POV-Ray : Newsgroups : povray.binaries.images : Rope Macro Server Time
31 Jul 2025 07:57:49 EDT (-0400)
  Rope Macro (Message 1 to 10 of 23)
Subject: Rope Macro
Date: 28 May 2009 06:29:50
Message: <4a1e679e@news.povray.org>
I'm working on a new Rope macro to handle knots and track object surfaces
etc.
Here are a couple of sample images.
Thoughts/ideas welcome.
Chris B.
Download 'rope_40.jpg' (78 KB) Download 'rope_41.jpg' (167 KB)
Preview of image 'rope_40.jpg'
Preview of image 'rope_41.jpg'
Subject: Re: Rope Macro
Date: 28 May 2009 07:30:00
Message: <web.4a1e750b99a5bfb66dd25f0b0@news.povray.org>
> etc.
Looks awesome... this'll come in very handy.
How are you doing the knots, with predefined knot curves? And can you handle
e.g. coiling automatically? And presumably you're using either catenaries or a
full mechanics simulation to produce hanging curves...?
(And, and, and...)
Date: 28 May 2009 08:08:40
Message: <4a1e7ec8@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:web.4a1e750b99a5bfb66dd25f0b0@news.povray.org...
>> I'm working on a new Rope macro ...
Each knot has it's own little macro that tracks displacements through the
path of the knot, factoring in the thickness of the rope and the tightness
of the knot. The knot macros add points into an array which is built up to
define the total path of the rope, then there's another macro to convert the
array of points into one or more splines and the splines into the rope.
Because you can break a rope into separate splines you can build adjacent
segments of the same rope using different spline types.
> And can you handle e.g. coiling automatically?
There's a macro to add rope spirals with a configurable amount of
randomness. It'll do left or right handed spirals, so it should be quite
easy to add a coil of rope. I'll give that a go :o).
Ahh! Nothing nearly so sophisticated there I'm afraid :-). I have a loose
segment macro that takes the current point and a new point and adds an extra
point in between roughly in the right place to bring the rope length to
approximately the value specified as a parameter and to get the lowest point
roughly where it should be for the relative heights of the two end points.
Then it relies upon using a curved spline for that segment of rope to join
the dots in a fairly gravity compliant way. There's nothing stopping anyone
with a better grip on the maths adding such a macro though. Each of the
path-defining macros is quite short, so it doesn't take long to add new
shape macros.
Chris B.
Download 'rope_14.jpg' (10 KB) Download 'rope_15.jpg' (18 KB)
Preview of image 'rope_14.jpg'
Preview of image 'rope_15.jpg'
Date: 28 May 2009 10:14:11
Message: <4a1e9c33$1@news.povray.org>
"Chris B" <nom### [at] nomailcom> schreef in bericht
news:4a1e7ec8@news.povray.org...
> extra
> point
> anyone
> shape macros.
Yum yum... for the ropes and knots....  :-)
For catenaries, there is a set of macros by PM2Ring (2005) which do a better
job than the catenaries by Chris Colefax. There is also a set of macros by
Rob Antonishen (2002) but they do not work quite well I am afraid (last
timeI tried them, earlier this year). Both sets were made available in these
forums at the time.
Date: 28 May 2009 10:32:26
Message: <4a1ea07a@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> schreef in bericht
news:4a1e9c33> For catenaries, there is a set of macros by PM2Ring (2005)
which do a better
> these forums at the time.
Found the PM 2Ring Catenary macro in povray.binaries.scene-files and in
povray.text.scene-files: "Catenary - a chain making macro" 2 September 2005
I am unable to trace Rob Antonishen's macro.
Date: 28 May 2009 12:30:00
Message: <web.4a1ebbf399a5bfb6f708085d0@news.povray.org>
Now *this* looks good...!
Date: 28 May 2009 18:43:38
Message: <4a1f139a$1@news.povray.org>
Wow!
Date: 29 May 2009 11:52:08
Message: <4a2004a8@news.povray.org>
> ... can you handle e.g. coiling automatically?
I've added a bit more into the spiral macro. What d'you have in mind by
coiling 'automatically'?
The example below uses two calls to the macro. The first adds a little helix
of two coils in the middle, spiralling downwards, the second call adds the
outward spiral (both using the default amount of randomness).
Chris B.
Download 'rope_17.jpg' (16 KB)
Preview of image 'rope_17.jpg'
Date: 2 Jun 2009 14:02:14
Message: <4a256926@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4a1e9c33$1@news.povray.org...
>> segment macro ....
What a tough assignment that turned out to be   ;o)
I couldn't quite get my head round the approach that PM2Ring took, so I
spent the weekend swotting up on the maths (with long breaks for the
headaches to subside), and worked out a way to just use the most rudimentary
catenary formula. So it uses the value of 'a' to control the shape, which is
the ratio between 'H' (the horizontal component of the tension in the rope)
and 'w' (the weight per unit length).
The method used by PM2Ring has the advantage that you can specify the ratio
between the straight-line length and the rope length to control the amount
of sag in the rope, which is probably more intuitive than using 'a'.
Nevertheless, I plan to finish the documentation and post the first version
of the code in a couple of days. Then if anyone can improve on it we could
incorporate that in a future version.
So here's the result. An image of the catenary juxtaposed behind my original
with 'fake' gravity.
Chris B.
Download 'rope_04.jpg' (25 KB)
Preview of image 'rope_04.jpg'
Date: 3 Jun 2009 03:47:55
Message: <4a262aab$1@news.povray.org>
news:4a256926@news.povray.org...
Good work! I am always awed by people able to do these tricky things. I know
I cannot. Thanks indeed for the effort.
