POV-Ray : Newsgroups : povray.binaries.images : PoVEarth, day #9 Server Time
12 Apr 2026 05:40:57 EDT (-0400)
  PoVEarth, day #9 (Message 1 to 10 of 12)
Subject: PoVEarth, day #9
Date: 3 Sep 2008 13:42:32
Message: <48becc88@news.povray.org>
High!
Today I found some time to continue with my apartment... after
implementing Reactor's suggestions (using different diffuse values for
inside and outside finishes and increasing radiosity brightness) and
also setting global ambient to 0.35, I managed to get a crudely
believable level of inside illumination.
But there are still some problems to fix: as you might notice in take 35
and 36, the radiosity illumination of the very same surface obviously
depends strongly on the camera position - the bathroom walls are much
darker if I look straight to the door! Is there any chance to avoid such
dependencies?
See you in Khyberspace!
Yadgar
Download '.jpg' (29 KB) Download '.jpg' (8 KB) Download '.jpg' (18 KB) Download '.jpg' (14 KB) Download '.jpg' (16 KB) Download '.jpg' (15 KB)
Preview of image '.jpg'
.jpg
.jpg
.jpg
.jpg
.jpg
.jpg
Subject: Re: PoVEarth, day #9
Date: 3 Sep 2008 14:40:11
Message: <48beda0b$1@news.povray.org>
news:48becc88@news.povray.org...
> High!
> dependencies?
> Yadgar
It looks like your textures have an ambient-setting >0
I can see no reason to set global ambient to 0.35, just add a #default
{finish {ambient 0}} at the top of the file.  This will leave the textures
that have an explicit ambient-setting intact, and lower the ambient of the
other textures to 0, giving you much better results.
cu!
Date: 3 Sep 2008 15:30:00
Message: <web.48bee4a43f41c8c03433a17c0@news.povray.org>
=?ISO-8859-15?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> High!
> dependencies?
> Yadgar
Actually, I strongly recommend against using ambient for this.  The surfaces
should have an ambient of 0 and rely only on diffuse lighting for illumination.
 The only time ambient should be used with radiosity is when you want an object
to emit light.
I could not tell the differences between the images you posted, but there are
some radiosity artifacts I can see.  The strange lightness in the interior
corners is from the ambient light.  Can you post the related code?
-Reactor
Date: 3 Sep 2008 17:40:02
Message: <48bf0432@news.povray.org>
High!
I doubt that (see below)... I tried it out, and now, the interior are
significantly darker than before - and increasing the radiosity
brightess (currently at 3) would be no alternative, as already at
brightness=4 all outer walls "drown" in shadowless white!
ambient_light 0.35 still looks better...
Yadgar
.jpg
Date: 3 Sep 2008 17:55:35
Message: <48bf07d7@news.povray.org>
High!
See attachment... when the camera is positioned between main room and
bathroom door, the walls of both rooms are considerably brighter than if
  the camera was placed right in front of the bathroom door!
but there are
interior
This is obviously not true as I (see my reply to Zeger) set the global
ambient_light as well as the default texture ambient to 0 - but the
brightened corners still persist!
