POV-Ray : Newsgroups : povray.binaries.images : Textured block pattern problem Server Time
20 Feb 2026 00:02:41 EST (-0500)
  Textured block pattern problem (Message 1 to 10 of 44)
Subject: Textured block pattern problem
Date: 24 Mar 2009 20:51:36
Message: <49c98018$1@news.povray.org>
High!
While playing around with procedurally generated countries' flags, I
tried to use them in patterns... and to make it simple in the beginning,
I started with a checker pattern containing the flags of Palau and
Trinidad and Tobago:
The include file containing the texture definitions (I plan to program
all sovereign countries' flags of the world later on):
// beginning of procflags.inc
#declare F_NoLights =
finish
   ambient 1
   diffuse 0
#declare P_Flag_Palau =
pigment
   spherical
   color_map
     [0 rgb <0, 0.75, 1>]
     [0.0001 rgb <0, 0.75, 1>]
     [0.0001 rgb <1, 1, 0>]
   // translate <-0.1, 0, 0.03>
#declare T_Flag_Palau =
texture
   pigment { P_Flag_Palau }
   finish { F_NoLights }
#declare P_Flag_TrinidadAndTobago =
pigment
   gradient x
   triangle_wave
   color_map
     [0.87 rgb <1, 0, 0>]
     [0.87 rgb 1]
     [0.92 rgb 1]
     [0.92 rgb 0]
   rotate y*45
#declare T_Flag_TrinidadAndTobago =
texture
   pigment { P_Flag_TrinidadAndTobago }
// end of procflags.inc
And the actual test scene:
// beginning of procflagstest.pov
#include "procflags.inc"
plane
   y, 0
   texture
     pigment
       checker
     finish { ambient 1 diffuse 0 }
camera
   location <0, 10, 0>
   look_at 0
   angle 40
// end of procflagstest.pov
...but the textures continue through the checker pattern rather than
being "copied" into each checker cell (see attached picture) - is this a
general shortcoming of the checker pattern, or are there ways to avoid this?
See you on www.khyberspace.de!
Yadgar
Download 'procflagstest.png' (4 KB)
Preview of image 'procflagstest.png'
Subject: Re: Textured block pattern problem
Date: 24 Mar 2009 21:40:00
Message: <web.49c98a9e143ba0c5ee2312a30@news.povray.org>
All the checker pattern does is "weave" two textures (or pigments or whatever)
together in an alternating fashion. It does no transformations whatsoever on
the textures themselves.
This is not a "shortcoming" - it's just the way the checker pattern works.
Having the pattern repeat for each tile is not always desired, so that requires
an additional operation, a so-called warp (more precisely, a repeat warp in this
case; you probably need two of them). See "3.5.12.6.2  Repeat Warp" in the POV
3.6 documentation.
Date: 24 Mar 2009 22:16:19
Message: <49c993f3@news.povray.org>
> 3.6 documentation.
Oh, it's legal to use more than one warp in each pattern? Then here we
go! But there's still one problem: almost all countries' flags are
rectangles (usually at a 3:2 ratio) rather than squares, so I need to
scale the checker cells *before* I insert the defined textures...
See you in Khyberspace!
Yadgar
Download 'procflagstest.png' (5 KB)
Date: 24 Mar 2009 22:30:33
Message: <49c99749@news.povray.org>
High!
I got it... scaling the checker pattern and then reciprocally rescaling
the textures does the trick!
plane
   y, 0
   texture
     scale x*1.5
     pigment
       checker
       pigment { P_Flag_Palau scale 0.3 scale <2/3, 0, 0> translate
<0.42, 0, 0.5> warp { repeat x } warp { repeat z } }
       pigment { P_Flag_TrinidadAndTobago scale <2/3, 0, 0> translate
x*0.65 warp { repeat x } warp { repeat z } }
Yadgar
Download 'procflagstest.png' (15 KB)
Date: 25 Mar 2009 05:30:00
Message: <web.49c9f976143ba0c56dd25f0b0@news.povray.org>
> 3.6 documentation.
Dang, I completely forgot about repeat warps. Looks like I reinvented the wheel
again... ;-)
Date: 25 Mar 2009 09:17:28
Message: <49ca2ee8@news.povray.org>
> wheel again... ;-)
  I always thought that POV-Ray was specially crafted for people who like to
reinvent the 3D wheel... :)
Jaime
Date: 25 Mar 2009 09:30:00
Message: <web.49ca31b7143ba0c56dd25f0b0@news.povray.org>
> > wheel again... ;-)
It's often quicker to do so than go hunting through docs and resources...!
I was making some textures the other day by drawing pictures with spherical and
boxed pigments, then tessellating them. Because I was using pigment functions
to combine the various shapes, it seemed obvious to call them as
fn(x-floor(x), 0, z-floor(z)).x
to get the repetition...
Date: 25 Mar 2009 11:05:00
Message: <web.49ca4724143ba0c5c1f399840@news.povray.org>
Yeah. It seems that most things are actually quite trivial in POV - at least in
the original latin sense, literally meaning "having three ways" ;)
In this case, another one would be to use the pattern as a function image (see
3.5.11.16) without the "once" keyword ;) (didn't test it, but I guess it should
tile like any proper image would)
You know you've been raytracing too long when...
    ... you know every little trick the POV SDL has to offer ;)
Date: 25 Mar 2009 11:53:20
Message: <49ca5370$1@news.povray.org>
Or at least the sphere.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 25 Mar 2009 12:30:00
Message: <web.49ca5af3143ba0c5c1f399840@news.povray.org>
Yeah, those are "tri-vial" as well: You can use POV's standard sphere{}, but
occasionally you are better off with a sperical blob element. And occasionally
you may have reason to model it as an isosurface - or a mesh, for that
matter...
Using bicubic patches to approximate a sphere seems to be a bit difficult
though...
