POV-Ray : Newsgroups : povray.binaries.images : Sea Scene WIP Server Time
3 Apr 2026 08:14:54 EDT (-0400)
  Sea Scene WIP (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Sea Scene WIP
Date: 2 Oct 2008 17:31:45
Message: <48e53dc1$1@news.povray.org>
Blue Herring nous illumina en ce 2008-10-02 17:07 -->
> Hello,
>   Here's the beginning of a sea scene I've been working on lately.  I'm
> fairly happy with it so far, but I'm not really sure where to go with it
> from here.  Thought I'd share, and if anyone has any comments they're
> always welcome.
Looks OK as is.
I like your sig, but you can make it shorter: remove the version and the
global_settings. Did you notice that changing the smples valus makes some big
difference on the image?
To err is human, to forgive is not our policy.
Date: 2 Oct 2008 17:52:18
Message: <48e54292$1@news.povray.org>
Blue Herring escreveu:
> Hello,
> always welcome.
I enjoyed it, depressing as it may look. :)
Date: 3 Oct 2008 03:13:10
Message: <48e5c606$1@news.povray.org>
"Blue Herring" <pov### [at] bherringcotsenet> schreef in bericht
news:48e53800@news.povray.org...
> Hello,
> always welcome.
Looks good so far. I am not too sure how to do this, but I suppose some
ripples around the posts would improve the water.
Date: 3 Oct 2008 08:00:46
Message: <48e6096e$1@news.povray.org>
Alain wrote:
> Looks OK as is.
> some big difference on the image?
Thanks!  Thanks for the suggestions, I was wondering if it might be a
bit too long.  I did notice that, and it surprised me.  I haven't seen
that make such a difference before now.  I'm assuming that the result
would converge at some higher setting.
-The Mildly Infamous Blue Herring
Date: 3 Oct 2008 08:09:05
Message: <48e60b61$1@news.povray.org>
Thanks very much!  I was shooting for somewhat desolate, though I wasn't
thinking depressing :)
// The Mildly Infamous Blue Herring
#include"functions.inc"isosurface{function{-f_strophoid(x/2-.45,y,
z*3,1,1.2,1,1.5)-.05}contained_by{box{<-2.1,-1,-1/3>,<1.4,1,1/3>}}
max_gradient 12inverse hollow pigment{rgbf 1}interior{media{samples
8 emission<3,80,150>/255density{crackle metric 1color_map{[0rgb 6]
[.03rgb 0][1rgb 0]}scale<1,2,1>warp{turbulence<.5,.75,.5>}scale 1/
3}}}translate z*3}
Date: 3 Oct 2008 08:12:23
Message: <48e60c27$1@news.povray.org>
Thanks, and that's a good idea.  The "ripples" pattern uses random
locations, but perhaps some sort of radial sine waves...  now I have to
try it! :)
3}}}translate z*3}
Date: 3 Oct 2008 09:49:30
Message: <48e622ea$1@news.povray.org>
I was sure I had it somewhere!
I remember I asked about this some years ago. Jim Charter provided the
following piece of code:
 Persistence of Vision Ray Tracer Scene Description File
 File name   :      .pov
 Version     : 3.6 / MegaPOV 1.0
 Description : Quick stab at placing concentric ripples w objects.
 Date        : July 2005
 Author      : Jim Charter
 E-mail      : p.b.i. and p.b.s-f, 05-07-2005
        sky_sphere {
            gradient y
            color_map { [0.0 color rgb <0.7,0.7,1.0>] [1.0 color blue 0.5] }
        light_source {    0
                color rgb 1
                translate vrotate ( <0,0,-100 >, <80, 90, 0> )
                location vrotate ( <0,0,-20 >, <10, 0, 0> )
                look_at <0,0,0>
                angle 25
        #local S = seed(1);
        #local Number = 2;
        #local RandomLocation = array[Number];
        #local I = 0;
        #while (I < Number)
          #local RandomLocation[I] =  < 5-10*rand(S), 0, 5-10*rand(S) > ;
          #local I = I + 1;
        plane { y, -10 pigment { rgb 0 }}
        plane { y, 0
          hollow
          interior { ior 1.5 }
          pigment { rgb 0 }
          finish { ambient 0 reflection { 1 fresnel on } }
          normal {
            average
            normal_map {
              #local I = 0;
              #while (I < dimension_size(RandomLocation,1))
                [1   pigment_pattern {
                       cylindrical
                       scale 5
                       poly_wave 1.5
                       pigment_map {
                         [0  rgb 1 ]
                         [1  wood
                             rotate x*90
                             cubic_wave
                             scale .1
                             pigment_map {
                               [0 rgb .5]
                               [.45 rgb .3 ]
                               [.55 rgb .7]
                               [1 rgb .5]
                       translate RandomLocation[I]
                #local I = I + 1;
        #local I = 0;
          sphere { 0, .5
            pigment { rgb Yellow }
            translate RandomLocation[I] + <0,.25,0>
          #local I = I + 1;
Date: 3 Oct 2008 13:32:34
Message: <48e65732$1@news.povray.org>
Blue Herring nous illumina en ce 2008-10-03 08:00 -->
> Alain wrote:
>> Looks OK as is.
>> the global_settings. Did you notice that changing the smples valus
>> makes some big difference on the image?
It's because you use the crackle pattern with a color_map that goes from 6 to
zero over 0.03. With more samples, you follow the actual pattern more closely.
There is about no difference if you go from 20 to 40 samples, so, yes, it does
converge with larger values.
Want to shorten a bit more?
color_map{[0rgb 6][.03rgb 0][1rgb 0]}
is the same as
color_map{[0rgb 6][.03rgb 0]}
The strongest reason for the people to retain the right to keep and bear
arms is, as a last resort, to protect themselves against tyranny in
government.
Thomas Jefferson
Date: 7 Oct 2008 18:01:57
Message: <48ebdc55@news.povray.org>
I like the atmosphere.
> I'm not really sure where to go with it from here.
I assume the viewpoint is from the shore, so possibly
some rocks could be seen at the bottom of the image, or
shallower water. Actually, your water seems reflective,
but not transparent. Some object(s) on the right part of
the island: Dead trees, ruined house, tower, lighthouse?
Maybe a less centered horizon?
Date: 9 Oct 2008 11:04:39
Message: <48ee1d87@news.povray.org>
Nifty, thanks!  This will be useful, I think.
3}}}translate z*3}