Here it is:
// My Place in the World
// A sub-sub-subsection of the PoVEarth project
// E-mail: yaz### [at] gmxde
// RADIOSITY
#declare radio=1; // flag for radiosity
#declare balanced=1; // flag for balanced lighting levels, as suggested
by Reactor
#if (balanced=1)
   #declare radbri=3;
   #declare outerDiff = 0.48;
   #declare innerDiff = 1;
#else
   #declare radbri=1;
   #declare outerDiff = 1;
global_settings
   #if (!radio)
     ambient_light 0.15
   #else
     ambient_light 0
     radiosity
       brightness radbri
       adc_bailout 0.01
       gray_threshold 0.8
       recursion_limit 3
       count 35
       error_bound 1.8
#default
   finish { ambient 0 }
// TIME VARIABLES
// PIGMENTS
#declare P_Concrete =
pigment
   color rgb 0.9
// FINISHES
#declare F_Standard_Outer =
finish
   diffuse outerDiff
   brilliance 0.15
#declare F_Standard_Inner =
finish
   diffuse innerDiff
   brilliance 0.15
// NORMALS
// TEXTURES
#declare T_Concrete_Outer =
texture
   pigment { P_Concrete }
   finish { F_Standard_Outer }
#declare T_Concrete_Inner =
texture
// LENGTH VARIABLES
#declare FrKarl_SideStreet_Width = 6.09;
#declare FrKarl_SideStreet_Pavement_Width = 1.32;
#declare GWG_FrKarl_Block238to252_Front_Way_Length = 4.09;
#declare GWG_FrKarl_Block238to252_Front_Doorstep_Depth = 0.427;
#declare GWG_FrKarl_Block238to252_Front_Doorstep_Depth = 0.115;
#declare GWG_FrKarl_Block238to252_Stair_Height = 0.168;
#declare GWG_FrKarl_Block238to252_Floor_Height = 16 *
GWG_FrKarl_Block238to252_Stair_Height;
#declare GWG_FrKarl_Block238to252_Floor_yOffset = 8 *
#declare GWG_FrKarl_Block238to252_Ceiling_Thickness = 0.148;
#declare GWG_FrKarl_Block238to252_Balcony_Spacing=9.19;
// OBJECT DEFINITIONS
#declare GWG_FrKarl_Block238to252_Raw=
box
   0, <11.08, 9.523, 53.49>
#declare GWG_FrKarl_Block238to252_Balcony_Raw=
difference
   box
     0, <1.155, 0.948, 3.24>
   box
     <0.165, 0.148, 0.155>, <1.65, 0.95, 3.085>
#declare GWG_FrKarl_Block238to252_Floor_Cutout =
box
   0, <10.34, 2.54, 52.75>
#declare GWG_FrKarl_Block238to252_Balcony_Door_Cutout =
box
   0, <0.38, 2.14, 1.14>
#declare GWG_FrKarl_Block238to252_MiddleApartment_InnerWall =
box
   0, <0.37, 7.892, 7.925>
#declare GWG_FrKarl_Block238to252_SouthernApartment_Bathroom_Wall =
box
   0, <3.515, 7.892, 0.1>
#declare GWG_FrKarl_Block238to252_SouthernApartment_InnerChimney =
box
   0, <0.5, 7.892, 0.3>
#declare GWG_FrKarl_Block238to252_SouthernApartment_BathroomDrainageBlock =
box
   0, <0.265, 7.892, 0.12>
#declare GWG_FrKarl_Block238to252_SouthernApartment_HallWall =
difference
   box
     0, <0.11, 7.892, 2.37>
   #declare a=0;
   #while (a<3)
     box
       0, <0.12, 2.0751, 0.86>
       translate <-0.005, a * 2.688 - 0.1481, 1.47>
     box
       0, <0.12, 2.0751, 0.96>
       translate <-0.005, a * 2.688 - 0.1481, 0.035>
     #declare a=a+1;
#declare GWG_FrKarl_Block238to252_SouthernApartment_KitchenRow_SideWall =
box
   0, <1.33, 7.892, 0.11>
#declare GWG_FrKarl_Block238to252_SouthernApartment_StorageRoom_SideWall =
box
   0, <0.31, 7.892, 0.115>
#declare GWG_FrKarl_Block238to252_SouthernApartment_StorageRoom_FrontWall =
difference
   box
     0, <0.087, 7.892, 0.765>
   #declare a=0;
   #while (a<3)
     box
       0, <0.089, 2.0501, 0.52>
       translate <-0.001, a * 2.688 - 0.1481, 0.05>
     #declare a=a+1;
#declare GWG_FrKarl_Block238to252_SouthernApartment_StorageRoom_Cutout =
box
   0, <0.124, 2.5399, 0.7649>
#declare GWG_FrKarl_Block238to252_SouthernApartment_BathroomWindow_Cutout =
box
   0, <0.38, 0.75, 0.72>
#declare GWG_FrKarl_Block238to252_ApartmentDoor_Cutout =
box
   0, <1.005, 2.106, 0.267>
