POV-Ray : Newsgroups : povray.binaries.images : MyMaglev: C++ automation (almost) finished Server Time
24 Dec 2025 03:46:35 EST (-0500)
  MyMaglev: C++ automation (almost) finished (Message 1 to 5 of 5)
Subject: MyMaglev: C++ automation (almost) finished
Date: 2 Jul 2009 20:22:06
Message: <4a4d4f2e@news.povray.org>
High!
As announced, I wrote a C++ routine to generate animated camera rides
along the tracks of the developing MyMaglev Personal Rail Cabin
System... the program (details see p.b.s-f) runs quite well, except for
some odd artifact, probably a coincident surfaces issue (see attached
images).
Currently, I hardly have an idea why these black squares show up... it
seems to have something to do with the CSG construction of the ground
cutouts!
See you in Khyberspace!
Yadgar
Download 'cabinrailway_new4_101.png' (27 KB) Download 'cabinrailway_new4_309.png' (21 KB)
Preview of image 'cabinrailway_new4_101.png'
Preview of image 'cabinrailway_new4_309.png'
Subject: Re: MyMaglev: C++ automation (almost) finished
Date: 4 Jul 2009 10:56:24
Message: <4a4f6d98@news.povray.org>
> High!
> images).
> cutouts!
> Yadgar
How do you model the grove in the track? Is it a difference? If so, make
the cutting object red, ambient 0.5. Does the problems areas turn red?
Date: 5 Jul 2009 09:14:51
Message: <4a50a74b@news.povray.org>
High!
No, the whole track profile is a lathe object! When I removed the ground
plane with the cutout, the black squares disappeared, but another
strange effect showed up (see attached images). In the oblique view it
looks as the side parts of the track profile extend much further than
its bottom, although the overhead view shows that this is not the
case... strange!
Yadgar
Download '2009-07-05 port whatmough personal rail cabin system test track, take 1.jpg' (13 KB) Download '2009-07-05 port whatmough personal rail cabin system test track, take 2.jpg' (13 KB)
Preview of image '2009-07-05 port whatmough personal rail cabin system test track, take 1.jpg'
Preview of image '2009-07-05 port whatmough personal rail cabin system test track, take 2.jpg'
Date: 5 Jul 2009 15:46:37
Message: <4a51031d@news.povray.org>
> High!
>> make the cutting object red, ambient 0.5. Does the problems areas turn
>> red?
> case... strange!
> Yadgar
It looks like the botton is to low. Look closely at the top view. there
is a gap near the end of the track
Try a lateral view.
Download '2009-07-05 port whatmough personal rail cabin system test track, take 2.jpg' (5 KB)
Date: 6 Jul 2009 05:13:57
Message: <4a51c055$1@news.povray.org>
High!
> case... strange!
Obviously it is because the profile contains a hollow shaped like an
upside-down "T" (which was intended!), so that the vertical side parts
do not connect with the ground immediately.
The black squares disappeared when I corrected my original precaution
against coincident surfaces problems: in the cutout definition, I
originally rotated the subtracting box 0.0001 degrees more than given in
the angle parameter from the segment definition file, but forgot that in
case of a left turn this tiny amount must be subtracted from the
original value rather than added!
     object
       Bend_Subtraction_Block
       #if (ang >=0)
         rotate y*(ang+0.0001)
       #else
         rotate y*(ang-0.0001)
Yadgar
Now playing: To The Shore (Duran Duran)
