POV-Ray : Newsgroups : povray.binaries.images : Am I just too stupid for programming?!? Server Time
30 Sep 2024 18:08:47 EDT (-0400)
  Am I just too stupid for programming?!? (Message 1 to 9 of 9)
Subject: Am I just too stupid for programming?!?
Date: 20 Apr 2009 05:33:02
Message: <49ec414e@news.povray.org>
High!
Now I'm rid of the clippings... but then, I noticed an ugly gap in
Phobos' surface (see attachment). I thought this might be because of not
having connected the ends of each stripe of mesh faces (corresponding to
lines in the original map image), so I changed my code:
   face_indices
     638398 // added (399-1)*2 = 796
     #declare a=0;
     #while (a<399)
       #declare b=0;
       #while (b<800) // runs now to 800 rather than 799
         <a*800+b, a*800+b+1, (a+1)*800+b>, // line 313
         #if (b=799 & a=398)
           <319999, 319200, 318400> // last triangle
         #else
           <(a+1)*800+b, (a+1)*800+b+1, a*800+b+1>,
         #declare b=b+1;
       #declare a=a+1;
...but all I get is the error message
"Parse Error: No matching } in 'face_indices', < found instead" (in line
313)!!!
See you in Khyberspace!
Yadgar
Subject: Re: Am I just too stupid for programming?!?
Date: 20 Apr 2009 05:39:15
Message: <49ec42c3$1@news.povray.org>
>   face_indices
>     #declare a=0;
>     #while (a<399)
>       #declare b=0;
>         #if (b=799 & a=398)
>         #else
>         #end
>         #declare b=b+1;
>       #end
>       #declare a=a+1;
>     #end
> 313)!!!
You are trying to add more indices than you have told POV at the top.
399*800*2 is 638400, but you told POV you are only having 638398 index
vectors.
Date: 20 Apr 2009 05:50:01
Message: <web.49ec44d439d56e6b1a1b9caf0@news.povray.org>
No, I don't see attachment :P
>    face_indices
With a running from 0 to 398, this should be 399*2 = 798 (because you use 399
distinctive values for a)...
>      #declare a=0;
>      #while (a<399)
>        #declare b=0;
>          #if (b=799 & a=398)
>          #else
.... and there should be some modulus operations in the vector building
statements, so wherever you have b+1, you should really have mod(b+1,800).
>          #end
>          #declare b=b+1;
>        #end
>        #declare a=a+1;
>      #end
> 313)!!!
POV-Ray expects less vectors in the face_indices block than you supplied.
Date: 20 Apr 2009 05:52:54
Message: <49ec45f6$1@news.povray.org>
>   face_indices
  The nice thing about povray SDL is that you can write math. No need to
precalculate anything. Thus you can write:
  face_indices
    399*800
>         #if (b=799 & a=398)
>         #else
>         #end
  There's no need to do that. Instead of all that, just use:
  (Note no comma at the end.)
  The SDL is flexible about commas. Use that fact to your advantage.
Date: 20 Apr 2009 06:15:00
Message: <web.49ec4a9939d56e6b1a1b9caf0@news.povray.org>
> >   face_indices
>   face_indices
>     399*800
But if you do, you better have the math right:
  face_indices
    399*800*2
because Yadgar is creating two faces per loop.
Date: 20 Apr 2009 07:27:01
Message: <49ec5c05@news.povray.org>
Here it is:
Download '2009-04-20 phobos, take 2.jpg' (14 KB)
Preview of image '2009-04-20 phobos, take 2.jpg'
Date: 20 Apr 2009 07:42:03
Message: <49ec5f8b@news.povray.org>
High!
It still doesn't work either, still the same error message... and, yes,
I also used mod(b, 800)!
Here is the current version:
mesh2 // Phobos
   vertex_vectors
     320000
     #declare a=0;
     #while (a<400)
       #declare b=0;
       #while (b<800)
         #declare redval=eval_pigment(PhobosRelief, <(0.5+b)*(1/800),
(0.5+a)*(1/400), 0>).red * (14-8.1);
         #declare greenval=eval_pigment(PhobosRelief, <(0.5+b)*(1/800),
(0.5+a)*(1/400), 0>).green * ((14-8.1)/255);
((8.1+redval+greenval)*<sin(radians(b*(360/800)))*cos(radians(-90+a*(180/400))),
sin(radians(-90+a*(180/400))),
cos(radians(b*(360/800)))*cos(radians(-90+a*(180/400)))>)/sc
         #declare b=b+1;
       #declare a=a+1;
   face_indices
     638400
     #declare a=0;
     #while (a<399)
       #declare b=0;
       #while (b<800)
         <a*800+mod(b,800), a*800+mod(b+1,800), (a+1)*800+mod(b,800)>
         <(a+1)*800+mod(b,800), (a+1)*800+mod(b+1,800), a*800+mod(b+1,800)>
         #declare b=b+1;
       #declare a=a+1;
   texture
     pigment { color rgb 0.3 }
     finish { F_Standard_Planetary_Surface }
   rotate y*clock
   translate Pos_Phobos/sc
Yadgar
Date: 20 Apr 2009 08:10:27
Message: <49ec6633$1@news.povray.org>
>       #while (b<800)
  Btw, since b is always smaller than 800, "mod(b,800)" is exactly
identical to just "b". (Where it does make a difference is in
"mod(b+1,800)".)
Date: 20 Apr 2009 08:35:02
Message: <49ec6bf6@news.povray.org>
High!
I must have placed one #end statement too much within my nested loop - I
removed it, and now it runs! At least the meridional gap is (almost)
gone, but as you can see in the latest image below, Christoph was right
in assuming that altering the scaling divisor won't help in the long run!
Onward to the next issue... the bounding problem!
Yadgar
Now playing: We Are The Refugees (Ian Cussick)
Download '2009-04-20 phobos, take 5.jpg' (12 KB)
Preview of image '2009-04-20 phobos, take 5.jpg'