#declare GWG_FrKarl_Block238to252_StairsHall_SideWall =
difference
   box
     0, <4.98, 7.892, 0.265>
   #declare a=0;
   #while (a<3)
     object
       translate <6.636, a * 2.688 - 0.149, -0.001>
     #declare a=a+1;
// CAMERA SETTINGS
// using microlocal coordinates
#declare view=0;
#switch(view)
   #case (0) // pedestrian view on side street, up building #246
     #declare camPos = <-8, 1.7, 10>;
     #declare camLook = <1, 7.2, 3>;
     #declare camAng = 40;
   #break
southward along side street
     #declare camPos = <-(FrKarl_SideStreet_Width / 2 +
FrKarl_SideStreet_Pavement_Width +
GWG_FrKarl_Block238to252_Front_Way_Length +
                        GWG_FrKarl_Block238to252_Front_Doorstep_Depth),
1.7, 70>;
     #declare camLook =<-(FrKarl_SideStreet_Width / 2 +
1.7, 0>;
     #declare camAng = 60;
   #break
   #case (2) // pedestrian view on side street, up building #244
     #declare camLook = <-30, 7.2, 0>;
   #break
   #case (3) // inside 1st floor of building #244, looking east
     #declare camPos = <-25.5, 5.9, 2.5>;
     #declare camLook =<-16, 4.6, 2.5>;
   #break
   #case (4) // inside 1st floor of building #244, balcony door
threshold close-up
     #declare camPos = <-17.9, 5.5, 2.5>;
     #declare camLook = <-17.76, 3.5, 2.5>;
   #break
   #case (5) // inside my apartment, looking west
     #declare dir = 270+clock;
     #declare azi = -10;
     #declare camPos = <4.2, 40 * 0.168 + 1.7, 2.5>;
     #declare camLook = camPos + < sin(radians(dir))*cos(radians(azi)),
sin(radians(azi)), cos(radians(dir))*cos(radians(azi))>;
     #declare camAng = 50;
   #break
   #case (6) // oblique view from 30 metres above ground, looking west
     #declare dir = 270;
     #declare azi = -25;
     #declare camPos = <40, 30, 10>;
   #break
   #case (7) // oblique (cutup) view from 18 metres above ground, my
apartment only, looking west
     #declare dir = 270;
     #declare azi = -25;
     #declare camPos = <15, 18, 3>;
   #break
   #case (8) // oblique (cutup) view from 18 metres above ground, my
apartment only, looking north
     #declare dir = 0;
     #declare azi = -25;
     #declare camPos = <5, 18, -10>;
   #break
   #case (9) // oblique (cutup) view from 18 metres above ground, my
apartment only, looking north-east
     #declare dir = 45;
     #declare azi = -25;
     #declare camPos = <-5, 18, -5>;
   #break
   #case (10) // view inside my main apartment room through hall door
     #declare dir = 70;
     #declare azi = -15;
     #declare camPos = <2.5,
GWG_FrKarl_Block238to252_Front_Doorstep_Depth + 40 * 0.168 + 1.7, 3>;
     #declare camAng = 65;
   #break
   #case (11) // view from my hall into staircase and northern apartment
     #declare dir = 0;
     #declare azi = -5;
     #declare camPos = <6.95,
GWG_FrKarl_Block238to252_Front_Doorstep_Depth + 40 * 0.168 + 1.7, 4.2>;
   #break
   #case (12) // inside my hall
     #declare dir = 330;
     #declare azi = -5;
     #declare camPos = <4.75,
GWG_FrKarl_Block238to252_Front_Doorstep_Depth + 40 * 0.168 + 1.7, 3.5>;
   #break
   #case (13) // view from my hall towards main room and balcony
     #declare dir = 260;
     #declare azi = -5;
   #break
   #case (14) // view from my hall into bathroom
     #declare dir = 270;
     #declare azi = -5;
GWG_FrKarl_Block238to252_Front_Doorstep_Depth + 40 * 0.168 + 1.7, 4.6>;
   #break
// ACTUAL SCENE
#declare detail=0;
#declare cutup=0;
#if (!detail) // full scene views
   // SCALE MODELS
   #declare models = array[5] { 0, 0, 0, 1, 0 }
   // models[0]: cosmic scale - whole Solar System, heliocentric
   // models[1]: global scale - Earth, geocentric, spherical terrain relief
