POV-Ray : Newsgroups : povray.binaries.images : POV 3.7 metals.inc; post your textures here Server Time
30 May 2026 00:25:33 EDT (-0400)
  POV 3.7 metals.inc; post your textures here (Message 71 to 80 of 82)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: POV 3.7 metals.inc; post your textures here
Date: 3 Apr 2009 06:23:00
Message: <49d5e384@news.povray.org>
clipka wrote:
> Yup, this is my point: It is the global ambient_light that is the thing
> originally intended to tweak the ambient of textures globally, not the #default
> ambient.
  "Originally" is the same thing thing as "correct"?
  And how is it in any way relevant what was the original meaning of
ambient_light with respect to what is the best way of designing textures
currently?
Date: 3 Apr 2009 07:55:00
Message: <web.49d5f8db4ee6dd4ef708085d0@news.povray.org>
> > ambient.
If there is any doubt about what is "correct", then yes, "originally" is what I
think does tip the scale.
> currently?
In the same way as *any* original meaning of something is of relevance to what
is the best way today: If you can't come up with something significantly
better, better stick to the original because it is prone to be "more" standard.
Date: 3 Apr 2009 08:33:44
Message: <49d60228$1@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.49d5dcd34ee6dd4ef708085d0@news.povray.org...
> "Zeger Knaepen" <zeg### [at] povplacecom> wrote:
>> how about making the default value for emission the same as the
>> ambient-value?
> No, definitely not. In a radiosity scene, only very, very few textures are
> typically intended to emit light. But in a non-radiosity scene, you
> probably
> want many, many textures to have an ambient term, in order to approximate
> "ambient illumination" (i.e. illumination by light scattered diffusely
> from
> other objects).
> So the typical use case would be to have ambient X emission 0.
this would completely break older scenes.  If the default emission-value is
the same as the specified ambient-value, then older scenes will render
exactly the same as they used to.
>> Also, I don't think emission should have any meaning when not used with
>> radiosity.
> I disagree.
> In a radiosity-only scene, of course you want emission to have an effect,
> because there'd be no other way to get light into the scene (except for a
> sky
> sphere).
> When lighting the same scene classically, you probably want the same thing
> to
> look similar when directly visible in the scene. For this, it will have to
> emit, too.
They will look exactly the same when directly visible, since only ambient
(and not emission) would affect the look of the texture itself.
So finish {ambient 1 emission .5} and finish {ambient 1 emission 5} will
look the same in a non-radiosity scene, but will affect their environment
different in a radiosity-scene... but even there the texture itself will
> Christian's idea to leave ambient fully functional in radiosity scenes for
> compatibility, and expecting the user to actively turn it off by setting
> ambient_light to 0, seems the most viable solution to me.
as already stated, that wouldn't work in a scene without convention
light_sources
I'm all for an emission-value in the finish-statement, but only if it
a) doesn't just duplicate the effect of ambient (it has to have a different
meaning than ambient) and
b) doesn't break old scenes (older scenes have to render exactly the same as
they do now)
and the only way, IMHO, to satisfy both conditions, is to let emission (and
only emission) only have effect in radiosity-lighting and to let the default
emission-value be the same as the specified ambient-value.
cu!
Date: 3 Apr 2009 10:00:00
Message: <web.49d615d84ee6dd4ef708085d0@news.povray.org>
I don't see how setting emission to 0 would break older scenes. Not with
Christian's suggestion for keeping backward-compatibility.
To recap the combined suggestion:
- Ambient works as it has always done. It's just deprecated to be used for
anything that is supposed to look like it's actively emitting light (as opposed
to things that are supposed to look like they're passively illuminated by
indirect light).
- For things that are supposed to look like they're actively emitting light, it
will be recommended to use the new "emission" keyword instead, which does
exactly the same as ambient except that it is not affected by the ambient_light
setting. (If both are used, the effects add up.)
- In non-radiosity scenes, nothing else changes to the current situation.
- In radiosity-only scens, it will be recommended to set ambient_light to 0; any
other value will only be accepted for backward compatibility, and generate a
deprecation warning. It will be expected that the emission mechanism is used to
generate light sources, instead of the ambient mechanism.
- In combined scenes, too, it will be recommended to set ambient_light to 0, and
any other value generate a deprecation warning. For such scenes, it will be
expected that the emission mechanism without a classic light source is used to
generate visible light sources, but otherwise classic light sources are used.
For this approach to work, clearly emission must default to 0.
> > to
> > emit, too.
Ah, so this is where you're misunderstanding things (or have different
expectations): You expect "emission" to only affect radiosity, and not the way
the thing looks when directly visible in the shot.
I can tell you that (a) I wouldn't want it that way (because after all, the
directly visible glow of an object *is* emission, not ambient illumination, so
it would be right to control both with the "emission" statement, and (b) it
would also be more difficult to implement, because without additional
programming effort, radiosity generally "sees" what the observer sees as well.
So both ambient *and* emission would have a directly visible effect, and both
would affect radiosity. It's just that in radiosity scenes the one would be
suggested to be turned off, while the other would remain effective.
