POV-Ray : Newsgroups : povray.binaries.images : Stonehenge (wip) Server Time
23 Apr 2026 02:37:30 EDT (-0400)
  Stonehenge (wip) (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Stonehenge (wip)
Date: 15 Jul 2009 13:00:00
Message: <web.4a5e0a16995a17e5a95afc190@news.povray.org>
Doctor John <joh### [at] homecom> wrote:
> From what I've read and (I think) understood, the latest research
> suggests that Stonehenge was associated with death and possibly rebirth.
> The open side is oriented with the setting sun on the winter solstice.
> The avenue which is oriented north-east towards the rising sun on the
> summer solstice connects with the Avon. You cross that and head for the
> place of the living which is Woodhenge. I find this explanation more
> convincing mainly because seeing stone as dead and unchanging and wood
> as alive and growing leads one to naturally to building your 'temples'
> to both death and life in their associated material.
I must say that I favor a theory of changing use over time. After all, the site
was in use for at least about 1000 years, and the design changed multiple
times.
> BTW I find it amusing that the modern "druids" might be celebrating
> midsummer's day in the wrong place.
Not only that - they're utterly mixing up different cults; stonehenge was built
millennia before druidic times :P
Date: 15 Jul 2009 13:10:00
Message: <web.4a5e0d10995a17e55fd99d9e0@news.povray.org>
Modern Druidism was invented by the Victorian gentry
Date: 15 Jul 2009 13:22:33
Message: <4a5e1059@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> wrote in message
news:web.4a5e0d10995a17e55fd99d9e0@news.povray.org...
>> They're utterly mixing up different cults; stonehenge was built
Well at least the modern druids existed when it was built the second time
then :-)
http://img.dailymail.co.uk/i/pix/2008/04_01/Stonehenge1964b_468x594.jpg
Chris B.
Date: 17 Jul 2009 03:09:25
Message: <3t8065tsk8hm3lvsccuho44mhgvlaq0g10@4ax.com>
>then :-)
>Chris B.
How right you are :)
For some reason my newsreader attached this to a post in 2000 "Motobike with
Blobman" ???
Regards
Date: 17 Jul 2009 04:55:08
Message: <4a603c6c$1@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:3t8065tsk8hm3lvsccuho44mhgvlaq0g10@4ax.com...
> with
> Blobman" ???
Wow! I posted it from Windows Mail on Vista (what used to be Outlook).
I've looked at it both on Windows Mail and Thunderbird and it puts it in the
right place on the Stonehenge thread in both those.
Having said that, the reason I downloaded Thunderbird last night was because
I'd noticed some strange things happening on these newsgroups. I've seen a
high number of dissappearing messages recently. For example I can see
several replies on 'newusers', without the original messages.  When this
sort of thing happened using Outlook on NT a couple of years ago I was told
it was my newsreader not taking account of sequential numbers allocated to
posts that had been deleted where the number was subsequently reused by the
server. I don't know how true that is, or whether there's anything can be
done about that if that's what's happening.
What news reader are you using?
Chris B.
Date: 18 Jul 2009 14:14:40
Message: <8v3465pjbnl4s8ishkj4o12iga9rg6mlak@4ax.com>
I'm using Agent and it's at fault. I checked your post using IE8 and the
sequence is fine.
Regards
Date: 18 Jul 2009 14:57:58
Message: <pl6465dnh5q94csfi72tmfru23l7f5fltp@4ax.com>
>sequence is fine.
I changed the sort method to author then back to subject and everything is in
its proper place now. Weird.
Regards
Date: 18 Jul 2009 17:07:56
Message: <d9e4655g6tnd6vdu0951fvpbgdnqkemdk9@4ax.com>
>>sequence is fine.
When I switched off UAC to install Pov 3.7 Agent lost all the bodied of all the
messages posted in the last month. Very very weird.
Regards
Date: 18 Jul 2009 17:25:01
Message: <web.4a623c9d995a17e5707a5c110@news.povray.org>
> >>sequence is fine.
Sounds like this Agent thing is *not* a software to be recommended...
Date: 18 Jul 2009 17:51:27
Message: <msg46555a787cb07euqdr723cplfr3dkh9@4ax.com>
>> >>sequence is fine.
Well I started using Free Agent years ago and was happy with it. Then I bought
Agent when I had to upgrade and wanted to keep all of the OT posts. Please don't
ask me why :)
I'm thinking of changing to something that will work with PSP. Just now instead
of clicking on an image in a post I need to save it in another directory then
open the directory and browse it with PSP. Upgrading from the no longer
supported Free Agent was a mistake.
Any recommendations?
Regards
