POV-Ray : Newsgroups : povray.binaries.images : 540k polygon Ajax model Server Time
24 Dec 2025 17:36:51 EST (-0500)
  540k polygon Ajax model (Message 1 to 9 of 9)
Subject: 540k polygon Ajax model
Date: 31 Aug 2008 19:12:13
Message: <48bb254d@news.povray.org>
I'd just, for the first time, started playing with some polygonal models
available on the internet, and I saw a great rendering on the Sunflow
gallery page of a 3D scanned stone bust:
http://sunflow.sourceforge.net/gallery/v0072/statue_ajax-jpeg.jpg
(from the gallery http://sunflow.sourceforge.net/index.php?pg=gall on
Sunflows sourceforge page)
The model itself has about 540,000 polygons, and is available via
http://forum.jotero.com/viewtopic.php?t=3&sid=b917ccdcb01d6651ec313e5192f9faf2
Since I'd not used high poly count models, or focal blur much, I though
I'd just try to re-render the Sunflow picture using POVRay.
The test renders took about an hour or so, but for the final render I
pumped up the settings and went to bed - I probably set them too high,
as the render time was 10 hours 57 minutes in the end.
The focal blur was set to 100 samples, radiosity to 5 bounces,
error_bound to 0.5, and the count to 900.
I converted the model using using Cross Roads 3D - which gave me a 142M
POV source file. Are there any other utilities that can convert other 3D
formats to POVRay? Something that supported mesh2 might be nice for example.
The model is lit from a single point light source, but the radiosity
does a great job of making that look pretty realistic. The original
Sunflow picture's author did a great job of posing and lighting the bust
  - there's some real flair in that.
It's interesting to see the differences between the POVRay and Sunfow
renders - I suspect that the Sunflow render was using less bounces.
I converted the HDR output to JPG in Photoshop, and adjusted the
contrast and saturation to make it a closer match to the Sunflow one so
I could compare them side to side.
Cheers,
Edouard.
Download '540k-ajax.jpg' (125 KB)
Preview of image '540k-ajax.jpg'
Subject: Re: 540k polygon Ajax model
Date: 31 Aug 2008 20:12:39
Message: <si7w6KIQNzuIFw8X@econym.demon.co.uk>
>3D formats to POVRay? Something that supported mesh2 might be nice for
>example.
PoseRay will convert the OBJ file to a POV mesh2 object. The result is
54Mb of POV mesh2 data that renders in less than a minute (with just the
single light source that I believe PoseRay pulls from the obj file).
The only awkward thing is that the bust faces away from the camera, and
the camera, light and model are located in illogical places. So I had to
do this to rotate the model and put it back into view.
#declare C =  (min_extent(Poseray_scene_object) +
               max_extent(Poseray_scene_object))/2;
object{
         translate -C
         rotate y*150
         translate C
Mike Williams
Gentleman of Leisure
Date: 31 Aug 2008 20:25:01
Message: <web.48bb35446dd8a1bffd79f3f60@news.povray.org>
Here's what you get straight out of the box with PoseRay.
The only thing I've changed is that I rotated the model, as mention edin thge
previous post.
Download 'ajax_jotero_com.jpg' (60 KB)
Preview of image 'ajax_jotero_com.jpg'
Date: 31 Aug 2008 20:30:06
Message: <48bb378e@news.povray.org>
>> example.
> object{
>          translate -C
>          rotate y*150
>          translate C
Ahhh, great - I'll try with PoseRay in the future. I'd read that mesh2
objects both parse faster, and take less space, both of which are good!
I think the raw render speed was about the same - a minute or so with a
single light source, and no radiosity or focal blur.
Thanks for the info!
Cheers,
Edouard.
Date: 31 Aug 2008 20:32:42
Message: <48bb382a@news.povray.org>
> previous post.
It's slightly hard to tell, but it looks like PoseRay also gets the
proper smoothing of the polygons right as well - Cross Roads 3D seemed
to leave me with a lot of planar polygons from it's cpomversion, even
after I chose the "smooth triangles" option.
Thanks again for the pointer!
Cheers,
Edouard.
Date: 2 Sep 2008 12:36:32
Message: <48bd6b90$1@news.povray.org>
Edouard Poor nous illumina en ce 2008-08-31 19:11 -->
> Cheers,
> Edouard.
Radiosity with 5 bounces. Very slight time effect here. In that scene, most
radiosity ray hit the backgrouns after the first bounce. Whenever you reach the
background, you stop. You may also reach the adc_bailout well before you've done
all the bounces. You should see little to no difference between 3 and 5 bounces
in both time and quality.
You know you've been raytracing too long when you wonder if ground fog or
athmosphere will look better for your company's market share pie chart.
Christoph Rieder
Date: 2 Sep 2008 15:24:34
Message: <48bd92f2$1@news.povray.org>
I think you succeeded superbly in your lighting. Even with such a
simple trivial texture it looks very good.
Date: 2 Sep 2008 18:40:00
Message: <web.48bdc0756dd8a1bf2e8115d20@news.povray.org>
I can't take any credit for the lighting and positioning of the statue - all I
did was copy the rendering on the Sunflow site as closely as I could - the
credit belongs to whoever did that original rendering ("Tartiflette" is all the
Sunflow page says).
There is no texturing either - just a slightly off-white pigment. It was the
inter-reflective lighting, simulated through radiosity in POVRay, that I found
fascinating.
Cheers,
Edouard.
Date: 4 Sep 2008 04:55:00
Message: <web.48bfa0fe6dd8a1bf12a5893a0@news.povray.org>
Superb image.
"Edouard Poor" <pov### [at] edouardinfo> wrote:
> It was the inter-reflective lighting, simulated through radiosity in POVRay, > that
I found fascinating.
> Cheers,
> Edouard.
you can give an example?
