POV-Ray : Newsgroups : povray.binaries.images : Rope Macro Server Time
29 May 2026 15:39:12 EDT (-0400)
  Rope Macro (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Rope Macro
Date: 28 May 2009 10:14:11
Message: <4a1e9c33$1@news.povray.org>
"Chris B" <nom### [at] nomailcom> schreef in bericht
news:4a1e7ec8@news.povray.org...
>> And presumably you're using either catenaries or a
>> full mechanics simulation to produce hanging curves...?
> Ahh! Nothing nearly so sophisticated there I'm afraid :-). I have a loose
> segment macro that takes the current point and a new point and adds an
> extra
> point in between roughly in the right place to bring the rope length to
> approximately the value specified as a parameter and to get the lowest
> point
> roughly where it should be for the relative heights of the two end points.
> Then it relies upon using a curved spline for that segment of rope to join
> the dots in a fairly gravity compliant way. There's nothing stopping
> anyone
> with a better grip on the maths adding such a macro though. Each of the
> path-defining macros is quite short, so it doesn't take long to add new
> shape macros.
Yum yum... for the ropes and knots....  :-)
For catenaries, there is a set of macros by PM2Ring (2005) which do a better
job than the catenaries by Chris Colefax. There is also a set of macros by
Rob Antonishen (2002) but they do not work quite well I am afraid (last
timeI tried them, earlier this year). Both sets were made available in these
forums at the time.
Date: 28 May 2009 10:32:26
Message: <4a1ea07a@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> schreef in bericht
news:4a1e9c33> For catenaries, there is a set of macros by PM2Ring (2005)
which do a better
> these forums at the time.
Found the PM 2Ring Catenary macro in povray.binaries.scene-files and in
povray.text.scene-files: "Catenary - a chain making macro" 2 September 2005
I am unable to trace Rob Antonishen's macro.
Date: 28 May 2009 12:30:00
Message: <web.4a1ebbf399a5bfb6f708085d0@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote:
> >> I'm working on a new Rope macro ...
Now *this* looks good...!
Date: 28 May 2009 18:43:38
Message: <4a1f139a$1@news.povray.org>
> Thoughts/ideas welcome.
Wow!
Date: 29 May 2009 11:52:08
Message: <4a2004a8@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:web.4a1e750b99a5bfb66dd25f0b0@news.povray.org...
> ... can you handle e.g. coiling automatically?
I've added a bit more into the spiral macro. What d'you have in mind by
coiling 'automatically'?
The example below uses two calls to the macro. The first adds a little helix
of two coils in the middle, spiralling downwards, the second call adds the
outward spiral (both using the default amount of randomness).
Chris B.
Download 'rope_17.jpg' (16 KB)
Preview of image 'rope_17.jpg'
Date: 2 Jun 2009 14:02:14
Message: <4a256926@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4a1e9c33$1@news.povray.org...
>> segment macro ....
What a tough assignment that turned out to be   ;o)
I couldn't quite get my head round the approach that PM2Ring took, so I
spent the weekend swotting up on the maths (with long breaks for the
headaches to subside), and worked out a way to just use the most rudimentary
catenary formula. So it uses the value of 'a' to control the shape, which is
the ratio between 'H' (the horizontal component of the tension in the rope)
and 'w' (the weight per unit length).
The method used by PM2Ring has the advantage that you can specify the ratio
between the straight-line length and the rope length to control the amount
of sag in the rope, which is probably more intuitive than using 'a'.
Nevertheless, I plan to finish the documentation and post the first version
of the code in a couple of days. Then if anyone can improve on it we could
incorporate that in a future version.
So here's the result. An image of the catenary juxtaposed behind my original
with 'fake' gravity.
Chris B.
Download 'rope_04.jpg' (25 KB)
Preview of image 'rope_04.jpg'
Date: 3 Jun 2009 03:47:55
Message: <4a262aab$1@news.povray.org>
news:4a256926@news.povray.org...
Good work! I am always awed by people able to do these tricky things. I know
I cannot. Thanks indeed for the effort.
Date: 3 Jun 2009 04:20:00
Message: <web.4a2631e799a5bfb66dd25f0b0@news.povray.org>
Whoops, sorry for late reply, got caught up with HDRs :)
I meant 'loose' coiling, where the rope can pile up on itself, or a hanging
loose coil (hooked over something, for example). I realise these are
non-trivial, I expect people can model this manually given your tools - just
wondered, that was all! :-)
This is a great macro, keep it up!
Date: 3 Jun 2009 07:06:50
Message: <4a26594a@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4a1e679e@news.povray.org...
> I'm working on a new Rope macro to handle knots and track object surfaces
I've posted the first version of these macros onto the POV-Ray Object
Collection at:
http://lib.povray.org/collection/rope/chrisb%201.0/rope.html
This image shows the predefined styles you can use. It's easy to add your
own styles and fairly easy to add new types of knot etc.. I'd be happy to
incorporate any new styles or new knots that you develop into a future
version.
Chris B.
Download 'styles.jpg' (43 KB)
Preview of image 'styles.jpg'
Date: 4 Jun 2009 07:46:16
Message: <4a27b408@news.povray.org>
news:web.4a2631e799a5bfb66dd25f0b0@news.povray.org...
>> What d'you have in mind by coiling 'automatically'?
> hanging
> just
Here's an example of what the randomisation options can do with a bit of
fiddling around. Some of the random shapes looked unrealistic, so it was a
question of repeatedly adjusting the seed until I got reasonable looking
shapes. This doesn't use any form of collision detection, so eagle-eyed
observers will notice that some bits of rope pass through other bits of rope
and even into adjacent objects in places.
The foreground object uses a very high randomisation setting at about 30
times the default. The other two are copies of the same coil at about 15
times the default randomisation (the one on the post is rotated and scaled
down a little).
To really overlay the coils of rope so that you don't get collisions would
be more complex. I've had a few ideas, but I'm not sure how difficult any of
them would turn out to be to implement. Most of my ideas to date would risk
ending up with some very limp-looking rope.
Chris B.
Download 'rope_42.jpg' (238 KB)
Preview of image 'rope_42.jpg'
