POV-Ray : Newsgroups : povray.binaries.images : Rainbow Server Time
20 Feb 2026 12:48:58 EST (-0500)
  Rainbow (Message 21 to 30 of 37)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Rainbow
Date: 25 Dec 2008 05:51:46
Message: <495365c2$1@news.povray.org>
> The image was rendered within one week
   Wow! ...it's a shame I don't have the patience to use my own includes for
such long projects. ;)
   Very good work with the rainbows, both Mike and Florian. I've to agree
with Florian that his one looks even more realistic due to the softer colors.
Jaime
Date: 25 Dec 2008 07:45:00
Message: <web.49537edc619c0ff3d077d5680@news.povray.org>
I have to admit that there's still a little problem with my rainbows. In nature
you hardly can see ones with such soft colors; They indeed are a bit brighter.
Especially the blue band appears too blurred to me. This is because I wrote
some functions by myself to approximate the CIE visible light spectrum. I've
also tried the original values without approximation, but there I did something
wrong, the rainbow showed up 'out of color'. Instead of white, it was ugly
yellowish :)
But one day I will sit down in front of my PC and will begin to write a
brandnew, much better code for the color spectrum.
Greetings, Flo
Date: 25 Dec 2008 08:56:29
Message: <4953910d$1@news.povray.org>
You've provided some very nice examples of what your include file can do.  I
agree that my colors are too bright. I think the problem with the angle of
the 'bows' is how I am determining the viewing and lighting angles. The
project has been abandoned for now but if I do revisit this I may take a
closer look at your implementation. The colors I used were just some values
I hard coded into the source.
Regarding the render times, it was the isosurface that slowed things down
along with two media containers; the one that comes with hf2iso and a box in
front of the camera that I included to simulate scattered rain. The
combination of several densities, scattering media, and isosurfaces really
slows things down, especially since for each intersection with the media it
has to check if any part of the isosurface is blocking the light.
I think that if you implemented your method in the emitting media in the
source it would speed up render times several fold.
-Mike
"Florian Siegmund" <flo### [at] gmxat> wrote in message
news:web.4952d7fd619c0ff387129fc00@news.povray.org...
> Take a glance at this one...
> The image was rendered within one week on a Pentium DualCore 3.6Ghz with
> 2GB
> RAM; I don't know the exact time it took to render though, because I
> stopped
> and continued tracing several times. For this image, I used Jaime Vives
> Piqueres' 'Project Tierra' landscape include files and my own ones for the
> rainbow, and I'm quite happy with the result. Still I'm using emitting
> media
> rather than scattering one, because it renders faster and my include file
> contains the possibility to 'project' a pattern onto the rainbow, e.g.
> clouds,
> to get the illusion of a 'broken' rainbow (not used in this image, but
> possible, if someone liked to use this feature).
> Mike, your rainbow seems a little bit too 'perfect' to me, like it was an
> illustration taken from a fairy tale book; most of all because of the
> powerful
> colors. Maybe this is your aim, because the viewer still gets a very
> special
> impression in this case, I don't know. If you wanted to achieve that, you
> are
> going into the right direction (yes, I like the image; put a crystal
> dragon
> into the scene and I would like it even more!) But for getting an image
> with a
> more realistic look, you should work on the colors and angles of the
> rainbow
> once more. One more thing to say, I wonder about your rendering times...
> what
> is it that kills your processor speed, the rainbow media or the landscape
> isosurface? By default, my rainbow media only takes 2 media intervals.
> There is
> no need of taking more intervals in normal cases, beacause I tweaked the
> density
> function in a way so that it renders nearly like the inbuilt 'fog' feature
> in
> pov-ray (assuming that reflecting water droplets are distributed
> constantly
> along the viewing ray). Hope this helps a little bit.
Date: 25 Dec 2008 10:35:13
Message: <4953a831$1@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> schreef in bericht
news:Qs8### [at] econymdemoncouk...
> Wasn't it Thomas de Groot who wrote:
>>One thing I wonder about is the difference of luminosity of the landscape
>>inside and outside of the rainbow. I am not sure if this is a RL feature.
> Yes. The lightness of the rainbow itself has to come from somewhere. Some
> of the light that would have come from the dark "Alexander's band" as you
> see the rainbow is deflected to make the bright coloured stripes of
> rainbows that are seen by people standing beside you.
> http://en.wikipedia.org/wiki/Alexander%27s_band
Thank you indeed Mike, excellent explanation. I understand it now.
Happy Christmas.
Date: 25 Dec 2008 16:15:01
Message: <web.4953f734619c0ff3180057960@news.povray.org>
Speaking of rainbows, I spotted this natural render yesterday.  Unfortunately,
my cheap digital camera wasn't up for the splendor. :P
My father told it was a sure bet to find a gold pot at its end, which looked to
be in reach for the people in those houses in the far right, a place
coincidentally named "Eldorado"... :D
Download 'arco-iris.jpg' (555 KB)
Preview of image 'arco-iris.jpg'
Date: 25 Dec 2008 16:54:16
Message: <49540108@news.povray.org>
Florian Siegmund wrote:
How do you make the "overall" (I don't see it in the sky) noise in both
of your pics? It makes them look like they were taken with a digital
camera in just a little bit too dark to be clean.
-Aero
Date: 26 Dec 2008 01:22:14
Message: <49547816$1@news.povray.org>
High!
Mike Hough schrieb:
> Well, I meant too long considering it was a test scene. I started out with
> POV-Ray for DOS on a 166mhz system, so I appreciate the processing power
> available these days.
I even started with Cyrix 80486 at 40 MHz... but back then, hardly any
CPU needed cooling fans, so the computer was quiet enough to sleep
beside it while rendering anything more complicated than a RSOCP (which,
by the way, I NEVER did during my early POV-Ray days in the 1990s!)!
> I did this final render of this scene and wasn't going to post it because I
> wasn't happy with it. It took 6d 9h 27m to render at 1920x1200.
Awesome! The mountains strongly remind me of the Hoggar mountains in
southern Algeria - where rainbows are extremely rare!
See you in Khyberspace!
Yadgar
Now playing: She Knew Better (Munich)
Date: 26 Dec 2008 02:45:55
Message: <49548bb3$1@news.povray.org>
"nemesis" <nam### [at] gmailcom> schreef in bericht
news:web.4953f734619c0ff3180057960@news.povray.org...
> Unfortunately,
And Natural POV renders so much faster :-)
This is a nice example by the way.
> looked to
Oooh, the lucky guys!
Date: 26 Dec 2008 03:39:55
Message: <q47d26-bq6.ln1@badulaque.unex.es>
Among other things, Florian Siegmund saw fit to write:
> Another scene, another rainbow...
That's grat!
I seem to remember that, in addition to the two main full-spectrum bands,
there are some green-red stripes at one end... Do you simulate this too?
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 26 Dec 2008 05:55:17
Message: <4954b815@news.povray.org>
I think what you are seeing is the noise component of the isosurface.
"Eero Ahonen" <aer### [at] removethiszbxtnetinvalid> wrote in message
news:49540108@news.povray.org...
> -Aero