   // models[2]: regional scale - 40 x 40 kms area around Cologne,
heightfield
   // models[3]: local scale - 500 x 500 metres around my apartment, plane
   // models[4]: microlocal - my apartment only, outside world only as
HDRI bitmaps
   #declare a=0;
   #declare i=0;
   #while (a<5)
     #if (models[a])
       #declare i=i+1;
     #declare a=a+1;
   #if (!i | i>1)
     #warning "Missing or ambiguous scale setting" // terminating POV script
   #else
     #if (models[0])
       #declare f=1000000 // 1 unit = 1000 kms
     #if (models[1])
       #declare f=1000; // 1 unit = 1 km
     #if (models[2] | models[3] | models[4])
       #declare f=1; // 1 unit = 1 metre
     #if (models[3])
       #declare trans=<251.565, 0, 250.325>;
    // #declare f=1;
     #if (models[3])
       light_source
         <0, 500, -1000>
         color rgb 1
     #if (models[2] | models[3])
       plane
         y, 0
         texture // bare sandy soil
           pigment { color rgb <0.5, 0.35, 0.2> }
     #if (models[3])
       sky_sphere
         pigment
           gradient y
           color_map
             [0 rgb <0.7, 1, 1>]
             [0.25 rgb <0, 0.5, 1>]
             [1    rgb <0, 0.5, 1>]
#if (cutup)
   difference
     union
#250 and #252
         union
           object
             texture { T_Concrete_Outer }
             scale 1/f
           #declare a=0;
           #while (a<3) // 3 floors with balconies
             #declare b=0;
             #while (b<2) // 2 balconies per floor
               object
                 scale 1/f
                 translate <-1.155 +b * 0.515,
GWG_FrKarl_Block238to252_Floor_yOffset + a *
GWG_FrKarl_Block238to252_Floor_Height - 0.148, 1.045 + b *
                          GWG_FrKarl_Block238to252_Balcony_Spacing>/f
               #declare b = b + 1;
             #declare a = a + 1;
         #declare a=0;
         #while (a<3)
           object
             texture { T_Concrete_Inner }
             scale 1/f
             translate <0.37, GWG_FrKarl_Block238to252_Floor_yOffset + a
* GWG_FrKarl_Block238to252_Floor_Height, 0.37>/f
           #declare a = a + 1;
         #declare a=0;
         #while (a<3)
           #declare b=0;
           #while (b<2)
             object
               scale 1/f
               translate <-0.005,
		      GWG_FrKarl_Block238to252_Floor_yOffset + 0.00001 + a *
                       1.84 + b *
             object
               scale 1/f
               translate <-0.005,
GWG_FrKarl_Block238to252_Floor_Height + 1.555,
                           4.585 + b*3.05>/f
             #declare b = b + 1;
           #declare a = a + 1;
       object
         scale 1/f
         translate <0.37, 1.459, 5.555>/f
       object
         scale 1/f
         translate <0.37, 1.459, 8.03>/f
       difference
         object
           scale 1/f
           translate <5.215, 1.459, 0.37>/f
         object
           scale 1/f
           translate <5.214, 1.459 + 32*0.168 - 0.1481, 3.18505>
       object
         scale 1/f
         translate <0.37, 1.459, 4.245>/f
       object
         scale 1/f
         translate <3.385, 1.459, 4.345>/f
       object
         scale 1/f
         translate <1.19, 1.459, 4.305>/f
       object
         scale 1/f
         translate <3.885, 1.459, 3.185>/f
       object
         scale 1/f
         translate <3.885, 1.459, 3.075>/f
       object
         scale 1/f
         translate <4.905, 1.459, 3.95>/f
       object
         scale 1/f
         translate <4.905, 1.459, 3.185>/f
       #if (!cutup)
         translate trans/f
     #if (cutup)
       box {  <-0.001, 9.1, -0.001>, <11.081, 9.524, 53.491> texture {
