POV-Ray : Newsgroups : povray.binaries.images : Christmas tree wip, glows show thru objects Server Time
24 Dec 2025 10:44:58 EST (-0500)
  Christmas tree wip, glows show thru objects (Message 1 to 4 of 4)
Subject: Christmas tree wip, glows show thru objects
Date: 25 Jan 2009 10:52:33
Message: <497c8ac1@news.povray.org>
Hello,
This relates to a query in p.g., and scene file in p.t.s-f.
I'm messing around with making a fake christmas tree macro, using glows as
the lights positioned on the ends of component cylinders, but the glows seem
to show through other objects..
I have a separate macro for making more realistic fake branches (heh..),
which is the second image below.
This probably won't work, because I've never used triangles, and using my
current method its very easy to suck up 2gb of ram, but I'm having fun with
it...so whatever...
Maybe someone has a nice small file using triangles that I might look at and
learn from.
Basic tree using test branches and no bifurcation: (blueStalk7.jpg is
closeup blueStalk7_3.jpg is distance)
Final branch structure: (blueStalk5.jpg) (allows you to specify twig
diameter and total height, not posted in p.t.s-f)
Bifurcation macro: (blueTree2k9_5.jpg) (a modified version of what
"quickfur" wrote on 2/5/07 for the shortcode contest, found in p.t.s-f)
Eventually I'll add a little bifurcation to the branches, with the branch
shown in blueStalk5 replacing the simple ones shown in blueStalk7 to more
accurately represent a fake tree.
I probably won't be able to render it with the glows on though. Heh.
When I'm done I'll use the same positioning macros that I'm using now, along
with a simple recursive tree macro (blueTree2k9_5.jpg) with low iteration to
create the bifurcated branches (consisting of the blueStalk5 object)
resulting in the final tree.
Again, nothing spectacular, just something to occupy my time out of work
with pneumonia.
Let me know if it sucks or anything! :-p
ian
Download 'blueStalk7.jpg' (63 KB) Download 'blueStalk7_3.jpg' (30 KB) Download 'blueStalk5.jpg' (27 KB) Download 'blueTree2k9_5.jpg' (61 KB)
Preview of image 'blueStalk7.jpg'
Preview of image 'blueStalk7_3.jpg'
Preview of image 'blueStalk5.jpg'
Preview of image 'blueTree2k9_5.jpg'
Subject: Re: Christmas tree wip, glows show thru objects
Date: 25 Jan 2009 12:50:01
Message: <web.497ca5eab941bb443c6235530@news.povray.org>
> it...so whatever...
Maybe you want to use a mesh object instead of individual triangles; that should
avoid a good deal of memory-consuming overhead.
(Note that triangles don't have to form a contiguous shape to be combined in a
mesh. Basically, a mesh is just an efficient triangle and smooth_triangle
container.)
Date: 25 Jan 2009 15:42:09
Message: <497ccea1$1@news.povray.org>
Well I haven't tried triangles or mesh yet, its just the default sdl
cylinder...
Would it work to export a cyl from a mesh modeller and use that?
ian
"clipka" <nomail@nomail> wrote in message
news:web.497ca5eab941bb443c6235530@news.povray.org...
>> with
>> it...so whatever...
> should
> in a
> container.)
Date: 25 Jan 2009 19:15:00
Message: <web.497d003eb941bb4463cb5da50@news.povray.org>
> cylinder...
Sorry, misunderstanding - looks like I didn't read your post carefully. Ignore
my comment.
