"St." <dot### [at] dot com> schreef in bericht news:49859f64@news.povray.org...
> Here's the next one with AA and area_light on. Amazingly, this rendered
> in only 58 minutes. I've used 0.5 on the coloured glass for the ambient in
> this one, and diffused the glass colours by 25%. I'm not sure about it, so
> I think I'll try 0.75 to see what that looks like, but what do you think?
> Ok at 0.5?
Yes, this looks much better. Just to be sure, try also 0.75 indeed, and make
your choice :-)
With this kind of testing, I am always reminded of woodworkers or
stomemasons (and jewellers too, of course): scratching here, taking off
there, polishing, chipping again, polishing again. It's a real artisanal
work. Like you said earlier: RL.
> Thanks Thomas! That's actually quite nice as it is, but it came out kind
> of matt in appearance so I put the metallic in a reflection block and
> added conserve_energy to give it some shine. I think it might have too
> much reflection now though. The normals show a little too much but they
> should look better when using better AA.
You are right! The reflection block works better here, but you can scale
that a bit down too. The same thing for the micro normals which can be
dimmed somewhat, but this depends on the aa. I took the example from a scene
I am working on, where the reflections should be virtually absent.
> Oh, and added a switch. :)
Nice one!
"St." <dot### [at] dot com> wrote:
> > I keep having no idea (and can't seem to learn) which of all those gamma
> > settings to set to 1.0 and which to set to 2.2 - but I know for sure that
> > there
> > should *not* be a .75 *anywhere*...
> :) Why not? If I increase it, it gets darker.
If your scene is too dark, that's not necessarily the gamma's fault. Maybe it's
time to replace that 25W light bulb with a 60W one.
The gamma settings are *not* suitable for adjusting overall scene brightness,
because they do so nonlinearly, thereby messing up the saturation in a highly
brightness-dependent fashion. Exactly the type of "selective washing-out" of
colors seen in your shot.
> "Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
> > Ah yes, this begins to look good. The colors are a bit too *primary* to my
> > taste. You could try to use somewhat *off* reds, yellows, and blues; maybe
> > even a very tiny bit different for each piece of glass. A bit darker too.
> > Scale down the ambient too. Maybe a value around 0.5 will look nice. The
> > opacity is allright I think.
> this one, and diffused the glass colours by 25%. I'm not sure about it, so I
> think I'll try 0.75 to see what that looks like, but what do you think? Ok
> at 0.5?
Nice work. Seems like the glass could use a bit more texture though. I'd
expect the overall tone of the image to be softer and warmer for a lamp like
this. Here's an example for reference:
http://styleglass.com/tiffanylamp.jpg
- Ricky
> I've just rendered this image now, it took 1 hour 22 minutes with
> area_light turned on and normal AA. I changed the colours of the glass to be
> less pale as per Thomas' suggestion, but are these colours too vivid now?
It *is* too vivid now. The problem wasn't the saturation per se, but the
difference in saturation between the lampshade and the shadows cast. Which most
likely is a gamma problem.
> I downloaded QuickGamma but it doesn't seem to do anything if I change
> the numbers. I'm obviously doing something wrong. :/
Why the * use QuickGamma, when all you need to do is check what your *current*
gamma is, set your POV "Display_Gamma" .ini setting to that value, insert
"assumed_gamma 1.0" in your scene, and then go ahead to fix your scene's
lighting conditions...
news:4985c3c8$1@news.povray.org...
> make
> your choice :-)
Ah, well, in this next image I used .7, and I think it looks ok. This
shot is with photons enabled and I stopped it at line 444 with 2pps showing.
(10PP's for someone who gets close to the render time of this image). :)
I can't see that it did much in the image so I don't think I'll use
photonsthankyouverymuch. :)
However, I think the glass is better now but still too vivid.
My Grandad was a good woodworker, making all kinds of weird and
wonderful things like turned bowls to 'what-nots' to corner cabinets and
coffee tables, usually in solid oak or mahogany.
> scene
Yes, the image attached was being rendered before I read this so they're
not applied as yet, but the funny thing is, with the lamp in its proper
place at the back of the room, the bronze looks so much better. So I think
I'll leave it as it is now.
> Nice one!
Hehe, there are more things now! :)
~Steve~
> Thomas
Download 'snapshot4_phot_test.jpg' (307 KB)
Preview of image 'snapshot4_phot_test.jpg'
"triple_r" <nomail@nomail> wrote in message
news:web.4985fa6fe879b872ef2b9ba40@news.povray.org...
> like
Thank you! I did a lot of searching but didn't spot that one - it's
perfect.
Yes, I definately need to add some varying opaque in there somehow.
~Steve~
> - Ricky
"clipka" <nomail@nomail> wrote in message
news:web.4986067dfd113391f8450bd80@news.povray.org...
>> change
> *current*
But I'm happy with the way I'm doing it. ;)
~Steve~
But the rest of the internet is not. Think about them also :D
Really. Gammas should be checked and calibrated (even visually). You'll
benefit and the others will too.
And just a bit of media to show the light cone.....
