POV-Ray : Newsgroups : povray.binaries.images : Shop Items Take 2 Server Time
30 May 2026 19:16:10 EDT (-0400)
  Shop Items Take 2 (Message 1 to 5 of 5)
Subject: Shop Items Take 2
Date: 8 Nov 2008 08:57:21
Message: <49159ac1@news.povray.org>
Howdy,
    I'm still calling this a work in progress but I think it's WAY better
than the first time. I still can't decide which brass I like better .... the
transom, or the bell/spittoon. I do however like the scattering media effect
around the jug, it doesn't  use a density or color_map. Perhaps I need to
tweak my viewing angle in order to get more of the same effect with some of
the other objects. Fire away if you have any ideas.
L8TR
Download 'Room.png' (377 KB)
Preview of image 'Room.png'
Subject: Re: Shop Items Take 2
Date: 8 Nov 2008 19:11:29
Message: <49162ab1@news.povray.org>
Jim Holsenback wrote:
> Howdy,
> L8TR
That reflective window frame looks like it's shooting out of the cork in
the jug.  Shift the jug or camera a bit so they don't line up.
Photographers call this a case of the sprouts, like when a telephone
pole sprouts out of someone's head.    ;-)
      -=- Larry -=-
Date: 9 Nov 2008 01:52:27
Message: <491688ab$1@news.povray.org>
The textures on the jugs and the wooden tabletop are screaming for
stronger antialiasing. That said, this looks pretty good.
I'm impressed by how you used the media; once most people decide that
they're willing to dedicate the extra render time to scattering media,
tend to crank it waaay up to make sure that you notice it. Your use is
delightfully subtle. At first I wasn't even sure that you were using
media at all--I just felt that there was something "right" about the
lighting that I couldn't put my finger on.
Good show. :-)
William Tracy
"Given a signal with a 2-Hz bandwagon, the Nyquil frequency must be 1-Hz
to avoid aliening of the furrier transformer."
     -- phdcomics.com
Date: 9 Nov 2008 04:21:25
Message: <4916ab95$1@news.povray.org>
"William Tracy" <wtr### [at] calpolyedu> wrote in message
news:491688ab$1@news.povray.org...
ah ... yes since it's still a WIP I used method 1 depth 0.3. better AA is
planned for the final run.
> delightfully subtle. At first I wasn't even sure that you were using media
> at all--I just felt that there was something "right" about the lighting
besides scattering I used a little absorption to cancel out the bluish tint
from the window and a little emission for it's final color .... btw: it took
almost 12 hrs for this render.
> Good show. :-)
Hey thanks!
 Jim
Date: 9 Nov 2008 04:27:30
Message: <4916ad02@news.povray.org>
"Larry Hudson" <org### [at] yahoocom> wrote in message
news:49162ab1@news.povray.org...
> Photographers call this a case of the sprouts, like when a telephone pole
haha .... I misssed that. I had to move the transom a bit as I didn't like
how the tripod leg intercepted the window leading in the far window. easy
enough to move the jug just a bit, but I think I'll try a few lower quality
renders with slightly diff camera angle in hopes of picking up more of the
scattering effect. good feedback .... thanks!
Jim
