POV-Ray : Newsgroups : povray.binaries.images : Re: Moss Vine test [~30k] Server Time
29 May 2026 18:05:55 EDT (-0400)
  Re: Moss Vine test [~30k] (Message 9 to 18 of 28)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Moss Vine test [~30k]
Date: 11 Mar 2009 00:53:32
Message: <49b743cc$1@news.povray.org>
"Mike Hough" <nos### [at] nospamcom> wrote in message
news:49b5b242$1@news.povray.org...
>> I am sure that even a single triangle would work, but I've never used
>> them, ever, so am profoundly lost...more stuff that I need to learn. :-p
> You could make a simple leaf in any modelling software and convert it to a
> POV-Ray mesh. As long as you pay attention to the dimensions it should not
> be hard to incorporate into your macro. If you offered up some dimensions
> I bet someone here would do it for you.
I've tried playing in wings3D...but I can't find CSGs..
hI'll probably just model it in Bryce or Truespace, then export DXF. That
can be converted to POV, right?
ian
Date: 11 Mar 2009 02:26:05
Message: <49b7597d$1@news.povray.org>
Poseray can import DXF. You might need to smooth the mesh after you import.
I think that poseray will also include comments with the dimensions of the
object in the exported file.
Date: 11 Mar 2009 05:30:00
Message: <web.49b783c2d4fd5b286dd25f0b0@news.povray.org>
"[GDS|Entropy]" <gds### [at] hotmailcom> wrote:
> They seem tedious more than difficult....I hate tedium.
It's no different from looping to place compound objects; you write macros to do
the work for you. To be sure, it requires a bit of concentration to get to the
first stage, but once you've got something that renders it's just tweaking. It
can be helpful to draw diagrams to aid with the visualisation.
Use plain mesh (i.e., just triangle statements) - it's much easier than mesh2.
(To be honest, mesh2 is mainly a handy conversion format for speeding up
parsing, you only need to use it if you're generating 10000s of triangles.
They're both the same thing once parsing is complete).
> I'll take a look at that there, and given that those are blades of grass,
> its probably not too far off from what I want to do with moss leaves anyway,
> I'd just need to grab one blade.
I've been trying to write a decent plant include file for a while now. I've got
a leaf macro that builds different shaped leaves procedurally, and I'm slowly
adding types of plants to use it. It's a long-term work in progress, but I've
got grass and dandelions so far. No ivy leaves yet, though. I can post the leaf
macro later if you're interested...?
> Suprisingly, its not the vine routes that takes the time, its tracing the
> moss onto the individual vine components.
Write random locations on the vine routes to a data file as you go, then read
them back in when you place the moss? Or the same thing, but using an array?
Every time you make a vine section, #if rand(seed) < probability then store the
current endpoint, or something.
There's more than one way to skin a cat, I'm sure you've got it in hand... :)
Bill
Date: 11 Mar 2009 08:03:23
Message: <49b7a88b$1@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:web.49b783c2d4fd5b286dd25f0b0@news.povray.org...
> to do
> the
> tweaking. It
> mesh2.
I'll definately give that a try once I get most of these macros to public
beta. :-)
> I've got
> slowly
> I've
> leaf
Of course, and if the macro parameters are expected to be stable, I could
make my macro implement yours, if that is cool.
> read
> array?
> store the
I've been using arrays, and in fact most of the macros I've been writing
recently implement component macros that I wrote for the snow macro.
It turns out that to reduce the parse time for this particular use, all I
had to was change a single line. I now have to perform only 5000 tests to
get the ~same number of placed objects as previously required 500k. This has
resulted in a much lower threshold  for catastrophically crashing povray due
to lack of available memory.
I doubt that I can get around the out of memory error by writing to a file.
Unless povray can read/write a part of a file without loading the whole
thing, or unless somehow a file would take less memory for the same amount
of data than would an array, I don't see any way around this problem in its
entirety.
Granted, using a mesh would free up a LOT of spaces used by the moss array,
as each moss frond takes 260 at current settings. Multiply that by the
amount of tests per vine sub-object...
I think that would go a long way to increasing the ceiling that I'm hitting.
I think I might need to determine the average amount of ram used per
"mossed" vine object, so that I can allow a user to input their total
available ram (for 32 bit systems this will always be 2gb), which would not
let the macro run so far as to give people those blood boiling OOM errors.
Here is the result of the one line change, in image and stats. Compare that
to the previous one posted...big improvement.
ian
Scene Statistics
  Finite objects:      1013230
  Infinite objects:          0
  Light sources:             1
  Total:               1013231
Possible Rendering Error: Maximum trace level reached! If your scene
contains black spots read more about the max_trace_level setting in the
documentation!
