POV-Ray : Newsgroups : povray.binaries.images : POV 3.7 metals.inc; post your textures here Server Time
29 May 2026 18:07:20 EDT (-0400)
  POV 3.7 metals.inc; post your textures here (Message 63 to 72 of 82)
Subject: Re: POV 3.7 metals.inc; post your textures here
Date: 2 Apr 2009 15:30:36
Message: <49d5125c$1@news.povray.org>
Warp wrote:
> Can you tell me an example of a texture where the author wants to
> control the ambient term of the finish, and for which you want to turn
> the ambient term off for a radiosity scene?
I just question your honorable assumption that all POV-Ray users are
so enlightened that they would never ever dream of using ambient > 0
to tweak a texture to make it look better unless they also want it to
glow in the dark should someone dare use it in a radiosity scene ;)
Date: 2 Apr 2009 15:45:47
Message: <49d515eb$1@news.povray.org>
clipka wrote:
> If I'm asked, there should be a separate "emission" parameter, with the whole
> "ambient" mechanism turned off in radiosity scenes.
that sounds like the correct solution. Although by default,
ambient probably needs to remain emissive as well for backward
compatibility. Radiosity scenes using "emission" can then set
ambient_light to 0 without losing their light sources.
Date: 2 Apr 2009 17:17:47
Message: <49d52b7b$1@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> wrote in message
news:49d515eb$1@news.povray.org...
>> whole
how about making the default value for emission the same as the
ambient-value?
Also, I don't think emission should have any meaning when not used with
radiosity.
So, finish {ambient 1 diffuse 0} results in an unshaded emissive texture,
finish {ambient 0 diffuse 1 emission 1} results in a texture that looks like
finish {ambient 0 diffuse 1} but for radiosity-calculations acts like finish
{ambient 1 diffuse 1} does now.  And finish {ambient 1 diffuse 0 emission 0}
results in a texture that looks unshaded and emissive, but doesn't emit any
light in a radiosity-scene.
It might not be realistic to have a normally shaded object to emit light,
but this way is IMHO the most versatile way, and also the easiest to use,
because most of the time you wouldn't even have define an emission-value
(and it's completely backward-compatible).
cu!
Date: 2 Apr 2009 18:21:46
Message: <49d53a7a@news.povray.org>
> ambient-value?
yes that should work nicely
I don't know how radiosity is implemented in detail, it may
be a problem to have an object which is bright but should not
radiate away light. But a radiosity scene could then treat
ambient as 0 if emissive is present.
Date: 2 Apr 2009 21:27:33
Message: <49d56605$1@news.povray.org>
clipka nous illumina en ce 2009-04-02 07:15 -->
> Warp <war### [at] tagpovrayorg> wrote:
>>   If the author wants a texture which is lighted "normally" by whatever
>> scene settings are currently in place, then he naturally should not
>> define any ambient term at all. That way the texture will use the
>> default ambient, which can be set in the scene with #default.
> Guess what the intended purpose of the global ambient_light setting is...
The original purpose of ambient_lights in the global_settings section is to
gives a shade to the ambient part of the finish.
Want all parts of the scene in the shadows to be bluish, put:
ambient_lights rgb<0.3, 0.5, 1>
and every shadow gets a blue cast.
You know you've been raytracing too long when you start wishing you were
actually in that futuristic mandelbrotian landscape you just rendered.
     -- fish-head
Date: 3 Apr 2009 05:20:00
Message: <web.49d5d44d4ee6dd4ef708085d0@news.povray.org>
I didn't think of that, but yes - of course. That's the solution to maintaining
backward compatibility.
Add a deprecation warning if ambient_light is set to anything other than 0 in a
radiosity scene, to encourage people shifting to the "emission" mechanism.
BTW, I also suggest adding an "emission" statement to the sky_sphere, so the
brightness of e.g. a HDR light probe can be tweaked without resorting to a
"real" sphere.
Date: 3 Apr 2009 05:55:01
Message: <web.49d5dcd34ee6dd4ef708085d0@news.povray.org>
> ambient-value?
No, definitely not. In a radiosity scene, only very, very few textures are
typically intended to emit light. But in a non-radiosity scene, you probably
want many, many textures to have an ambient term, in order to approximate
"ambient illumination" (i.e. illumination by light scattered diffusely from
other objects).
So the typical use case would be to have ambient X emission 0.
> radiosity.
I disagree.
In a radiosity-only scene, of course you want emission to have an effect,
because there'd be no other way to get light into the scene (except for a sky
sphere).
When lighting the same scene classically, you probably want the same thing to
look similar when directly visible in the scene. For this, it will have to
emit, too.
Christian's idea to leave ambient fully functional in radiosity scenes for
compatibility, and expecting the user to actively turn it off by setting
ambient_light to 0, seems the most viable solution to me.
Date: 3 Apr 2009 06:00:00
Message: <web.49d5dd964ee6dd4ef708085d0@news.povray.org>
Yup, this is my point: It is the global ambient_light that is the thing
originally intended to tweak the ambient of textures globally, not the #default
ambient.
Date: 3 Apr 2009 06:23:00
Message: <49d5e384@news.povray.org>
> ambient.
  "Originally" is the same thing thing as "correct"?
  And how is it in any way relevant what was the original meaning of
ambient_light with respect to what is the best way of designing textures
currently?
Date: 3 Apr 2009 07:55:00
Message: <web.49d5f8db4ee6dd4ef708085d0@news.povray.org>
> > ambient.
If there is any doubt about what is "correct", then yes, "originally" is what I
think does tip the scale.
> currently?
In the same way as *any* original meaning of something is of relevance to what
is the best way today: If you can't come up with something significantly
better, better stick to the original because it is prone to be "more" standard.
