POV-Ray : Newsgroups : povray.binaries.images : Sands of Time (wip2) Server Time
23 Apr 2026 04:13:24 EDT (-0400)
  Sands of Time (wip2) (Message 11 to 12 of 12)
Subject: Re: Sands of Time (wip2)
Date: 20 Jun 2009 12:30:00
Message: <web.4a3d0d73b616322a1d5d3f0@news.povray.org>
Doctor John <joh### [at] homecom> wrote:
> Agreed. It took ages to individually shape and polish each individual
> grain ;-)
Although we must confess that nature did a superb job at multiprocessing there
> BTW what finish, interior etc did you use on your grains
In the first shot I used this technique in, I union'd all the grains (I actually
used blobs instead of spheres), and applied the following material:
    #declare SandColor = color rgb <0.9,0.6,0.3>;
      bozo
      texture_map {
        #macro SparklesTexture(fTrans,fRef,fDiff,fMix,cMix)
          pigment { color (1-fMix)*SandColor + fMix * cMix transmit fTrans }
          finish { specular fRef diffuse fDiff reflection { fRef/2 } }
        [0.0 SparklesTexture (0.7, 1.0, 1.0, 0.0, <0,0,0>) ]
        [0.2 SparklesTexture (1.0, 0.1, 0.0, 0.0, <0,0,0>) ]
        [0.4 SparklesTexture (0.3, 0.3, 0.5, 0.5, <1,1,1>) ]
        [0.6 SparklesTexture (0.3, 0.3, 0.5, 0.5, <0,0,0>) ]
        [0.8 SparklesTexture (0.3, 0.3, 0.5, 0.5, <0,0,0>) ]
        [1.0 SparklesTexture (0.7, 0.3, 1.0, 0.0, <0,0,0>) ]
      scale 0.005
    interior { ior 1.5 }
    // no_shadow
    // no_reflection
So quite a mix of different material properties (if you look at real sand,
you'll often find that it's a mix of very different colors, too); they seem
quite a bit arbitrary, but yes - they actually are :) In fact I just toyed
around until it looked good, partially driven by how I'd expect it to work
physically, partly driven by what effects I expected from the sand grains.
In some other shot, these looked better:
    bozo
    texture_map {
      #macro GrainsTexture(fTrans,fRef,fDiff,fMix,cMix)
        finish { specular fRef*2 diffuse fDiff reflection { fRef/2 } }
      [0.0 GrainsTexture (0.7, 1.0, 1.0, 0.0, <0,0,0>) ]
      [0.2 GrainsTexture (1.0, 0.1, 0.0, 0.0, <0,0,0>) ]
      [0.4 GrainsTexture (0.3, 0.3, 0.5, 0.5, <1,1,1>) ]
      [0.6 GrainsTexture (0.3, 0.3, 0.5, 0.5, <0,0,0>) ]
      [0.8 GrainsTexture (0.3, 0.3, 0.5, 0.5, <0,0,0>) ]
      [1.0 GrainsTexture (0.7, 0.3, 1.0, 0.0, <0,0,0>) ]
    scale 0.005
  no_shadow
So you'll probably need to do your own tweaking, actually.
Date: 22 Jun 2009 05:43:29
Message: <4a3f5241$1@news.povray.org>
I love the greebled sphere.
Paolo
 >Doctor John  on date 19/06/2009 12:42 wrote:
> A few changes, still trying to make clipka's suggestion work well so it
> isn't implemented here. More to add. Final result will be posted to IRTC
> test round.
> John
