POV-Ray : Newsgroups : povray.binaries.images : just messin around. [200k] Server Time
18 Aug 2025 08:00:00 EDT (-0400)
  just messin around. [200k] (Message 1 to 6 of 6)
Subject: just messin around. [200k]
Date: 27 Feb 2009 02:05:50
Message: <49a790ce@news.povray.org>
I just felt like rendering something different to test one of my media
clouds.
The water is a modification of Christoph Hormanns, the image idea and
sky_sphere colormap came from Mike Kost here:
http://povray.tashcorp.net/tutorials/qd_realskysphere/
I would have used radiosity, but I didn't feel like waiting that long. Yeah,
I probably should have used heteroMF instead of rigedMF, but whatever, it
still doesn't look too bad for a scene only meant to test clouds.
ian
Download 'landscape_2_.gif' (169 KB)
Preview of image 'landscape_2_.gif'
Subject: Re: just messin around. [200k]
Date: 27 Feb 2009 03:23:07
Message: <49a7a2eb$1@news.povray.org>
"[GDS|Entropy]" <gds### [at] hotmailcom> schreef in bericht
news:49a790ce@news.povray.org...
>clouds.
> Yeah, I probably should have used heteroMF instead of rigedMF, but
> whatever, it still doesn't look too bad for a scene only meant to test
> clouds.
He he... you test clouds, but the water dominates the image.... :-)
That said, I think the clouds look very good.
The water... hm, hm... I am not a particular fan of this one. At least, I
think you should scale up one dimension (x or z) and a bit od rotation
around y to give a better idea of wave trains.
Date: 27 Feb 2009 04:08:07
Message: <49a7ad77$1@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:49a7a2eb$1@news.povray.org...
Yeah, I was kinda going for a replication of the sky_sphere test scene that
I linked to, with a little artistic licence.
Why thank you. :)
Those are some of the oldskool plane clouds turned media that I posted a
while back.
Just a little more work on them, and I'll have them where I want them and
usable for almost any type of scene. I'm also on home stretch with the
snow/icicle macro I've been working on. I'd like to eventually build a kind
of framework of weather/landscape macros, with maybe some grass, rain, water
and rocks thrown in the mix.
Speaking of such, have you experimented with your moss texture and the
(deprecated now) snowmacro core? I think that could be very cool.
Nor am I, its just not right. Circular waves? Not good. I think heteroMF
might work better. I'll work on that aspect of things once I get this
snowmacro done, at least enough for a beta release.
ian
Date: 27 Feb 2009 10:12:44
Message: <49a802ec@news.povray.org>
news:49a7ad77$1@news.povray.org...
To tell the truth, I have a problem of how to declare the VectorArray, and
was stuck there. Other things came in the way then.
I just tested Gilles Tran's MakeSnow macro with my moss texture and got this
result. Not entirely convincing, but I only used a single layer of moss. I
think that with your macro something similar would be obtained.
Download 'makesnow_test.jpg' (154 KB)
Preview of image 'makesnow_test.jpg'
Date: 27 Feb 2009 12:51:47
Message: <49a82833$1@news.povray.org>
news:49a802ec@news.povray.org...
The vectorarray is just an array of random vectors. Just make sure that its
size is the same as the ctr variable in the snowtest.
Here is a macro which will do the job nicely, as it is based upon the
bounding box:
#local RsA = seed(3141592654);
//      RRand Macro by Chris Huff
#macro RRand(RS, Min, Max)
 (rand(RS)*(Max-Min) + Min)
//      randVectorMM2 Macro by [GDS|Entropy]
#macro randVectorMM2(Array,ctr,Min,Max,Object)
 #local vectorA = min_extent(Object);
 #local vectorB = max_extent(Object);
 #local i=0;
 #while (i<ctr)
  #declare Array[i] = <RRand(RsA, Min+vectorA.x, Max+vectorB.x),RRand(RsA,
Min+vectorA.y, Max+vectorB.y),RRand(RsA, Min+vectorA.z, Max+vectorB.z)>;
 #set i=i+1;
// call it like this and use sRandVectArray for the vectorArray input in the
snow macro
// and use the snowcounter variable for the ctr input of the snow macro
#declare snowCounter = 500;
#declare sRandVectArray = array [snowCounter];
 randVectorMM2(sRandVectArray,snowCounter,-sFudgeFactor, sFudgeFactor,
testObject)
> this result. Not entirely convincing, but I only used a single layer of
> moss. I think that with your macro something similar would be obtained.
Possibly. Might I see the test source? I might be able to do something with
it.
With a slight modification, the image you posted looks a lot like trees from
a great altitude... :)
It would also make great corrosion or rust if you changed the colors of your
moss...even dirt or paint peeling off of a wall. Lots of possibilities I see
there.
ian
Date: 28 Feb 2009 07:41:37
Message: <49a93101@news.povray.org>
news:49a82833$1@news.povray.org...
> with it.
Sure. This is the relevant code (Material for the 'moss' and parameters for
the MakeSnow macro. Be aware that this comes from a scene originally created
in Moray. So, the z-axis is up for the macro parameters:
//---- start code
#local Frequency = 20;
#declare Moss =
material {
    granite
    frequency Frequency
    color_map {
      [0.33 color rgbt <0,0,0,1> ]
      [0.33 color rgb <0.3,0.4,0.1>*0.5 ]
      [0.40 color rgb <0.8,0.9,0.1>*0.9 ]
      [0.50 color rgb <0.4,0.4,0.1>*0.8 ]
      [0.50 color rgbt <0,0,0,1> ]
      [0.66 color rgbt <0,0,0,1> ]
      [0.66 color rgb <0.4,0.4,0.2>*0.8 ]
      [0.80 color rgb <0.8,0.8,0.2>*0.8 ]
      [0.99 color rgb <0.4,1.0,0.2>*0.5 ]
      [0.99 color rgbt <0,0,0,1> ]
  normal {
    granite 0.5
    frequency Frequency
    bump_size 5
  finish{
    specular 0.0
//MakeSnow Object
object {
 #declare Obj       = object { MakeSnow_Landscape };
 #declare Particles = 20000;
 #declare Size      = 0.050;
 #declare Thickness = 0.050;
 #declare MinHeight = 0.500;
 #declare MaxHeight = 3.000;
 #declare Direction = (0.0*x)+(0.0*y)+(-1.0*z);
 #declare rd        = seed(2003);
 #declare T_Snow    = material {Moss}
 MakeSnow(Obj,Particles,Size,Thickness,MinHeight,MaxHeight,Direction)
//---- endcode
> from a great altitude... :)
> your moss...even dirt or paint peeling off of a wall. Lots of
> possibilities I see there.
Absolutely. Both aspects are possible, depending on the type of texture that
you use.
