Subject: Re: Spotlights with photons (143KB) (Was: Hotel crime scene)
Date: 25 Apr 2009 06:46:52
Message: <49f2ea1c$1@news.povray.org>
> My plan had a "part two" to it (which I also didn't manage to do
> properly) - I wanted to render the light and fixture, without any other
> scene elements, to a full spherical camera, and use that as the
> transparency map for the light in a real scene (possibly with the fixture
> modified with no_shadow). If you get what I mean...
> It's still on my list of things to experiment with, but perhaps as you
> are having far more success than I ever did, it might be something you
> would find interesting?
Well... the experiment worked great and fast, but has a BIG limitation:
you cannot use area lights with it, because the "fake photons" effect
disappears (logically) due to the soft shadows... &%#$!!! :(
Any ideas? ... I cannot think of anything that will overcome this problem.
Jaime
Jaime Vives Piqueres <jai### [at] ignorancia org> wrote:
> Hi again:
> After Edouard mentioned IES light data files, I tried an experiment I
> envisioned sometime ago: creating a realistic spot fixture and let it
> reflect and refract some photons. The tests with just one spot seemed to
> work nicely, but when I integrated it on the hotel scene with the same
> photon spacing, the results don't look so great...
Oops. Is that fourteen backwards? Otherwise very nice.
- Ricky
Ahh, I see the flaw. The "shadow map" from the light and fitting is an
approximation, but from your experiment it sounds like it's not a close enough
one to actual photons...
Hmm, perhaps a no_area_light object modifier added to the SDL? That would
probably be useful in general to be honest.
I can't think of a multiple light solution that would work, and even if there
was one it wouldn't be a general solution to a scene.
Sorry my idea wasn't a winner in the end!
> Jaime
Cheers,
Edouard.
Date: 27 Apr 2009 07:36:01
Message: <49f598a1@news.povray.org>
> enough one to actual photons...
No, in fact it is very close to the photons effect, in some aspects better
looking, although not correct, of course. See attached pics...
Yes, I think that would be the only solution: the sphere with the
"photon map" could be flagged as "no_area_light". But I cannot think of any
other situation where it will be useful such a modifier...
> there was one it wouldn't be a general solution to a scene.
Well, lets wait... we all know POV-Ray unexplored possibilities are
endless, and perhaps there is already a clever way to do it, waiting for
someone to discover it.
It was a very good idea, and just in case, I will archive it under my
/stalled folder...
Jaime
Download 'fakespot_map.jpg' (22 KB)
Download 'fakespot_test.jpg' (22 KB)
Preview of image 'fakespot_map.jpg'
Preview of image 'fakespot_test.jpg'
Date: 27 Apr 2009 07:37:38
Message: <49f59902$1@news.povray.org>
Oops, indeed... Thanks!
Jaime
> I was practicing with Chief Architect, and did this hotel corridor... it was
> so boring that I decided to have some fun adding some story to it.
Am I right that the bit about the mirrored 14 involves the janitor?
jussi
