POV-Ray : Newsgroups : povray.binaries.images : Re: Moss Vine test [~30k] Server Time
29 May 2026 16:56:31 EDT (-0400)
  Re: Moss Vine test [~30k] (Message 19 to 28 of 28)
Subject: Re: Moss Vine test [~30k]
Date: 11 Mar 2009 17:50:00
Message: <web.49b830ded4fd5b28219167190@news.povray.org>
Here's my leaf macro as it stands:
http://www.infradead.org/~wmp/leaf.inc
It's more comprehensive than I remember - all the leaf types apart from stalks
and grassblades have uv vectors (u along the length of the leaf, v from the
centre to the edges), so uv_mapped textures will work with them. Also, the
macro only produces triangles - it has to be called from inside a mesh block -
this means you can have as many leaves as you want in a single mesh.
Enjoy!
Bill
Date: 11 Mar 2009 19:40:00
Message: <web.49b84af5d4fd5b28801985dd0@news.povray.org>
"[GDS|Entropy]" <gds### [at] hotmailcom> wrote:
>   Finite objects:      1013230
> Peak memory used:        1414575125 bytes
I reckon your memory issues are not *per se* due to using a bucketload of CSG
instead of a few meshes.
I just did a quick test with 10k spheres, with a color-mapped pigment; the
following might give you some hints how to improve performance:
- With all spheres being generated on-the-fly as scene-level objects, I get a
peak mem of ~8 MB.
- If I #declare the material first, and use that in my spheres "as is" (no
translations, rotations or any modifications), peak mem reduces to ~6.5 MB.
- If I place the spheres in a union and attach the material only to the union,
peak mem reduces to ~3.6 MB.
- If I #declare the sphere first, and use translated copies, peak mem goes *UP*
again to ~6.4 MB!
- Worst thing I got so far was #declare the sphere first with a material, and
use translated copies, giving me ~12 MB!
Another thing I found was that first generating an array with object locations,
and then creating the objects in a separate pass, is more costly than creating
an array of objects right away.
Still, here's the best advice:
- If instead of generating 10000 spheres I #declare a mesh of 100 triangles,
then generate a union of 100 translated copies of it, I get a peak mem of lousy
~360 kB, which is just ~170 kB over my "baseline" peak mem. Even with 1000
copies, I still need just ~1.4 MB peak.
Given that you'll possibly need only one triangle per leaf to replace a pair of
cones (unless you want to do extreme close-ups - note that you can still
simulate curvature using a smooth triangle), this should be a good enough model
to give you a rough estimate of how much memory you can save.
Date: 11 Mar 2009 20:30:00
Message: <web.49b85743d4fd5b28801985dd0@news.povray.org>
> The reason you're running out of memory is that every instance you use takes up
> the same memory as the original, so there's no advantage to instancing. Meshes,
> however, are stored just once. All mesh instances are actually just transforms,
> so they take up a minute amount of space.
To get a bit more into depth about what's going on:
There is a certain general per-object memory overhead that pertains to *all*
objects, whether it is a primitive, a CSG union, or even just a copy of a
#declared object.
With most primitives, this overhead greatly outweighs the actual memory
requirements for the pure geometry data; from the tests I did I'd expect
something like a 10:1 overhead for "bare metal" objects, i.e. with nothing but
the geometry data specified.
With meshes, this overhead can be arbitrarily low: If you have just a single
triangle, it will probably be in the 10:1 area, too. If you have ten triangles,
it will be more like 10:10. If you have 1k triangles, it will be something like
10:1k. And so on.
Now this alone wouldn't make meshes much of a memory-saver, as normally an
object will have to have many more triangles than a CSG representation of the
same shape.
However, as mentioned before, the overhead also pertains to copies of #declared
objects, while the geometry data of *some* primitives is *not* copied, and
instead just references the original's data, so costs *no* extra memory at all.
So e.g. 100 copies of a 1k-triangle mesh will have 100x the standard overhead,
but only 1x the triangle data costs.
The best known of these "bulk" objects is mesh (and its alter ego, mesh2).
Others are blob, height_field, lathe, polygon and prism.
