POV-Ray : Newsgroups : povray.binaries.images : POV 3.7 metals.inc; post your textures here Server Time
19 Feb 2026 22:25:01 EST (-0500)
  POV 3.7 metals.inc; post your textures here (Message 1 to 10 of 82)
Subject: POV 3.7 metals.inc; post your textures here
Date: 28 Mar 2009 22:06:15
Message: <49ced797@news.povray.org>
To all users:
Please post your metal textures here.
Once this inc file is done I will move to waters.inc, stones.inc, woods.inc,
etc.. so you can go ahead and post those textures too if you want. Remember:
radiosity compatibility. ;-)
ian
Subject: Re: POV 3.7 metals.inc; post your textures here
Date: 29 Mar 2009 05:20:20
Message: <49cf3d54@news.povray.org>
Here are six metal textures. Nothing really special. Just thought they might
be of interest.
Download 'textures_test_metals.jpg' (69 KB) Download 'textures_test_metals.inc.txt' (8 KB) Download 'textures_test_metals.pov.txt' (2 KB)
Preview of image 'textures_test_metals.jpg'
Date: 29 Mar 2009 09:10:01
Message: <web.49cf72ef4ee6dd4eea392f10@news.povray.org>
> be of interest.
The rusty steel looks great. The other ones in the front row I'm not sure about.
The three in the back look rather non-metallic to me - but then again, they
might all be oxidized - in that case I guess they're ok.
Date: 29 Mar 2009 09:35:37
Message: <49cf7929@news.povray.org>
"clipka" <nomail@nomail> schreef in bericht
news:web.49cf72ef4ee6dd4eea392f10@news.povray.org...
> about.
> they
The two in front you mention are fantasy metals, just for fun; the two
greenish ones are bronzes with an oxydized/patina layer. Back left, is a
rusty iron.
They may not be exactly RL, but I am not sure that metals.inc should only
contain RL stuff. However, I leave selection to the community.
Date: 29 Mar 2009 12:20:01
Message: <web.49cf9ea34ee6dd4e1dfafa300@news.povray.org>
"[GDS|Entropy]" <gds-entropy    AT    hotmail   DOT  com> wrote:
> To all users:
> ian
A rusty iron-texture
---[Snip]---------------
//*PMRawBegin
#include "textures.inc"
//*PMRawEnd
global_settings {
   adc_bailout 0.0039216
   assumed_gamma 1.5
   max_trace_level 256
   noise_generator 2
sky_sphere {
      color rgb <0.054902, 0.219608, 0.4>
cylinder {
   <0, 3, 0>, <0, -3, 0>, 2
         spherical
         turbulence <1, 1, 1>
         omega 1
         lambda 6
         color_map {
            [ 0.1 color rgb <0.478431, 0.513725, 0.462745>
      normal {
         boxed
         30
         omega 1
         lambda 6
         frequency 15
      finish {
         ambient rgb <0, 0, 0>
         diffuse 0.3
         specular 0.6
         conserve_energy
         reflection {
            rgb <0.1, 0.1, 0.1>
            metallic 1
      scale 15
   scale 1
   rotate <0, 0, 0>
   translate <1.6, 0, 5.53333>
sphere {
   <0, 0, 0>, 2
      uv_mapping
         spherical
         omega 1
         lambda 6
         color_map {
      normal {
         boxed
         30
         omega 1
         lambda 6
         frequency 15
      finish {
         diffuse 0.3
         specular 0.6
         conserve_energy
         reflection {
            rgb <0.1, 0.1, 0.1>
            metallic 1
      scale 7.5
   scale 1
   rotate <0, 0, 0>
   translate <2.13333, 0, -3.13333>
torus {
   3, 1
         spherical
         omega 1
         lambda 6
         color_map {
      normal {
         boxed
         30
         omega 1
         lambda 6
         frequency 15
      finish {
         diffuse 0.3
