POV-Ray : Newsgroups : povray.binaries.images : Media & Glass Question Server Time
29 May 2026 16:55:13 EDT (-0400)
  Media & Glass Question (Message 11 to 15 of 15)
Subject: Re: Media & Glass Question
Date: 30 Mar 2009 21:31:45
Message: <49d17281@news.povray.org>
Jim Holsenback nous illumina en ce 2009-03-30 14:21 -->
> "Alain" <ele### [at] netscapenet> wrote in message
> news:49d0df24$1@news.povray.org...
>> Does your glass have a thickness, or is it solid trough?
> It's a lathe object, and I rotated it slightly just to make sure I could see
> all the way through it. Without a texture it looks like a hollow tube ...
> btw: when it's textured hollow on or off appears to make no difference. It
> indeed appears to be acting like a solid object.
> Just to be clear about it I'm running 3.6.1 on linux ... I'm not on that
> machine now but planned on doing some more testing (purely trial and error
> at this point) this evening .... perhaps I should post a couple of relevent
> code segments to see if anyone can spot what's going on here.
>> Now, there is a magnifier like effect that should NOT be there.
> yes that describes what we're seeing perfectly ....  the effect gets more
> pronounced as ior is increased.
>> Then, the flame's container apears to have an ior of 1.000.
> I don't recall (it's someone elses macro) but I'll check
> Thanks
> Jim
Your lathe spline should go back to form an inner surface and form a closed
shape that never reatch the axis.
Keep your eyes wide open before marriage, half shut afterwards.
Benjamin Franklin
Date: 30 Mar 2009 22:07:12
Message: <49d17ad0@news.povray.org>
Jim Holsenback nous illumina en ce 2009-03-30 16:16 -->
> "clipka" <nomail@nomail> wrote in message
> news:web.49d10dc330aab812f708085d0@news.povray.org...
>> Duh - from the looks of it, I'd say your glass globe is *solid*!
> well double duh .... that's what appears to be happening but I've proven
> that the globe is a tube. I gave it just a pigment and rotated it so I could
> see ALL the way throught it!
> I even used just a plain cone object with open and hollow keywords and the
> effect is still there.
>> So your objects *do* intersect - not their surfaces, but their volumes.
> doesn't open (if applicable) and hollow keywords overcome that problem?
> Cheers
This is a pair of open cylinder with an ior of 1.5.
The left one is rotated so that you can see trough both open ends, the other is
seen edge on.
There is also a small spgere with only a pigment of rgbt 1 and no interior at
the center of both cylinders.
As you can see, the ior does affect the background even if you only pass trough
one surface. The sphere is also visible on the right where you see it trough the
side of the cylinder.
On the left, the sphere is completely invisible, but is very visible on the right.
'Honesty is the best policy, but insanity is a better defense'
Download 't2.jpg' (36 KB)
Preview of image 't2.jpg'
Date: 31 Mar 2009 05:55:19
Message: <49d1e887@news.povray.org>
news:49d17ad0@news.povray.org...
trough
trough the
the right
ah yes simular to some tests I did ....
a differenced cone fixed the problem I was having with the infinately thin
walls of the lathe object. Before I did that scaling the entrie object by
100 didn't give any joy, just like the open/hollow cone .....
I wanted the globe to have a curved profile not straight, so maybe a merge
of a cone and an irregularly scaled sphere, then difference to trim out the
inside might suit .... maybe an isosurface with thickness.
thanks for your insights.
Jim
Date: 31 Mar 2009 06:03:49
Message: <49d1ea85@news.povray.org>
news:web.49d146c530aab8122f4aa4190@news.povray.org...
> So what you need is either an "open" shape with a surface that models
glass
> sufficiently well without relying on IOR (which is difficult)
well this excercise has proven that ....
> Or a single lathe
> object comprised of a closed spline, or something alike.
well it's back to school for me on this subject .... I thought that's what I
had with the lathe object. I even set up a "Spline Lab" environment simular
to that outlined in the documentation. I'll be reading between the lines to
see what I've missed. I may be slow but I eventually get there.
Ciao
Date: 31 Mar 2009 13:30:01
Message: <web.49d2528830aab812f708085d0@news.povray.org>
Yeah, that scaling idea was based on the assumption that you already *did* have
a differenced object ;)
Scaling a thickness of 0 by any value doesn't help, of course :P
