POV-Ray : Newsgroups : povray.binaries.images : My CNC router design Server Time
23 Apr 2026 07:13:03 EDT (-0400)
  My CNC router design (Message 11 to 15 of 15)
Subject: Re: My CNC router design
Date: 8 Mar 2009 07:30:00
Message: <web.49b3aba14b56cbe3a745f7570@news.povray.org>
"Rarius" <rar### [at] rariuscouk> wrote:
> Here is a plain text post with a updated image of my CNC design.
> Rarius
Hey, someone stole the drilling tool!
Attachment worked fine this time, thanks.
Date: 8 Mar 2009 07:40:00
Message: <web.49b3adf34b56cbe3f50167bc0@news.povray.org>
> The drive spindles are 12mm trapezoidal with a 3mm pitch
> running in bronze nuts. The rails are 12mm, 16mm and 20mm ground shafts
> running through linear bearings.
Some nice components! Especially the linear bearings with the recirculating
balls. I'm not familiar with 'trapezoidal' threads; from the photo at the
website, they look kind of like 'Acme' threads here in the 'States.
> I bought a job lot from eBay. It included four spindles, three pairs of
You lucky guy!! I'm jealous.
Ken W.
Date: 8 Mar 2009 12:49:26
Message: <49b3f716$1@news.povray.org>
Rarius wrote:
> I think the problem of "racking" on the X axis is more of a worry. Although
> not shown on the image I have decided to add a cable system like that used
> on large draftsmans drawing boards to stop any rotational movement as the
> carriage moves backwards and forwards along the X axis.
> Rarius
Yeah, that could be an issue. Since you've got two sliding rails and a
third driving rail, your system is kinematically over constrained, so
any racking between the two sides would put a lot more frictional load
on the drive motor, possibly causing harm. This can be helped by doing
what you said with extra cables, or another workaround is using thinner
bearings spaced farther apart, instead of a single long sleeve bearing.
That way any rotation can move the individual bearing races a little bit
out of alignment, instead of putting a huge torque side load on each end
of a long bearing.
How are you keeping z vertical? If x is the first motor, I'm slightly
worried about it bending around y, especially if you have a large load
on the cutter - it could bend against the long thin rails.
Another thing - the timing belt pulleys on the z axis aren't centered on
the threaded rods?
-cshake
Date: 8 Mar 2009 15:53:43
Message: <49b42247$1@news.povray.org>
"CShake" <cshake+pov### [at] gmailcom> wrote in message
news:49b3f716$1@news.povray.org...
>> Although not shown on the image I have decided to add a cable system like
>> that used on large draftsmans drawing boards to stop any rotational
>> movement as the carriage moves backwards and forwards along the X axis.
>> Rarius
> third driving rail, your system is kinematically over constrained, so any
> racking between the two sides would put a lot more frictional load on the
> drive motor, possibly causing harm. This can be helped by doing what you
> said with extra cables, or another workaround is using thinner bearings
> spaced farther apart, instead of a single long sleeve bearing. That way
> any rotation can move the individual bearing races a little bit out of
> alignment, instead of putting a huge torque side load on each end of a
> long bearing.
I would have liked to move the X bearings further apart, but that quickly
starts to eat into the available work area. If I had been buying the rails
new I would have bought much longer ones, but as I bought them second hand I
am stuck with what I have.
> worried about it bending around y, especially if you have a large load on
Just to clarify: In my design, the X and Y  lie in the horizontal plane. X
is the front/back axis, with the motor on the far right. Y is the side to
side axis and Z is the up/down axis.
The Z axis is held vertical by the two vertical  rods that drop through two
pairs of linear bearings. I agree that three would be better but I'll see if
the two can cope. I can always rebuild later.  It is lifted by the two
vertical spindles that are both driven by the stepper motor.
The sideways force on the router bit should be reasonably small as I will be
using small bits and low feedrates.
> the threaded rods?
Thanks for pointing that out. A typo crept into the script during an edit
lat last night! Fixed now.
Rarius
Date: 9 Mar 2009 22:40:12
Message: <49b5d30c@news.povray.org>
Cousin Ricky nous illumina en ce 2009-03-08 00:24 -->
> I love large corporations that practice what they preach.  Good thing
> that Web browsers are maintaining, uh... (subtracts in head), 19 years
> of backwards compatibility, and keep tabs on each other so that, say,
> Opera knows how MSHTML formats its attachments.  Alas, povray.org's
> software doesn't.  (Just continue using plain text and avoid the whole
> mess.)
MSHTML makes me think of MicroSoftHTML, or a microsoft propriatary extention
over the HTML specification.
Well, not even compatible with IE7 here...
If you're ever about to be mugged by a couple of clowns, don't hesitate - go for
the juggler.