T_Concrete_Outer } }
       translate trans/f
     #if (!balanced)
       light_source // shadowless fill light for apartment 2nd floor
south in house #246
         <3, 0.115 + 40 * 0.168 + 1.27>
         color rgb 0.3
         shadowless
#242 and #244
       union
         object
           scale 1/f
         #declare a=0;
           #declare b=0;
             object
               rotate y*180
               scale 1/f
               translate <11.08 + 1.155 - b * 0.515,
			1.045 + 3.24 + b * GWG_FrKarl_Block238to252_Balcony_Spacing>/f
             #declare b = b + 1;
           #declare a = a + 1;
       #declare a=0;
       #while (a<3)
         object
           scale 1/f
           translate <0.37, GWG_FrKarl_Block238to252_Floor_yOffset + a *
         #declare a = a + 1;
       #declare a=0;
       #while (a<3)
         #declare b=0;
         #while (b<2)
           object
             scale 1/f
             translate <10.705,
                       1.84 + b *
           #declare b = b + 1;
         #declare a = a + 1;
       translate (< -((FrKarl_SideStreet_Pavement_Width +
                    GWG_FrKarl_Block238to252_Front_Doorstep_Depth)*2 +
                    FrKarl_SideStreet_Width)-11.08,
                    0,
                    0 > + trans)/f
     camera
       location camPos/f +trans
       look_at camLook/f +trans
       angle camAng
#else // single detail views
   sky_sphere
     pigment { color rgb 1 }
   plane
     y, 0
     texture
   light_source
     <1000, 2000, -4000>
     color rgb 1
   object
     GWG_FrKarl_Block238to252238to252_Balcony_Raw
   camera
      location <8, 1.5, 1.6>
      look_at  <0, 0.5, 1.6>
      angle 40
.jpg
Date: 3 Sep 2008 20:34:21
Message: <48bf2d0d$1@news.povray.org>
news:48bf0432@news.povray.org...
> High!
>> textures
>> the
this image looks a whole lot better already.  Just use higher quality
radiosity, and you're there
cu!
Date: 3 Sep 2008 23:30:01
Message: <web.48bf55c93f41c8c05f180b2a0@news.povray.org>
=?ISO-8859-1?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> High!
> Here it is:
Texture changes:
/*  old declaration
texture
// should be replaced with:
texture
    finish { F_Standard_Inner }
I am still adjusting other settings, but the first change I made was above, with
the inner and outer diffuse settings.  T_Concrete_Inner is using the finish
F_Standard_Outer, and it should be using F_Standard_Inner.
Next:
#if (balanced=1)
   #declare radbri=1.125; /* 1.125 or so for outdoors, raise to 2.0 for indoor
views*/
   #declare outerDiff = 0.25;
   #declare outerAmbi = 0.15;
   #declare innerDiff = 1.00;
   #declare innerAmbi = 0.00;
#else
   #declare radbri=1;
   #declare outerDiff = 1.00;
   #declare outerAmbi = 0.00;
// FINISHES
finish
   diffuse outerDiff
   ambient outerAmbi // new variable, declared above
   brilliance 0.15
finish
   diffuse innerDiff
   ambient innerAmbi
   brilliance 0.15
  I added additional variables for controlling the ambient settings
individually.  I do not recommend the use of ambient light for the indoor
portions, but it can be used to help alter the contrast of the outdoor shadows.
I also dropped the radiosity brightness to the 1.0 to 1.25 range, observing good
results around 1.125 for outside views.  This can be raised or lowered depending
on how much you want the user to be able to see inside.
After changing that, I raised the brightness of the light_source to match.
Assuming a desired intensity of 1.0 * the color declared in the pigment
statement, with a diffuse of 0.25, the light source brightness should be 4.0
(since 4.0 * 0.25 = 1).
