POV-Ray : Newsgroups : povray.binaries.images : POV 3.7 metals.inc; post your textures here Server Time
29 May 2026 20:37:12 EDT (-0400)
  POV 3.7 metals.inc; post your textures here (Message 41 to 50 of 82)
Subject: Re: POV 3.7 metals.inc; post your textures here
Date: 1 Apr 2009 11:40:01
Message: <web.49d38a4a4ee6dd4ef708085d0@news.povray.org>
> > ambient 0 in the finish statement, otherwise it would emit light.
>   That's what #default { finish { ambient 0 } } is for.
Not with material to place in a lib. Those should have all parameters set, just
to be sure. After all, you never know what the user sets his defaults to.
>   What happens if you *want* the texture to have an ambient value >0?
Then you're screwed with radiosity...
Date: 1 Apr 2009 11:45:00
Message: <web.49d38b094ee6dd4ef708085d0@news.povray.org>
Ive <"ive### [at] lilysoftorg"> wrote:
> Well, I did see it the other way round. If you define a texture that
> looks great with nice specular/phong highlights you might be
> disappointed how it looks if used in a radiosity only lit scene, because
> all highlights are gone.
(As a matter of fact, I think the material definitions should get some overhaul,
too, so that specular highlights and specular reflection are automatically "in
sync", so you don't have to worry about such issues)
Date: 1 Apr 2009 15:47:20
Message: <49d3c4c8$1@news.povray.org>
include files could use a #define such as RADIOSITY_TEXTURES
to provide two versions of a texture depending on whether the
#define is set before #including. For textures which just use
a different ambient value that would be no extra effort to
write using a simple macro for ambient.
#macro AMBIENT(ambient_value)
#ifdef RADIOSITY_TEXTURES
   ambient 0
#else
   ambient ambient_value
#declare T_SOME_TEXTURE = texture
   pigment {...}
   normal  {...}
   finish  {... AMBIENT(0.15)}
Date: 1 Apr 2009 16:10:00
Message: <web.49d3c8d94ee6dd4ef50167bc0@news.povray.org>
> Kenneth wrote:
> > Sorry to be so brain-challenged, but: radiosity compatibility? I've seen that
> > term mentioned several times lately, and have no clue what it means re:
> > textures.  I must have missed something somewhere. Please explain?
> For "radiosity-lit-only" scenes (or MCPov for that matter) it would even
> mean "specular 0" and "phong 0".
Got it. (Although the specular and phong stuff is new--I need to do some
experiments to see.)
Here's an 'old pitted iron texture' that I dug out of one of my scenes (I
actually started with one of the stones.inc pigments, and modified it)...
#declare old_pitted_iron_texture =
        pigment{
                granite  // AGATE works well for this too.
                color_map {
                        [0.000 rgb .8*<.4, .4, .380>]
                        [0.153 rgb .4]
                        [0.398 rgb .5*<0.7, 0.4, 0.25>]
                        [0.398 rgb .2*<0.7, 0.7, 0.7>]
                        [1.000 rgb <0.545, 0.380, 0.345>]
        finish{
              ambient .2 // 0 for radiosity
              diffuse 1
              phong .6
              phong_size 24
        normal {granite .7 scale 9}
KW
Download 'old_pitted_iron.jpg' (52 KB)
Preview of image 'old_pitted_iron.jpg'
Date: 1 Apr 2009 17:10:36
Message: <49d3d84c$1@news.povray.org>
Ive wrote:
> This does not work if the texture already has a finish with ambient > 0.
> But I'm pretty sure you know that.
  Then wouldn't the correct suggestion be "don't put an 'ambient' term
in the finish of the texture" rather than "use 'ambient 0'"?
  The former doesn't fix the ambient, so you can later change it to
whatever you want with #default. The latter fixes it and you can't
change it without modifying the texture code.
Date: 1 Apr 2009 17:11:24
Message: <49d3d87c@news.povray.org>
Alain wrote:
> Warp nous illumina en ce 2009-04-01 10:41 -->
> You just add finish{ambient YourValue} and it will override that defined
> elsewhere.
  Wouldn't it simply be easier if the texture didn't define any ambient
at all? Then you can use #default to set it to whatever you want.
Date: 1 Apr 2009 17:13:02
Message: <49d3d8de@news.povray.org>
> to be sure.
  Just to be sure of what?
  Why shouldn't the ambient term of a texture be definable with a
#default block, even if the texture is in a library?
  That didn't answer my question.
Date: 1 Apr 2009 17:43:32
Message: <49d3e004$1@news.povray.org>
because the designer of the texture might wish to specify
the intended ambient value for use with classical lighting.
Date: 1 Apr 2009 18:45:01
Message: <web.49d3edd34ee6dd4ef50167bc0@news.povray.org>
That's true.
Actually there's already a very easy way to turn off ALL ambient light settings
in a scene: global_settings{ambient_light 0}
It's really a multiplier (which is why it's set up as <1,1,1> by default); a
very useful little on/off ambient-light switch for running radiosity scenes.
KW
Date: 1 Apr 2009 18:55:01
Message: <web.49d3f0454ee6dd4ebda078810@news.povray.org>
> That's true.
> KW
I find that even worse - in a radiosity scene, you often want some objects to
give out light via an ambient term. Specifically with lightprobes, you need the
lightprobe image to be ambient X and diffuse 0. Radiosity based lightprobe
scenes often have no actual lights - all the lighting originates from the
lightprobe. Setting the global ambient multiplier to 0 turns off the lightprobe
in those cases, and your scene ends up black...
