2006 last time I did an image..)
Not entirely happy with it but I will submit it and hope to do better in the
next round.
Sean
Date: 26 Aug 2009 23:39:32
Message: <4a95fff4$1@news.povray.org>
> Sean
It's just the same stroboscopic effect you often see in movies where the
wagon wheels appear to go backward.
It's basically this -- assume for example, the spokes are 10 degrees
apart and the timing lets them move 8 degrees clockwise each frame.
This will give the appearance of them moving 2 degrees counterclockwise
each frame.  Perhaps you can play with the timing to come up with better
results, but I have no specific suggestions of how to do this.
      -=- Larry -=-
Date: 27 Aug 2009 03:51:08
Message: <4a963aec$1@news.povray.org>
In this case the solution is easy: simply add more frames (or less). I'd try
either 17 or 34. If I've counted right then at 21 frames the wheels should
seem to stand still ;-)
Then, since you already have 25 frames, why not go for 50 frames?
Date: 27 Aug 2009 19:48:01
Message: <4a971b31$1@news.povray.org>
> direction...
It's just an illusion.
You can, sometimes, see just the same in a movie.
I remember one where you see a big agricole tractor spoked weel complete
with heavy treads and 2 circles of bolts. You had the illusion that the
treads and one circle of bolts where turning backward, at different
speeds, one circle of bolts turned veeeeryyyy sloooowly in the right
ditection, and the spokes turned to fast in the correct direction.
It was facinating :)
Date: 26 Sep 2009 14:28:03
Message: <4abe5d33$1@news.povray.org>
s.day schrieb:
> This reminds me of a train I modelled several years ago (the royal scot) it was
> pretty much the last image I did, in fact the effort probably finished be off..
Well, I guess by now I'm getting a feeling of what you're talking about...
(still on the :-) side though... I think.)