         specular 0.6
         conserve_energy
         reflection {
            rgb <0.1, 0.1, 0.1>
            metallic 1
      scale 7.5
   scale 1
   rotate <90, -45, 0>
   translate <-3.73333, 0, 3.5>
light_source {
   //*PMName Key-Light
   <7, 5, -10>, rgb <1, 1, 1>
   area_light <6, 0, 0>, <0, 6, 0>, 9, 9
   adaptive 2
   jitter
   circular
   orient
light_source {
   //*PMName Fill-Light
   <-7, 5, -10>, rgb <0.5, 0.5, 0.5>
   shadowless
   media_interaction off
   perspective
   location <-0.3, 4, -9>
   sky <0, 1, 0>
   direction <0, 0, 1>
   right <1.3333, 0, 0>
   up <0, 1, 0>
   look_at <0, 0, 0>
---[Snap]------------
Download 'rostiges eisen(2).png' (405 KB)
Preview of image 'rostiges eisen(2).png'
Date: 29 Mar 2009 13:28:02
Message: <49cfafa2@news.povray.org>
Metallic spaceship-hull panels
.. or greebles-in-a-texture if you like :)
--- START CODE ---
#declare MetalPanels=
  average
  pigment_map {
   [1
   cells
   pigment_map {
    [0
     cells
     color_map {
      [0 rgb .6]
      [1 rgb 1]
     scale 1.5
    [.4
     cells
     color_map {
      [0 rgb .8]
      [1 rgb 1]
     translate <.25,.5,.2>
   [1
   cells
   color_map {
    [0 rgb .8]
    [1 rgb 1]
   translate <.25,1.5,.2>
   scale 2
   translate <2.25,1.5,3.5>
  scale .25
 normal {
  average
  normal_map {
   [1
   cells
   normal_map {
    [0
     cells
     bump_size 1
     scale 1.5
    [.4
     cells
     bump_size .8
   scale 1
   [1
   cells
   normal_map {
    [0
     cells
     bump_size 1
     scale .5
    [.4
     cells
     bump_size .8
   scale .25
   [1
   cells
   bump_size .5
   scale 2
 finish {ambient 0 diffuse 1 brilliance 4 specular 1 roughness .01 metallic}
#declare PanelScars=
  crackle form <1,0,0>
  color_map {
   [0 rgbt <.1,.01,0,.5>]
   [.2 rgbt <.1,.01,0,1>]
  scale .5
  turbulence .2
  lambda 3
  scale 4
 normal {
  dents .1
 finish {
  diffuse .5 ambient 0
#declare PanelDirt=
  granite
  color_map {
   [0 rgb .2*<.8,.75,.7> transmit .99]
   [1 rgb .1*<.8,.75,.7> transmit .8]
 finish {ambient 0 diffuse .5}
#declare PanelDirt2=
  granite
  color_map {
   [1 rgb .1*<.8,.75,.7> transmit .6]
//Test-scene:
#local Area_Lights=off;
#local Skylights=60;
#local Seed=seed(123);
 location <2,2,2>*2
 look_at 0
//some fancy lighting
light_source {
 <-500,500,500>*50
 rgb <1.5,1.3,1.1>
 #if (Area_Lights)
 area_light
 x*5000,y*5000
 4,4
 circular
 orient
#local MI=Skylights;
#local I=0;
#while (I<MI)
 #local LL=vrotate(vrotate(x,z*360*rand(Seed)),y*180*rand(Seed));
 #local LH=pow(LL.y,2);
 #local LX=pow(1+LL.x/2,1);
 #local LL=LL*5000;
 light_source {
  LL
  rgb <.4,.5,.9>*2.5/MI
  #if (Area_Lights)
  area_light
  x*5000,y*5000
  4,4
  adaptive 2 jitter circular orient
 #local I=I+1;
sphere {
 0,1
 uv_mapping
 texture {MetalPanels translate 1 scale .25}
 texture {PanelScars scale <.125,.125,.5>}
 texture {PanelDirt scale <.5,.25,1>}
 texture {PanelDirt2 scale <.25,.125,.7>}
torus {
 1.5,.5
 uv_mapping
union {
 cylinder {-x*4,x*4,.35}
 cylinder {-z*4,z*4,.35}
 texture {PanelDirt scale <.5,.25,.5>}
 texture {PanelDirt2 scale <.7,.125,.7>}
sphere {
 0,1
 pigment {bumps
  color_map {
   [.25 rgb <.7,.8,.9>]
   [.7 rgb 1]
  poly_wave 2
  scale <1,.25,1>*5
  warp {turbulence .5 lambda 3}
  scale .5/5
 finish {ambient 1 diffuse 0}
 scale 100
 no_shadow
 no_image
plane {y,-2
  granite
  color_map {
   [0 rgb <.5,.4,.3>]
   [1 rgb <.6,.5,.4>]
 no_image
 no_shadow
--- END CODE ---
cu!