The most important thing to know is that CSG unions (and merges and differences)
are *not* among these. If you copy a union comprised of 1000 primitives, you'll
not only pay the general object overhead, but also the costs for a copy of each
of the 1000 elements.
Date: 11 Mar 2009 20:45:00
Message: <web.49b85ac8d4fd5b28801985dd0@news.povray.org>
> Check this out (apologies for the horrific texture):
> I exported this from Bryce and converted with poseray.
>   Finite objects:       145243
> Peak memory used:         158859969 bytes
See? Roughly same number of primitives, yet they cover a much greater portion of
the object, and even cost less per object.
Date: 12 Mar 2009 05:40:04
Message: <49b8d874@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.49b84af5d4fd5b28801985dd0@news.povray.org...
> CSG
> get a
> peak mem of ~8 MB.
> MB.
> union,
> *UP*
> again to ~6.4 MB!
> and
> locations,
> creating
> triangles,
> lousy
> pair of
> model
Those are very interesting results, not all expected. Apparently, good
programming concepts are not always good POV concepts... Unfortunately there
appears to be a performance penalty for writing things extensibly using
certian methods. :-(
At least this gives a clearer picture of how in any given circumstance to
optimize for both reusability and efficient memory usage.
Do you (or anyone) have any ideas on how to perform an efficient inside()
test on not just a single point, but an entire object? You can see the issue
in my last image post, where even with an inside() test, the actual leaf
objects occur partially within the cyl at certian points, even when the
vector/normal reorient may not occur within the cyl.
At first glance it looks like a loop covering an array of vectors within
min/max extent of whatever object A you are trying to determine may or may
not occur within another object B is the only option (and then ditch
creating the object at the vector which would produce such a coincident
result), but that seems awfully crude. :-\
thanks!
ian
Date: 12 Mar 2009 05:42:48
Message: <49b8d918@news.povray.org>
"[GDS|Entropy]" <gds### [at] hotmailcom> wrote in message
Addendum: I have been using things of the format:
  #if (((vectorArray[i].x <= vectorB.x) & (vectorArray[i].x >= vectorA.x)) &
((vectorArray[i].y <= vectorB.y) & (vectorArray[i].y >= vectorA.y)) &
((vectorArray[i].z <= vectorB.z) & (vectorArray[i].z >= vectorA.z)))  etc...
Where vector A and B are min/max extents of object being tested
against...I'm just not sure that this is the best way...
ian
Date: 12 Mar 2009 11:20:00
Message: <web.49b92730d4fd5b28f708085d0@news.povray.org>
As a matter of fact, I'd partially blame it on POV. With a few changes to
interior design, I guess it should be possible to copy CSG objects, too,
without copying each and every of its components.
At the moment however, it seems to me that the design of the bounding box
mechanism prohibits this (requiring a dedicated bounding box per primitive, and
each box in turn referencing a dedicated primitive object), so changes would
have to be made there.
If I understand you correctly, you'd loop in 3D.
Here's a way to reduce this to 2D at least:
Loop over (or pick random points on) a sphere surface big enough to contain all
of your object A. (make sure you get a roughly homogenous distribution, and
don't waste too much time near the poles)
trace() a ray from each point to the object's bounding box center.
If you get an intersection point, test whether it is inside the other object B.
Repeat until you're confident that you've covered enough of object A's surface.
Note that this way you may miss surface areas in hollows; however, if the other
object is "convex enough", this should not be a problem. It will be a real
issue only if both objects have significant hollows.
Another approach - which should be able to cope with arbitrary hollows - would
be to actually test whether intersection{A B} contains anything. Note however
that this will again create another object. (Mental note for myself: Test
whether #undef frees the memory occupied by the assigned object.)
If you want to place a bucketload of identical objects, you may want to use the
former approach, but shoot the rays at the "unplaced" object and store them in
an array. When you then try to place a copy, you loop through the array,
transform the points according to the intended placement, and do the inside
test for each transformed point. You'd then add the transformed object only if
you're confident that it doesn't intersect. This spares you both a lot of
trace() invocations and some unnecessary instantiating of objects that turn out
to intersect.
