POV-Ray : Newsgroups : povray.binaries.images : Textured block pattern problem Server Time
29 May 2026 16:57:19 EDT (-0400)
  Textured block pattern problem (Message 35 to 44 of 44)
Subject: Re: My contribution is online now! (n/t)
Date: 28 Mar 2009 11:09:01
Message: <49ce3d8d@news.povray.org>
news:49ce2cd1$1@news.povray.org...
Now I'm confused :-)
I don't see a new version on the site and I don't see any text in your last
post ??
Chris B.
Date: 28 Mar 2009 12:52:31
Message: <49ce55cf@news.povray.org>
High!
> last post ??
Yes, (n/t) means "no text" - the headline was meant to say it all!
As I'm an absolute newbie to the Object Collection, I probably uploaded
the version under a wrong name, so that you can't find it - I simply
entered "Flags" in the "Name" line, if that may help you...
See you in Khyberspace!
Yadgar
Date: 28 Mar 2009 13:11:02
Message: <49ce5a26@news.povray.org>
>> last post ??
The name "Flags" should be right and it should have asked for a new version
number.
However, I don't see it under that or any other name. The last submission I
see was a new one from a couple of days ago.
Did you get something like the screen shot attached, confirming that the
upload had worked?
Chris B.
Download 'screenshot.jpg' (32 KB)
Preview of image 'screenshot.jpg'
Date: 28 Mar 2009 14:08:47
Message: <49ce67af$1@news.povray.org>
> submission I see was a new one from a couple of days ago.
> upload had worked?
I tried it once more, and now I got the confirming screen!
Yadgar
Date: 28 Mar 2009 14:18:42
Message: <49ce6a02$1@news.povray.org>
High!
But now another problem occurs: as I tried to compose the texture of the
Afghan flag as a layered texture consisting of a simple three-column
pattern (lower layer) and an object pattern generated from a vectorized
bitmap made with Inkscape, I got the message:
Illegal texture or patch in clip, bound or object pattern.
Here is the definition of the "AfghanFlag" macro:
#macro Flags_AfghanFlag()
    Flags_ThreeColumnFlag(0, <191, 0, 0>/255, <0, 0.6, 0>)
// Layered texture, coat of arms object-patterned texture yet to be
// added!
    texture
      pigment
         object
           object { Afghanistan_Coat_of_Arms }
           scale 0.01
           color rgbft 1
           color rgbft <1, 1, 1, 0, 0>
What went wrong? I also submitted the file Afghanistan_Coat_of_Arms.inc
containing the definition of Afghanistan_Coat_of_Arms to the Object
Collection, so you can look it up...
Yadgar
Date: 28 Mar 2009 14:55:00
Message: <web.49ce7110941a467e22390e420@news.povray.org>
POV-Ray does not allow for a textured object to be used itself in an
object-pattern. It must be "naked", so to speak.
I guess this is intended to avoid people having wrong expectations about what
the object pattern does.
BTW, instead of
>          object
>            scale 0.01
>            color rgbft 1
you can just as well write
           scale 0.01
           color rgbft 1
Date: 28 Mar 2009 15:56:37
Message: <49ce80f5$1@news.povray.org>
High!
I removed the textures from the inc file, now the render runs... but
although I defined a white pigment for the object pattern, it does not
show up at all! The only way I can tell from is the slowing down of the
render...
Yadgar
Date: 28 Mar 2009 15:59:35
Message: <49ce81a7$1@news.povray.org>
news:49ce67af$1@news.povray.org...
Congratulations :o)
Now that it's there I can see a few reasons it might have given you problems
with the upload:
When you download from the object collection it generates some files that
you don't need to upload (a readme, a little script and a copyright logo).
Basically anything that isn't prefixed with the object name you don't need
to upload.
To make it 'standards compliant' you mostly just need to prefix everything
with the object name. So I've prefixed the new include file and all the
variables contained within it. With files generated from Inkscape this only
needs two simple global changes, AllShapes to Flags_AllShapes and path to
Flags_path.
I've also added the same 'Flags_' prefix to the new image files and changed
all references to file names to lowercase. The server changes the file names
to lowercase automatically, so any references to files from within other
files need to be in lowercase.
I've made those minor changes and marked it as fully compliant (3).
I hope these trials and tribulations didn't put you off. The flags you've
done are excellent.
Best Regards,
Chris B.
Subject: Re: Textured block pattern problem
Date: 4 Apr 2009 05:40:04
Message: <cfmja6-p8r.ln1@badulaque.unex.es>
> 3. Spain
> 4. Switzerland
The Spanish flag doesn't look quite right. The middle yellow stripe should
be twice as wide as the red stripes. The image looks like 1.5 times only.
The proportions of the Swiss flag's cross don't look exactly right either.
According to Wikipedia ("Flag of Switzerland") the cross's arms should be
"a sixth longer than their width", and "a relation of 2:3 or 7:10 to the
span of the flag is usual".
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 4 Apr 2009 10:56:01
Message: <49d77501@news.povray.org>
High!
They were just meant als provisional... currently I'm working on Chris
Bartlett's Flags.inc, thoroughly revising these preliminary drafts!
Yadgar
Now playing: If It Wasn't For Love (Jon Anderson)
