"triple_r" <nomail@nomail> wrote in message
news:web.4985fa6fe879b872ef2b9ba40@news.povray.org...
> "St." <dot### [at] dot com> wrote:
> Nice work. Seems like the glass could use a bit more texture though. I'd
> expect the overall tone of the image to be softer and warmer for a lamp
> like
> this. Here's an example for reference:
> http://styleglass.com/tiffanylamp.jpg
Thank you! I did a lot of searching but didn't spot that one - it's
perfect.
Yes, I definately need to add some varying opaque in there somehow.
~Steve~
> - Ricky
"clipka" <nomail@nomail> wrote in message
news:web.4986067dfd113391f8450bd80@news.povray.org...
>> I downloaded QuickGamma but it doesn't seem to do anything if I
>> change
>> the numbers. I'm obviously doing something wrong. :/
> Why the * use QuickGamma, when all you need to do is check what your
> *current*
> gamma is, set your POV "Display_Gamma" .ini setting to that value, insert
> "assumed_gamma 1.0" in your scene, and then go ahead to fix your scene's
> lighting conditions...
But I'm happy with the way I'm doing it. ;)
~Steve~
But the rest of the internet is not. Think about them also :D
Really. Gammas should be checked and calibrated (even visually). You'll
benefit and the others will too.
And just a bit of media to show the light cone.....
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:49886d02$1@news.povray.org...
Of course. That's one thing that I've done before, and it looks quite
good, so I'll try it again. But not now as I have to crack on with my TC-RTC
image. :)
~Steve~
> Thomas
"Severi Salminen" <sev### [at] NOT THISsaunalahti fi invalid> wrote in
message news:498849bb@news.povray.org...
LOL! You're correct of course... ;)
So what you're really saying is adjust my monitor to 2.2 and then add it
to assumed_gamma 2.2 in my scene and then adjust my scene using correct
ambients until it looks right. But I kind of do that anyway, apart from my
assumed_gamma is .75. I thought the idea was to play around in SDL to get
something good out of it? ;)
It's confusing, that's for sure. I mean, you must be seeing the same as
me, right? I'm sure I would have had more comments about 'washed out', or
'too dark' by now if you weren't. :)
~Steve~
> > *current*
Darn - I was hoping I could convince you ;)
Noooooo! Stooooooop! (*grabs & pulls away keyboard*)
Phew, that was close...
No, *please* don't set "assumed_gamma" to 2.2... I have the theory that it
should be set to 1.0 actually; Set "Display_Gamma" to 2.2 instead, and see what
it does. Check with that "Gamma Test Scene" I posted.
And I wish people would leave that freakin' ambient alone, and use *proper*
lighting, like radiosity and HDR light maps and stuff like that... no surprise
people keep fighting with material settings...
You remember that "Immortal Game" scene? Well, bet you do ;) In case you forgot
where to find it:
http://www.tc-rtc.co.uk/imagenewdisplay/stills/index185.html
(Okay, that's actually for people reading this thread and wondering, "what the
heck is he talking about" ;))
Look at the white knight's mane (upper part, that's a raytraced square).
Guess how long I've been struggling to make good gold or brass textures?
I tell you - for hours on end. And I bet I'm not the only one.
Now guess how long it took me to get the gold material in this shot right (not
talking about the bump mapping here, just color and reflection and all)?
Just a freakin' five minutes; once I had gone for the HDR image for background,
it all came just naturally.
How long do you think I did tinker with the materials for the marble pieces?
Not much work there either.
I think there's a secret here: You can toy around with reflective materials for
ages and ages - if they don't have anything good to reflect, they'll always
look like something else than you intend them to. But if they do have proper
surroundings, it's all a piece of cake.
The same goes for dull materials and a proper lighting model. Radiosity makes
*so* much of a difference. Image-based lighting works good, too (except that
POV doesn't have it). Even if you don't really *see* it in a shot: You *feel*
it, somehow.
(And likewise, to get proper results, the gamma settings need to be right... ;))
Having spent a bit of time trying to sort out the whole gamma smash, I guess
your setting of "assumed_gamma 0.75" isn't so bad after all - in combination
with a "Display_Gamma" of 1.0 it should have roughly the same effect as the
combo "assumed_gamma 1.0" and "Display_Gamma=2.2". However, the drawback is
that you can't properly render other people's scenes that have an "assumed
gamma 1.0" statement, and others can't properly render your scenes either.
And defining translucent materials with an "ambient" term... yuck! I bet you do
that for a purpose, but... well, I guess it's time POV learns how to do fast
subsurface scattering instead, 'cause I bet that's what you try to emulate...
(did I mention that I don't think too much of that "ambient" thing? :P)
"clipka" <nomail@nomail> schreef in bericht
news:web.4988eb2dfd1133915c2186730@news.povray.org...
>> it
It was indeed :-)
> what
Exactly! assumed_gamma 1.0; display_gamma to whatever value is correct for
your machine.
> *proper*
> surprise
My experience is that, with translucent surfaces used as lamp shades, a bit
of ambient on the texture finish is working just fine. In all other cases
ambient should be 0.
I know you disagree on the translucency bit, but it works, even if it is not
orthodox usage :-)
On Wed, 4 Feb 2009 09:58:54 +0100, "Thomas de Groot"
I can't say that I agree with you about using an ambient of zero unless you are
talking about radiosity scenes. And I will stay away from them until Christoph
fixes the code for that. I typically use an ambient between 0.1 and 0.3 for
everyday scenes.
Regards
