POV-Ray : Newsgroups : povray.binaries.images : Textured block pattern problem Server Time
29 May 2026 20:36:56 EDT (-0400)
  Textured block pattern problem (Message 41 to 44 of 44)
Subject: Re: My contribution is online now! (n/t)
Date: 28 Mar 2009 15:56:37
Message: <49ce80f5$1@news.povray.org>
High!
clipka wrote:
> POV-Ray does not allow for a textured object to be used itself in an
> object-pattern. It must be "naked", so to speak.
I removed the textures from the inc file, now the render runs... but
although I defined a white pigment for the object pattern, it does not
show up at all! The only way I can tell from is the slowing down of the
render...
See you in Khyberspace!
Yadgar
Date: 28 Mar 2009 15:59:35
Message: <49ce81a7$1@news.povray.org>
news:49ce67af$1@news.povray.org...
> I tried it once more, and now I got the confirming screen!
Congratulations :o)
Now that it's there I can see a few reasons it might have given you problems
with the upload:
When you download from the object collection it generates some files that
you don't need to upload (a readme, a little script and a copyright logo).
Basically anything that isn't prefixed with the object name you don't need
to upload.
To make it 'standards compliant' you mostly just need to prefix everything
with the object name. So I've prefixed the new include file and all the
variables contained within it. With files generated from Inkscape this only
needs two simple global changes, AllShapes to Flags_AllShapes and path to
Flags_path.
I've also added the same 'Flags_' prefix to the new image files and changed
all references to file names to lowercase. The server changes the file names
to lowercase automatically, so any references to files from within other
files need to be in lowercase.
I've made those minor changes and marked it as fully compliant (3).
I hope these trials and tribulations didn't put you off. The flags you've
done are excellent.
Best Regards,
Chris B.
Subject: Re: Textured block pattern problem
Date: 4 Apr 2009 05:40:04
Message: <cfmja6-p8r.ln1@badulaque.unex.es>
> 3. Spain
> 4. Switzerland
The Spanish flag doesn't look quite right. The middle yellow stripe should
be twice as wide as the red stripes. The image looks like 1.5 times only.
The proportions of the Swiss flag's cross don't look exactly right either.
According to Wikipedia ("Flag of Switzerland") the cross's arms should be
"a sixth longer than their width", and "a relation of 2:3 or 7:10 to the
span of the flag is usual".
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 4 Apr 2009 10:56:01
Message: <49d77501@news.povray.org>
High!
They were just meant als provisional... currently I'm working on Chris
Bartlett's Flags.inc, thoroughly revising these preliminary drafts!
Yadgar
Now playing: If It Wasn't For Love (Jon Anderson)
