POV-Ray : Newsgroups : povray.binaries.images : Textured block pattern problem Server Time
29 May 2026 19:13:07 EDT (-0400)
  Textured block pattern problem (Message 31 to 40 of 44)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: @Chris B.: SHOUT 2!!!
Date: 28 Mar 2009 05:29:12
Message: <49cdede8@news.povray.org>
High!
Meanwhile I managed to get into the submitting dialog - but the server
won't accept any ZIP files! What should I do?
See you in Khyberspace!
Yadgar
Subject: Re: @Chris B.: SHOUT!!!
Date: 28 Mar 2009 06:06:13
Message: <49cdf695@news.povray.org>
news:49cde50d$1@news.povray.org...
> High!
> Although I just registered and logged in, I can't proceed to the members
> area... I just always get the login tab!
> Yadgar
That's odd!
Once you're logged in it should change the menu along the top, so you get a
'Contribute' and a 'Members' option. It should also take you straight into
the Members Page (although it says 'Contributors Page' in the title at the
moment). This lists 4 options ('Submit a contribution','Update your
profile','Log Off','Unregister').
The login process uses Cookies, so it won't work if you have Cookies
disabled. The Contribution screen also uses JavaScript, so that won't work
if you have JavaScript disabled in your browser.  The other thing I noticed
one time was that my first login attempt didn't seem to 'take', but I
repeated the same login and it worked the second time.
I've just checked the site in both Firefox 3.0.7 and IE 7.0 on Windows Vista
and they both seems to be working ok. What are you using?
Regards
Chris B.
Subject: Re: @Chris B.: SHOUT 2!!!
Date: 28 Mar 2009 06:14:30
Message: <49cdf886@news.povray.org>
news:49cdede8@news.povray.org...
> High!
True. You'll need to upload the individual files. On the contributions
screen you hit the browse button under the files tab on the left and select
a file, repeating that for each file (I guess there'll be about 10 files).
You should see the list of files you've added build up on the screen.
Chris B.
Subject: My contribution is online now! (n/t)
Date: 28 Mar 2009 09:57:37
Message: <49ce2cd1$1@news.povray.org>
Subject: Re: My contribution is online now! (n/t)
Date: 28 Mar 2009 11:09:01
Message: <49ce3d8d@news.povray.org>
news:49ce2cd1$1@news.povray.org...
Now I'm confused :-)
I don't see a new version on the site and I don't see any text in your last
post ??
Chris B.
Date: 28 Mar 2009 12:52:31
Message: <49ce55cf@news.povray.org>
High!
> last post ??
Yes, (n/t) means "no text" - the headline was meant to say it all!
As I'm an absolute newbie to the Object Collection, I probably uploaded
the version under a wrong name, so that you can't find it - I simply
entered "Flags" in the "Name" line, if that may help you...
Yadgar
Date: 28 Mar 2009 13:11:02
Message: <49ce5a26@news.povray.org>
>> last post ??
The name "Flags" should be right and it should have asked for a new version
number.
However, I don't see it under that or any other name. The last submission I
see was a new one from a couple of days ago.
Did you get something like the screen shot attached, confirming that the
upload had worked?
Chris B.
Download 'screenshot.jpg' (32 KB)
Preview of image 'screenshot.jpg'
Date: 28 Mar 2009 14:08:47
Message: <49ce67af$1@news.povray.org>
> submission I see was a new one from a couple of days ago.
> upload had worked?
I tried it once more, and now I got the confirming screen!
Yadgar
Date: 28 Mar 2009 14:18:42
Message: <49ce6a02$1@news.povray.org>
High!
But now another problem occurs: as I tried to compose the texture of the
Afghan flag as a layered texture consisting of a simple three-column
pattern (lower layer) and an object pattern generated from a vectorized
bitmap made with Inkscape, I got the message:
Illegal texture or patch in clip, bound or object pattern.
Here is the definition of the "AfghanFlag" macro:
#macro Flags_AfghanFlag()
    Flags_ThreeColumnFlag(0, <191, 0, 0>/255, <0, 0.6, 0>)
// Layered texture, coat of arms object-patterned texture yet to be
// added!
    texture
      pigment
         object
           object { Afghanistan_Coat_of_Arms }
           scale 0.01
           color rgbft 1
           color rgbft <1, 1, 1, 0, 0>
What went wrong? I also submitted the file Afghanistan_Coat_of_Arms.inc
containing the definition of Afghanistan_Coat_of_Arms to the Object
Collection, so you can look it up...
Yadgar
Date: 28 Mar 2009 14:55:00
Message: <web.49ce7110941a467e22390e420@news.povray.org>
POV-Ray does not allow for a textured object to be used itself in an
object-pattern. It must be "naked", so to speak.
I guess this is intended to avoid people having wrong expectations about what
the object pattern does.
BTW, instead of
>          object
>            scale 0.01
>            color rgbft 1
you can just as well write
           scale 0.01
           color rgbft 1
