POV-Ray : Newsgroups : povray.binaries.images : mesh2 Server Time
8 May 2026 08:02:03 EDT (-0400)
  mesh2 (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: mesh2
Date: 2 Jan 2009 17:40:00
Message: <495e97c0@news.povray.org>
Trevor G Quayle schreef:
> Wijnand Nijs <w.n### [at] alf4alldemonnl> wrote:
>> A test with a mesh2 object for different outside (texture) and inside
>> (interior_texture) textures. The test to use the interrior_texture in
>> combination with a texture_list fails. Any idee?
>> Strange is that with the conversion (Poseray): 1. one face has the wrong
>> vertex and 2. some normals are disappeared (no rounding). Is there a way
>> to correct it manually?
>> Greetings...
>> Wijnand
> Odd about the vertex change.  You could maybe track it down manually if you
> can't fix it otherwise.
> As for the normals, if you are refering to the shadow line blockiness, this is
> not an error or normals disappearing, it is a known "bug/feature" (actually not
> really a bug, but it does bug people...)
> See "2.4.8  The shadow line artifact" for an explanation.
> -tgq
Tanks. The "shadow line artifact" is now clear. I have to wait for a
next version.
Subject: Re: mesh2
Date: 2 Jan 2009 19:22:22
Message: <495eafbe@news.povray.org>
----- Original Message -----
Newsgroups: povray.binaries.images
Sent: Friday, January 02, 2009 10:25 PM
Subject: Re: mesh2
> Chris B schreef:
>> Here's a simple testbed so you can play around with it:
> I don't know if it is the way I am play around, but when I declare a
> texture_list I can do with the texture (f.e. leave it transparant) and
> interior_texture (f.e. make it pigment {rgb <0,0,1>}) nothing helps. Or
> has it somthing to do with the version (my version is: 3.6.1.msvc8.win64).
You're right. There seems to be a behavioural different between 3.6 and the
3.7 beta 39.
3.6 seems to ignore the interior_texture and the texture object modifiers if
the texture_list is specified within the body of the mesh2 definition,
whereas 3.7 beta 39 works as I described in my last posting.
Subject: Re: mesh2
Date: 2 Jan 2009 22:15:00
Message: <web.495ed7f67707fe408f3cb1a30@news.povray.org>
> The testbed explains a lots for me (thanks) but... I don't know if it is
> the way I am play around, but when I declare a texture_list I can do
> with the texture (f.e. leave it transparant) and interior_texture (f.e.
> make it pigment {rgb <0,0,1>}) nothing helps. Or has it somthing to do
I guess the thing is quite simple: The generic "texture" and "interior_texture"
are fallback textures that are applied to all triangles that don't have a
texture_list item assigned. So if you do assign a texture_list item, that
texture is applied to both sides, and both "texture" and "interior_texture"
remain without effect to this triangle.
It's a pity there is nothing like a "interior_texture_list", but I guess we have
to live with this limitation for now.
What you could do would be to split up the mesh object by textures before
exporting to POV-Ray, strip each of the resulting objects of the texture_list,
and assign both a texture and interior_texture. Finally combine them via a
union.
Subject: Re: mesh2
Date: 3 Jan 2009 07:59:07
Message: <495f611b$1@news.povray.org>
Chris B schreef:
> ----- Original Message ----- From: "Wijnand Nijs" <w.n### [at] alf4alldemonnl>
> Subject: Re: mesh2
>> Or has it somthing to do with the version (my version is:
>> 3.6.1.msvc8.win64).
> 3.7 beta 39.
> modifiers if
I thought no problem, download and install 3.7 and it works. But... on
www.povray.org there is only a 3.7 beta 29 (64 bit) with an expire date
of the 1st of November 2008. I tried but that one refused to do his job.
   Where to get the 3.7 beta 39?
Thanks and greetings...
Wijnand
Subject: Re: mesh2
Date: 3 Jan 2009 08:15:01
Message: <web.495f63fc7707fe408f3cb1a30@news.povray.org>
For the beta 39 you may still have to wait a while I guess :) But Chris promised
to rush out the beta 30 (basically a not-so-strictly-deadlined beta 29 if I
understand him correctly) in a few hours, and a beta 31 with functional
improvements in what I take to be a couple of days.
Subject: Re: mesh2
Date: 3 Jan 2009 08:21:15
Message: <dhpul4hus9k4jv5m8fln9q266eav0hsgnp@4ax.com>
On Sat, 03 Jan 2009 13:59:01 +0100, Wijnand Nijs <w.n### [at] alf4alldemonnl>
Hi Wijnand,
	On the Beta page there is a 32 bit version as well.
http://www.povray.org/beta/
http://www.povray.org/beta/POV-Ray%20for%20Windows%20v3.7%20beta%2029.msi
There is a workaround to disable the expiry date but an updated version should
be available very soon.
See the post by "Random Coder" on this thread.
http://news.povray.org/povray.beta-test/thread/%3Cweb.495c49605fe797ab30acaf600%40news.povray.org%3E/
You may have to fix the broken lines due to word wrap ;)
Regards
Subject: Re: mesh2
Date: 3 Jan 2009 09:02:33
Message: <495f6ff9$1@news.povray.org>
> Hi Wijnand,
No no.. not back to the 32 bit version, I bought XP Professional x64
edition for speed and not because I like to throw away money. I read
(...) the post by Random Coder and wait patiently you have promised to
Clipka.
Thanks...
Subject: Re: mesh2
Date: 3 Jan 2009 09:28:57
Message: <dftul4l1jd4kcljoqrk3ehoga2s1k6vnn6@4ax.com>
On Sat, 03 Jan 2009 15:02:27 +0100, Wijnand Nijs <w.n### [at] alf4alldemonnl>
>Clipka.
Fair enough.
Regards
Subject: Re: mesh2
Date: 15 Jan 2009 07:40:52
Message: <496f2ed4$1@news.povray.org>
>> Clipka.
> Fair enough.
Hello Chris,
Uhhh... "But Chris promised to rush out the beta 30 (basically a
not-so-strictly-deadlined beta 29 if I understand him correctly) in a few hours" ;)
Greetings...
Wijnand Nijs
Subject: Re: mesh2
Date: 15 Jan 2009 09:07:56
Message: <496f433c$1@news.povray.org>
"Wijnand Nijs" <w.n### [at] alf4alldemonnl> wrote in message
news:496f2ed4$1@news.povray.org...
> Hello Chris,
> hours" ;)
> Greetings...
> Wijnand Nijs
I assume you meant Chris Cason, but he did indeed do that; See
It says it expires 1st of February 2009, but I don't know if that's a strict
deadline.
Chris B.