     #if (models[3])
       light_source
         <0, 500, -1000>
         color rgb 4 // raised from 1.0
The radiosity block needs a great deal of adjustment.  An error_bound of 1.8 is
too high for the size of the shadows for what I've seen at view 0, it should
probably be in the 0.25 to 0.75 range with a count raised to match.  I would
also boost the number of bounces to 4 or 5, possibly more for the indoor scenes
and depend on adc bailout (it rarely continues beyond 4 bounces).
Note that the radiosity adjustments will significantly alter the brightness of
some parts!  This is especially true for an error_bound that is too large.
Right now I am rendering view 13 with higher quality radiosity settings and the
changes to the finishes and light_sources mentioned above.  I expect it to take
> 30 minutes, and it is still going to be slightly lower quality (needs to have
a higher count for the error_bound values I am using), but it should be
sufficient to demonstrate the type and degree of brightness changes that will
be available to you by altering the indoor and outdoor diffuse values
seperately.
This is the radiosity block I am using:
  radiosity{
    pretrace_start 100/image_width  // start pretrace at this size
    pretrace_end     1/image_width  // end pretrace at this size
//    adaptive 1 // can only be used under MegaPov 1.2.1
    count 100                       // higher -> higher quality (1..1600) [35]
    nearest_count 20                // higher -> higher quality (1..10) [5]
    error_bound 0.25               // higher -> smoother, less accurate [1.8]
    recursion_limit 5               // how much interreflections are calculated
(1..5+) [3]
    low_error_factor .5             // reduce error_bound during last pretrace
step
    gray_threshold 0.80             // increase for weakening colors (0..1) [0]
    minimum_reuse 0.0015            // reuse of old radiosity samples [0.015]
    brightness radbri               // brightness of radiosity effects (0..1)
[1]
    adc_bailout 0.01
    always_sample off               // turn sampling in final trace off [on]
-Reactor
Date: 4 Sep 2008 02:30:01
Message: <web.48bf7f8a3f41c8c05f180b2a0@news.povray.org>
Rendered view 13, command line: +w1024 +h768 +a0.2 +am2 +r4
Took approx 25 minutes on a P4 3.0GHz
Radiosity settings as below, other settings were the changes I recommended in
the previous post.
#declare radbri = 1.50;
radiosity{
    //adaptive 1                   // MegaPov 1.2.1 only
    error_bound 0.5                // higher -> smoother, less accurate [1.8]
    low_error_factor .25           // reduce error_bound during last pretrace
step
    brightness radbri              // brightness of radiosity effects (0..1) [1]
    adc_bailout 0.01
    //save_file "povworld.rad"
Note that there are artifacts in the corners that can be corrected by boosting
count, but I didn't want to wait for it.  Perhaps MegaPov's adaptive error
bound could help here also, but I've never had much luck with it.  I am still
experimenting with view 0, but I expect the settings to be similar.  The main
difficulty that I am encountering is that some of the windowsills that have the
interior diffuse settings receive direct light, and as a result are brighter
than they should be.
-Reactor
Download 'povworld_radb1.50.png' (90 KB)
Preview of image 'povworld_radb1.50.png'
Date: 4 Sep 2008 09:03:23
Message: <48bfdc9b$1@news.povray.org>
> dependencies?
Maybe take a look at the MCPov patch.  I have had some really good results
from MCPov with scenes that have been a pain to get radiosity working well.
The render times are usually a lot longer with MCPov to get a smooth image,
but if you factor in the time spent fiddling with radiosity and scene
settings it can actually be faster.
Date: 4 Sep 2008 11:35:02
Message: <web.48bfff6e3f41c8c097ce1dd00@news.povray.org>
Took approx 33 minutes on a P4 3.0GHz
Radiosity settings as below, also changed llight_source back to 1.0 for this
view (down from 4.0 in the indoor veiw).
   #declare radbri=1.375;
   #declare outerDiff = 0.75;
radiosity{
//    adaptive 1
    count 200
    nearest_count 20
    error_bound 0.25
    recursion_limit 5
    gray_threshold 0.80
    brightness radbri
    adc_bailout 0.01
    save_file "povworld_v0_unbal.rad"
    always_sample off
-Reactor
Download 'povworld_rad_unbal.png' (121 KB)
Preview of image 'povworld_rad_unbal.png'
