POV-Ray : Newsgroups : povray.binaries.images : Eva Sails Away (again) Server Time
23 Apr 2026 09:02:14 EDT (-0400)
  Eva Sails Away (again) (Message 21 to 24 of 24)
Subject: Re: Eva Sails Away (again)
Date: 11 Mar 2009 14:34:02
Message: <49b8041a$1@news.povray.org>
Alain wrote:
> Thomas de Groot nous illumina en ce 2009-03-09 05:48 -->
>> Really improving indeed. Very nice view.
>> The waves, like others already said, need more thought. Are they
>> coming from the sea (at right)? Then they should curve the other way
>> round due to the interference with the shallowing sea bottom which
>> slows them down. They are obviously not the wake of the ship as they
>> are also present in front of it. A slight wake (45 degrees) should be
>> nice to add in that respect.
>> Thomas
> The 45 degree angle is the angle for a precise speed, twice the speed of
> the waves in the water for a given depth. The wake angle depend on the
> speed of the ship trough the water and the depth.
> Here, it's like there is something like a water fall somewhere to the
> left. In that case, there should be some foam on the water.
Waterfall? I wanna make someday one of those, but probably not in this
particular image.. Still, like you said, I guess it could explain those
waves.
-- Arttu "Blizzara" Voutilainen
-- http://blizzara.zbxt.net:8000/Plone/
Date: 11 Mar 2009 14:41:26
Message: <49b805d6$1@news.povray.org>
Paolo Gibellini wrote:
> The scene is peacefully, beautiful.
Thanks!
> Regarding the waves, we don't see what if you have imagined at the left
> (a shore? the mouth of a river?), they are a bit unusual but I like them.
Well, to be honest, I have no idea myself what could have caused them. I
just liked them that way, too, and decided to render the image anyways
to see all the things I should fix.
> Tee boat (as Warp notes) compared with the overall scene (trees, water,
> ...) needs perhaps some details.
Yep. It shall be done.
Btw, what do you people think about the trees? Do they look good enough?
> Paolo
>>Arttu Voutilainen  on date 07/03/2009 20:02 wrote:
>> I think this one is starting to look pretty good. Since last version
>> I've changed the texture on the trees, fixed the problem I had with
>> media and turned water-plane into an isosurface.
>> Took 25h 30min to render with pov3.7-b29 on AMD64 3500+.
>> So, any comments, critiques, anything?
Date: 12 Mar 2009 14:55:35
Message: <49b95aa7$1@news.povray.org>
Arttu Voutilainen nous illumina en ce 2009-03-11 14:41 -->
> Thanks!
>> Paolo
You use a waves pattern. That pattern is circular.
What you need to do to make it more straigh: translate it more to the left by a
large amount, like 1000 to 10000. You can also scale in unevenly: scale<1,1,500>
to make them almost parallel to the z axis, then rotate it somewhat to orient
the waves as you like.
You know you've been raytracing too long when you hate games, but you buy Riven
just to look at the pictures.
AmaltheaJ5
Date: 18 Mar 2009 07:44:36
Message: <49c0dea4$1@news.povray.org>
IMHO in this sunset mood the trees are very realistic. Especially the
far trees.
Paolo