Render Statistics
Image Resolution 1280 x 1024
Pixels:          1312000   Samples:         1502912   Smpls/Pxl: 1.15
Rays:            2047633   Saved:                 0   Max Level: 5/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder               1189022659        11408002      0.96
CSG Intersection              45321691         2913618      6.43
CSG Union                   1087005314          669132      0.06
Sphere                      2168288631          860782      0.04
Bounding Box                 396224017       110147439     27.80
Light Buffer                 672753438       349217503     51.91
Vista Buffer                 144135167       115783532     80.33
Calls to Noise:                   0   Calls to DNoise:         1345012
Shadow Ray Tests:           2359688   Succeeded:                952498
Transmitted Rays:            544721
I-Stack overflows:            28578
Smallest Alloc:                  18 bytes
Largest  Alloc:             8105856 bytes
Peak memory used:        1414575125 bytes
Total Scene Processing Times
  Parse Time:    0 hours 12 minutes 34 seconds (754 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Cloth Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Mechsim Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  1 minutes  7 seconds (67 seconds)
  Postpr. Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours 13 minutes 41 seconds (821 seconds)
CPU time used: kernel 15.09 seconds, user 794.44 seconds, total 809.53
seconds
Render averaged 1619.11 PPS over 1310720 pixels
POV-Ray finished
Download 'VineTest1_2_1.jpg' (13 KB)
Preview of image 'VineTest1_2_1.jpg'
Date: 11 Mar 2009 08:30:01
Message: <web.49b7addbd4fd5b286dd25f0b0@news.povray.org>
Could do, but I may change it considerably yet; that's why I've not posted it
anywhere. You could always just plunder my code to make your own leaf, which is
what I was getting at ;-)
> entirety.
Your memory usage is still heinous. There's no way you should need to use more
than a fraction of that for this sort of thing.
I don't understand where all your data is coming from. Surely all you need to
store in an array is a position and maybe a normal for each moss object? There
can't be more than 10,000 visible 'mosses' in that image.
Why aren't you #declaring a moss frond, storing position data (i.e. vectors)
in the array, then instancing the #declared frond? Your image simply does not
have enough complexity to account for that memory usage.
Whenever I've done something like this in the past, I've racked up some severe
parsing times, but rarely more than a few 10s of MB of peak RAM.
*clunk*
*wires jaw back on*
Bill
Date: 11 Mar 2009 09:10:00
Message: <web.49b7b7d6d4fd5b286dd25f0b0@news.povray.org>
Sorry, please disregard my disbelief, I've got so accustomed to using meshes for
this that I forget just how much memory normal objects take up. On reflection,
it doesn't seem so silly.
So:
The reason you're running out of memory is that every instance you use takes up
the same memory as the original, so there's no advantage to instancing. Meshes,
however, are stored just once. All mesh instances are actually just transforms,
so they take up a minute amount of space. I guarantee that if you use meshes
for your fronds, even quite complex ones, you will save over 95% of the memory
you're currently using!
You can even go further and use them for the ivy creepers, although that's
probably not so serious.
Date: 11 Mar 2009 13:30:21
Message: <49b7f52d@news.povray.org>
news:web.49b7b7d6d4fd5b286dd25f0b0@news.povray.org...
>> more
> meshes for
> reflection,
> So:
> takes up
> Meshes,
> transforms,
> meshes
> memory
Check this out (apologies for the horrific texture):
I exported this from Bryce and converted with poseray.
Scene Statistics
  Finite objects:       145243
  Infinite objects:          0
  Light sources:             1
  Total:                145244
documentation!
Render Statistics
Pixels:          1312000   Samples:         2094440   Smpls/Pxl: 1.60
Rays:            2176126   Saved:                 0   Max Level: 5/5
Cone/Cylinder               1088334589         1326340      0.12
Mesh                          67373038         2668035      3.96
Sphere                      2167394361          366116      0.02
Bounding Box                 869147567       316790036     36.45
Light Buffer                 449711964       194011242     43.14
Vista Buffer                 465015215       340904239     73.31
Calls to Noise:                   0   Calls to DNoise:         1114198
Shadow Ray Tests:           1505186   Succeeded:                494705
Transmitted Rays:             81686
Largest  Alloc:             1161960 bytes
Peak memory used:         158859969 bytes
  Parse Time:    0 hours 11 minutes 53 seconds (713 seconds)
  Render Time:   0 hours  1 minutes 43 seconds (103 seconds)
  Total Time:    0 hours 13 minutes 36 seconds (816 seconds)
CPU time used: kernel 20.84 seconds, user 780.28 seconds, total 801.13
seconds
Render averaged 1636.10 PPS over 1310720 pixels
POV-Ray finished
Download 'VineTest1_2_2.jpg' (33 KB)
Preview of image 'VineTest1_2_2.jpg'
Date: 11 Mar 2009 16:00:00
Message: <web.49b8176ad4fd5b28f50167bc0@news.povray.org>
I dunno, I kind of like this texture--looks like tiny crystals forming (or
whatever the word is) out of a liquid solution.
KW
Date: 11 Mar 2009 17:03:50
Message: <49b82736$1@news.povray.org>
Well, to clairify, the only thing I exported from bryce was the plant, which
I then retextured in Poseray.
ian
"Kenneth" <kdw### [at] earthlinknet> wrote in message
news:web.49b8176ad4fd5b28f50167bc0@news.povray.org...
> KW
Date: 11 Mar 2009 17:43:59
Message: <49b8309f@news.povray.org>
Ok, a little better here. Well...at least a bit closer to what I'm shooting
for. It is clear that I will need to add another inside() test for whatever
object is being grown upon, as you can see here some of these clumps are
partially within the column.
I think I need to add the capability to not create hidden objects. There are
two ways which come to mind, the first of which being to detect all vectors
on the target object which are hidden and exclude them from the generation
of random vectors in that macro. This seems like it might be the most
efficient way method. The second of which would be to perform the test
within the object placement macro.
I'm not sure which would give the best results, so I guess I'll need to
implement both and see what happens.
I think the macro that clipka posted in response to my hidden glow problem
will do the trick nicely.
Any thoughts?
ian
Download 'VineTest1_2_3.jpg' (16 KB)
Preview of image 'VineTest1_2_3.jpg'