Date: 13 Mar 2009 08:37:35
Message: <49ba538f@news.povray.org>
news:web.49b92730d4fd5b28f708085d0@news.povray.org...
Yup, and those interior design changes would be really nice. I haven't any
idea how difficult that would be to code, because I've never tried to write
a raytracer before, but I'm guessing that since no patches fix this, and
that this has persisted across pov versions...that it ain't so easy. ;-)
> primitive, and
> would
Maybe in POV 4 then. :-)
That is what I was thinking.
> contain all
> and
Thats still 3d though right?
Ok, so a macro fills an array once with random positions on a sphere, then
uses that array in a looped call to trace.
I thought trace() accepted only a point and an object? It can accept two
points?
> object B.
I'm a little fuzzy here...
Assuming I had you right in my sentence above, what result from that trace
would go within the #if block that would initiate the call to
inside(myPoint,objectB)?
> surface.
> other
It is likely that in real world use hollows are to be expected. I'm trying
to write this macro suite for use in any scene.
> would
> however
So I would take the sphere position trace data and test that against the
points in an intersection of every object A (the leaf for instance) with
object B (column)?
Oh man...this is starting to sound like people won't be able to use these
macros unless they have a spare Cray XT4 laying around... O_O
> use the
> them in
> inside
> only if
> turn out
> to intersect.
A bucket load of objects is to be expected.
Ok, so I perform the spherical trace/intersection test once, then
reorient_trans() the object, test inside() against object B?
Gah! I hate word problems! ;-D
You watch...just as soon as I get all comfortable with SDL v3.7 (or v4) will
drop and I'll have to relearn everything. lol!
ian
Date: 13 Mar 2009 11:05:00
Message: <web.49ba7553d4fd5b286dd25f0b0@news.povray.org>
Or you could just do it on the fly.
> points?
Trace takes an object id, a start point, a direction, and (optionally) a
previously-#declared vector in which it stores the surface normal at the point
found.
> > object B.
The aforementioned normal vector is set to <0,0,0> if the trace fails to hit
anything. Test the length of this vector using vlength().
Bill
Date: 14 Mar 2009 13:30:00
Message: <web.49bbe938d4fd5b284c2c4c080@news.povray.org>
> > contain all
> > and
Yeah, what I meant was that I only have to loop over 2 variables (latitude and
longitude instead of 3 (X, Y and Z).
> points?
Um... sorry if I confused you. To be precise, I should have written "trace() a
ray from each point in the direction of the center" - whatever direction that
is for the particular point. It's easy to compute that direction from the point
P and the center C as (C-P).
> > object B.
You mean how to test whether trace() did find an intersection at all? Pass an
(initialized!) normal vector variable to the macro, and afterwards check
whether it is non-zero (i.e. check for vlength(myNormal) > 0).
> > surface.
> > other
Sure, it's a trade-off between speed and quality. But in situations like your
vine macro, chances are the "entangled" object's walls are much thicker than a
leaf's total size, so this should be a non-issue for most cases, and in any
case better than not testing at all (and faster than an exhaustive test).
> > would
> > however
> object B (column)?
For POV, generating an intersection object isn't really such a big deal. The
only *possible* issue is that it requires memory that *might* not be freed when
no longer needed - I didn't test yet.
After all, behind the scenes, POV just basically creates a CSG container object
with references to the elements, and only performs any calculations on it when
trace() is called (or the object is rendered on the screen). And as it happens,
for CSG intersections POV actually uses an algorithm very similar to the one I
outlined before: It simply computes the itersections of the ray with each
component object, tests which of these are inside all other components, and
ultimately picks the closest of all these.
In a way, POV never really creates the intersection object - it just performs a
smart combination of ray-intersection- and inside-tests for all the primitives
involved.
Well, almost but not quite, so let's try get this more precise:
- You perform the spherical trace/intersection test once for object A (the one
you intend to place copies of)
- For each candidate placement...
-- you compute the transform { reorient_trans(...) translate ... } you intend to
use for the placement
-- you inside()-test the respective vtransform() of the points against object B
(the one near to which you intend to place the object A copies)
-- if you find that none of them is inside, you do the actual placement using
the transform {...} of the object to be placed.
Hopefully that one will be easier then ;)