Download 'metalpanels.jpg' (40 KB)
Preview of image 'metalpanels.jpg'
Date: 29 Mar 2009 13:30:00
Message: <web.49cfaffb4ee6dd4eea392f10@news.povray.org>
Looks more like old oil than rust to me - but great effect in any case!
Date: 29 Mar 2009 14:07:22
Message: <49cfb8da$1@news.povray.org>
  That one could be quite useful to many, I'm sure.
Date: 29 Mar 2009 16:30:00
Message: <web.49cfda3f4ee6dd4eea392f10@news.povray.org>
Definitely so.
Date: 29 Mar 2009 18:15:00
Message: <web.49cff2824ee6dd4e5aa5eee10@news.povray.org>
> To all users:
> ian
Here's another rusty one ...
#declare radiosity_on = true;
#declare globalreflection =1;
#if (radiosity_on)
// radiosity (global illumination) settings
global_settings {
  radiosity {
    pretrace_start 0.08           // start pretrace at this size
    pretrace_end   0.04           // end pretrace at this size
    count 35                      // higher -> higher quality (1..1600) [35]
    nearest_count 5               // higher -> higher quality (1..10) [5]
    error_bound 1.8               // higher -> smoother, less accurate [1.8]
    recursion_limit 3             // how much interreflections are calculated
(1..5+) [3]
    low_error_factor .5           // reduce error_bound during last pretrace
step
    gray_threshold 0.0            // increase for weakening colors (0..1) [0]
    minimum_reuse 0.015           // reuse of old radiosity samples [0.015]
    brightness 1                  // brightness of radiosity effects (0..1) [1]
    adc_bailout 0.01/2
    //normal on                   // take surface normals into account [off]
    //media on                    // take media into account [off]
    //save_file "file_name"       // save radiosity data
    //load_file "file_name"       // load saved radiosity data
    //always_sample off           // turn sampling in final trace off [on]
    //max_sample 1.0              // maximum brightness of samples
  assumed_gamma 1.0
#else
global_settings {
  assumed_gamma 1.0
#declare base = texture {
  pigment { color rgb <0.91, 0.95, 0.91>*0.5}
  normal {
     wrinkles
      normal_map {
        [ 0.0 granite 0.00 scale 0.001]
        [ 0.2 granite 0.0 ]
        [ 0.28 wrinkles 0.05 turbulence 0.5 scale 0.005]
        [ 0.38 wrinkles 0.05 turbulence 0.5 scale 0.005]
        [ 0.4 granite 0.0 ]
        [ 0.62 granite 0.05 turbulence 0.5 scale 0.005]
        [ 0.9 granite 0.0 ]
        [ 1.0 granite 0.00 scale 0.001]
  turbulence 0.05
  scale 300
    #if (radiosity_on)
      finish {
        ambient 0.0
        brilliance 2
        diffuse 0.3
        metallic
        specular 0.80
        roughness 1/2000
        reflection 0.9*globalreflection
    #else
      finish {
        ambient 0.01
        brilliance 2
        diffuse 0.3
        metallic
        specular 0.80
        roughness 1/2000
#declare tex1 = texture {
  pigment { granite
    color_map {
      [ 0 color rgb <0.7, 0.4, 0.2> ]
      [ 1 color rgb <0.6, 0.2, 0.05> ]
    } turbulence 0.2 scale 0.5
  normal { bumps 0.2
  turbulence 0.05
  scale 0.5
    #if (radiosity_on)
      finish {
        ambient 0.0
        brilliance 2
        diffuse 0.3
        metallic
        specular 0.20
        roughness 1/20
        reflection 0.1*globalreflection
    #else
      finish {
        ambient 0.01
        brilliance 2
        diffuse 0.3
        metallic
        specular 0.20
        roughness 1/20
#declare tex2 = texture {
  wrinkles
  texture_map {
     [0  base]
     [0.5 tex1 ]
  } scale 0.2 turbulence 0.5
#declare final= texture {
  wrinkles
  texture_map {
     [0  base]
     [0.1 base]
     [0.1 tex2 scale 0.005]
     [0.11 tex2 scale 0.005]
     [0.12 base]
     [0.5 base]
     [0.7 tex2 scale 0.05]
Download 'metaltex.png' (216 KB)
Preview of image 'metaltex.png'
