POV-Ray : Newsgroups : povray.binaries.images : On the streets... Server Time
23 Apr 2026 07:12:47 EDT (-0400)
  On the streets... (Message 11 to 15 of 15)
Subject: Re: On the streets...
Date: 8 Mar 2009 08:56:32
Message: <49b3c080@news.povray.org>
"[GDS|Entropy]" <gds### [at] hotmailcom> schreef in bericht
news:49afdb91$1@news.povray.org...
> This looks to be going somewhere cool, I like the hellhound look of the
> wolves too. :-D
Thanks! Yes, the initial idea comes out quite well I believe. A bit more
work and I shall be satisfied. It does not have to be perfect. I am always
more interested in working out a concept than in perfecting real world
looks.
I like the wolves too! The glint in the eyes does a lot although it was
rather difficult to get it about right.
Date: 8 Mar 2009 11:47:11
Message: <49b3e87f$1@news.povray.org>
message de news: 49b3bc44@news.povray.org...
> "Slime" <fak### [at] emailaddress> schreef in bericht
> news:49b0c7fc$1@news.povray.org...
>>> - The scene is too dark.
>> Definitely the biggest issue. Working with media/light interaction in
>> POV-Ray can be slow, so I suggest you forget it for now and work on your
>> lighting. Once it looks cool without fog, you can consider adding some
>> in. Illuminate the objects of interest and get some contrast in there.
> No. I am sorry. I am about 99% certain that the gamma's are correct and I
> can clearly see everything (no ambient used of course) and as far as I can
> see the contrast between light and dark is about right.
> Thomas
I can clearly see everything too, my contrast and brightness are properly
set and my monitor gamma is 1.8 .
Of course the image is rather dark but that's what I would expect expect for
a night scene...
I agree anyway that the light bulbs should look brighter IMHO.
Xavier
Date: 8 Mar 2009 13:05:00
Message: <web.49b3f9fcdf6b06f2a745f7570@news.povray.org>
As a matter of fact, your shot *is* problematic on poorly calibrated displays,
or monitors calibrated for different viewing conditions (e.g. if someone
calibrated his display for dim artificial illumination, they'll have trouble
seeing your picture with bright daylight shining into their room).
On my primary display and under my standard viewing conditions, The shot turns
out fine, e.g. I can make out the structure of the buildings and such (which
supports your claim, as I am quite sure that the display is rather well
calibrated, too); on my secondary display, however, I cannot. (So far it has
defeated any attempts to calibrate it properly, so I make the best of it and
use it to assess how my shots look like to viewers who don't bother about
calibration.)
Just in case this shot should happen to be a WIP for some kind of competition
(*wink*), you might want to take such issues into account. It *may* be better
to have the shot a bit too bright than a bit too dark.
Date: 9 Mar 2009 05:33:39
Message: <49b4e273$1@news.povray.org>
"clipka" <nomail@nomail> schreef in bericht
news:web.49b3f9fcdf6b06f2a745f7570@news.povray.org...
> displays,
> trouble
> turns
> (which
> has
> and
> calibration.)
> competition
> better
No, This is not intended for the competition you are thinking of :-) It is
an independant work. I feel that it is not entirely covered by the topic and
I like to work in different directions at the same time.
I am aware indeed of the problems with displays you refer to above, however,
for this particular night scene (and night scenes are always difficult) I
strongly feel against brightening it up as that would destroy the overall
ambience I am trying to show.That is why I opted for more restricted
spotlights instead of the global lights you would expect in regular street
lamps. The effect was certainly more correct, but it did not really suit my
concept of the scene.
Date: 9 Mar 2009 05:37:43
Message: <49b4e367@news.povray.org>
"Xavier Manget" <NOS### [at] NOSPAMfreefr> schreef in bericht
news:49b3e87f$1@news.povray.org...
> for a night scene...
Clipka explains the problem well, below. The darkness of the scene on the
other hand is intended of course. Not everything should be seen clearly.
Correct. I did feel also that the bulbs could use a boost, and even a glow,
now that I think about it.
