POV-Ray : Newsgroups : povray.binaries.images : Blob Issue 2 Server Time
30 Sep 2024 21:33:11 EDT (-0400)
  Blob Issue 2 (Message 1 to 2 of 2)
Subject: Blob Issue 2
Date: 2 Sep 2008 10:16:22
Message: <48bd4ab6@news.povray.org>
Hello,
   This is the second issue I ran into with blobs lately.  What is
happening is that when a blob with individually textured components has
something removed using a difference, and the difference uses the
"cutaway_textures" option, then the texturing of the components is lost.
  What it seems like its doing is reapplying the texture from the object
level of the blob, but not the component level.
An example scene:
#version 3.61;
#declare Use_Difference = yes;
#declare Use_Cutaway = yes;
#declare Use_Object_Texture = yes;
#declare Use_Left_Texture = yes;
#default { finish { ambient 0.1 diffuse 0.9 } }
global_settings {
   assumed_gamma 1.0
   max_trace_level 6
   location <0, 4, -7>
   up y
   right x * image_width/image_height
   look_at y * 2
light_source {
   <20, 10, -30>, White
box {
   <-50, -1, -50>, <50, 50, 10>
   inverse
     pigment { White }
plane {
   y, 0
       checker White, Black
       scale <2.5, 1, 2.5>
#declare Glass_F =
   finish {
     ambient 0
     specular 0.9
     roughness 0.001
     reflection {
       0, 1
       fresnel
     conserve_energy
#declare Yellow_Glass =
     pigment { Yellow }
     finish { Glass_F }
#declare Blue_Glass =
     pigment { Blue }
     finish { Glass_F }
#declare Red_Glass =
     pigment { Red }
     finish { Glass_F }
#declare Green_Glass =
     pigment { Green }
     finish { Glass_F }
#declare Obj =
   blob {
     threshold 1
     sphere { <-1.5, 2, 0>, 3.696, 2
       #if(Use_Left_Texture)
         texture { Red_Glass }
     sphere {
       <1.5, 2, 0>, 3.696, 2
       texture { Yellow_Glass }
     #if(Use_Object_Texture)
       texture { Blue_Glass }
     interior {
       ior 1.62725
#if(Use_Difference)
   #declare Obj =
     difference {
       object { Obj }
       box {
         <-0.75, -0.75, -10>, <0.75, 0.75, 10>
         rotate z * 45
         translate y * 2
         #if(! Use_Cutaway)
           texture { Green_Glass }
       #if(Use_Cutaway)
         cutaway_textures
       bounded_by {
         box { min_extent(Obj), max_extent(Obj) }
object { Obj }
I've attached some sample images.  The first is just the blob with
textures on the left and right components and the object as a whole.
The second is a box differenced from the same blob.  The third is the
same difference with the cutaway_textures keyword applied.  The last is
the same as the third, but the object texture has been removed.  Note
the last one generates a parse error about a missing pigment, and the
texture looks the be the global default.
It seems component textures are just not supported with
cutaway_textures. If this is documented somewhere and I just missed it,
someone please let me know.
-The Mildly Infamous Blue Herring
Download 'blob issue 2 - no difference, left right and object textured.png' (34 KB) Download 'blob issue 2 - difference, no cutaway, left right and object textured.png' (34 KB) Download 'blob issue 2 - difference, cutaway, left right and object textured.png' (31 KB) Download 'blob issue 2 - difference, cutaway, left and right textured, object untextured.png' (11 KB)
Preview of image 'blob issue 2 - no difference, left right and object textured.png'
Preview of image 'blob issue 2 - difference, no cutaway, left right and object textured.png'
Preview of image 'blob issue 2 - difference, cutaway, left right and object textured.png'
Preview of image 'blob issue 2 - difference, cutaway, left and right textured, object untextured.png'
Subject: Re: Blob Issue 2
Date: 2 Sep 2008 13:16:35
Message: <48bd74f3$1@news.povray.org>
Blue Herring nous illumina en ce 2008-09-02 10:16 -->
> Hello,
> An example scene:
> #version 3.61;
> global_settings {
>   assumed_gamma 1.0
>   max_trace_level 6
> camera {
>   location <0, 4, -7>
>   up y
>   look_at y * 2
> light_source {
> box {
>   inverse
>   texture {
>     pigment { White }
> plane {
>   y, 0
>   texture {
>     pigment {
>       scale <2.5, 1, 2.5>
> #declare Glass_F =
>   finish {
>     ambient 0
>     specular 0.9
>     roughness 0.001
>     reflection {
>       0, 1
>       fresnel
>     conserve_energy
>   texture {
>     pigment { Yellow }
>     finish { Glass_F }
>   texture {
>     pigment { Blue }
>     finish { Glass_F }
>   texture {
>     pigment { Red }
>     finish { Glass_F }
>   texture {
>     pigment { Green }
>     finish { Glass_F }
> #declare Obj =
>   blob {
>     threshold 1
>       #end
>     sphere {
>     #end
>     interior {
>       ior 1.62725
> #if(Use_Difference)
>   #declare Obj =
>     difference {
>       object { Obj }
>       box {
>         rotate z * 45
>         translate y * 2
>         #if(! Use_Cutaway)
>         #end
>       #if(Use_Cutaway)
>         cutaway_textures
>       #end
>       bounded_by {
> #end
> object { Obj }
> textures on the left and right components and the object as a whole. The
> second is a box differenced from the same blob.  The third is the same
> difference with the cutaway_textures keyword applied.  The last is the
> same as the third, but the object texture has been removed.  Note the
I have reproduced your problem with both 3.6 and 3.7.
Conquest is not in our principles. It is inconsistent with our government.
Thomas Jefferson