Now you may wonder, "but what if I want my texture to have that slight ambient
term in radiosity scenes, too?"
Well, you just wouldn't. Ambient illumination as modeled with the "ambient" and
"ambient_light" mechanism is just an approximation of what radiosity does
automatically and better; with radiosity, that mechanism is simply just in the
way. You don't need it to model realistic textures for radiosity scenes. To the
contrary: You *can't* model realistic (non-glowing) textures for radiosity
scenes that have any ambient term.
> light_sources
That would depend on the approach used; with the approach Christian and I have
in mind, it would work perfectly.
It will - if only due to the fact that it will be independent of the
ambient_light, which can then be used to switch off all ambient terms globally,
while leaving a mechanism to model glowing objects.
And (likewise important if I'm asked), despite all similarities in effect, it
will have a totally different *meaning* - thank you for the word.
The "ambient" term will state - in line with its original intention - that an
object receives ambient illumination from somewhere, and needs therefore to be
non-black even in shadows. The very same thing radiosity computes automatically
and at much better quality.
The "emission" term will state that an object emits light by itself regardless
of other illumination sources; "ambient" has been mis-used for this purpose in
the past in lack of a separate mechanism, but this is the very reason why
ambient has become a problem.
> they do now)
Doesn't happen with my idea, when combined with Christian's suggestion.
IYHO. I disagree, for multiple reasons:
(1) Semantics: Passive ambient illumination *is* something different in the real
world than active emission of light; while in the approach you have in mind,
neither "ambient" nor "emission" would properly describe what the things do
(because neither would have any real-world equivalent, taken on its own).
(2) Ease of use: With the approach proposed by Christian and me, the bulk of
existing textures would be immediately radiosity-ready. No need to change
anything, unless the texture is *intended* to glow - just set ambient_light to
0 and render; and making full use of that approach in future scenes would be
virtually no more difficult than it is now: Just throw in an "emission"
statement for every texture *intended* to glow, and do the others as usual.
With your approach, the bulk of existing textures would have to be explicitly
equipped with "emission 0" statements to make them radiosity-ready - and future
scenes would of course require that statement, too, to make the best use of the
approach. Worse yet: A significant portion of textures will continue to be
created non-radiosity-ready, because scene designers typically not using
radiosity will often just not bother adding that "emission 0" statement.
(3) Ease of implementation: Any surface feature that should "look" different to
radiosity than it does to the observer requires extra implementation effort.
To sum it up: I don't think the approach you had in mind is really viable.
Date: 3 Apr 2009 13:26:44
Message: <49d646d4$1@news.povray.org>
I almost completely disagree with your post, but I'm to tired for a
discussion now :)
cu!
Date: 3 Apr 2009 14:49:18
Message: <49d65a2e@news.povray.org>
clipka nous illumina en ce 2009-04-03 05:54 -->
>> ambient-value?
> typically intended to emit light. But in a non-radiosity scene, you probably
> "ambient illumination" (i.e. illumination by light scattered diffusely from
> other objects).
>> radiosity.
> I disagree.
> because there'd be no other way to get light into the scene (except for a sky
> sphere).
> When lighting the same scene classically, you probably want the same thing to
> emit, too.
Setting ambient_lights 0 is definetly NOT a viable solution. As you said, it
effectively turn OFF any and all ambient, for every finish, even those you WANT
to have an ambient value and emit light.
   I knew a girl so ugly that she was known as a two-bagger. That's When you put
a bag over your head in case the bag over her head comes Off.
	Rodney Dangerfield
Date: 3 Apr 2009 16:55:01
Message: <web.49d677104ee6dd4e81475b100@news.povray.org>
> [snip]
Even though my novice vote should not count for much, I just want to
chip in to say that I am in favour of clipka's and Cristian's combined
suggestion. I agree that the meaning of the ambient and emmision statement is
clearly distinct, and both meanings are easy to comprehend. Also, I cannot see
anything awkward in using old textures, defining textures that work in normal
rendered scenes as well as radiosity-rendered scenes, re-rendering old scenes,
etc when this approach would be implemented.
Cheers,
Erwin
Date: 3 Apr 2009 17:00:00
Message: <web.49d678744ee6dd4e58271f380@news.povray.org>
.... which is *exactly* what we'd have the "emission" statement for, so no
problem.
Date: 4 Apr 2009 03:40:01
Message: <web.49d70ea64ee6dd4ecb42dd300@news.povray.org>
Really an interesting approach, clipka.
But *emission* keyword can be confusing to the *emission* media?
(only in terms of keywords, obviously)
Carlo
Date: 4 Apr 2009 05:50:00
Message: <web.49d72b844ee6dd4eae1b72370@news.povray.org>
Indeed; so far, I considered the keyword only a kind of "working draft", and I
wasn't sure about it either.
On the other hand, using this particular keyword may actually be of benefit: You
put "emission COLOR" in a media, and the object's interior glows; you put
"emission COLOR" in a surface, and that surface glows. Sounds reasonably
straightforward to me.
