POV-Ray : Newsgroups : povray.binaries.images : The Last Man On Earth Server Time
13 Apr 2026 22:53:26 EDT (-0400)
  The Last Man On Earth (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: The Last Man On Earth
Date: 24 Jul 2008 03:14:17
Message: <48882bc9$1@news.povray.org>
"Bryan Valencia" <no### [at] waycom> schreef in bericht
news:4887f27d$1@news.povray.org...
> ok, maybe I'm just dense (pun intended)
> But I added the 2 densities and my media effect disappeared while the sky
> was still white.
> This is my media
> media {
>   intervals 20
>   scattering { 4, rgb 0.01 }
>   samples 2, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9
> //   density {planar scale y*5 }
> //   density {granite scale 0.1}
> The two // lines are the ones I added.
As a start, try this from one of my scenes. The parameter SkyScale scales
the sphere used as a sky.
Also, remember to always use intervals = 1 as the default method is 3.
//start code
background {Black}
sphere { <0, 0, 0>, 1
  texture {pigment {rgb 0 transmit 1} }
  interior_texture {
      gradient y
      color_map {
        [0.0 rgb <0.6,0.7,1.0>*0.3 transmit 0.3]
        [0.7 rgb <0.0,0.1,0.8>*0.3 transmit 0.3]
    finish {ambient 1 diffuse 0}
  scale SkyScale
  hollow
  #if (Atmo)
    interior {
      media {
        intervals 1
        scattering {2, rgb 0.3/SkyScale}
        samples 300
        confidence 0.9999
        variance 1/1000
        ratio 0.9
//end code
Date: 24 Jul 2008 11:56:00
Message: <4888a610$1@news.povray.org>
Bryan Valencia nous illumina en ce 2008-07-23 23:09 -->
> Alain wrote:
>> Bryan Valencia nous illumina en ce 2008-07-23 17:30 -->
>>> First W.I.P.
>>> I wish there was a way to make the atmosphere thin enough to still
>>> see the colors of the sky sphere.
>> With various patterns, you can make thick enough near the ground but
>> thin enough so that you can still see the sky.
>> Try the planar pattern. It evaluate as 1 on the x-z plane and drop
>> linearly to zero one unit up and down. You just need to scale it
>> apropiately. You can also use some of the wave forms variations to
>> change the rate ov change.
>> scalop_wave will stay high near the ground and drop sharply near the
>> top for example.
> sky was still white.
> This is my media
>     media {
>       intervals 20
>       samples 2, 10
>       confidence 0.9999
>       variance 1/1000
>       ratio 0.9
If your sky is still white, maybe your sky have a problem. Completely remove the
media and see if the sky is OK.
Concerning your media:
The default method is method 3. With this method, you should keep intervals 1
and increase samples. Also, this method only use the first samples value and
ignore the second value. The documentation have not been updated for version 3.6
and is only correct if you use method 1 or 2.
The defaults are:
method 3
intervels 1
samples 3
Made a test scene, background used for a blue sky.
Try with the planar pattern enabled, OK. Media present, sky visible.
Uncomment the granite density. Much slower, (may be beter to use some
turbulence) "sky" still visible, media present.
SHOPPING MATH
A man will pay $20 for a $10 item he needs.
A woman will pay $10 for a $20 item that she doesn't need.
Date: 25 Jul 2008 18:46:06
Message: <488a57ae@news.povray.org>
well I'm sure I did this wrong, but there was no combination that I could get the
results I wanted.
	media {
		method    3
	  intervals 1
	  scattering { 2, rgb 0.0002 }
	  samples 10, 1000
	  confidence 0.9999
	  variance 1/1000
	  ratio 0.9
	  density {planar scale y*55 }
	  //density {granite turbulence 2 scale 0.1}
	  density {bumps turbulence 2 scale 20}
gives this.
Download 'media-atmosphere2.jpg' (66 KB) Download 'media-atmosphere3.jpg' (89 KB)
Preview of image 'media-atmosphere2.jpg'
Preview of image 'media-atmosphere3.jpg'
Date: 25 Jul 2008 18:50:49
Message: <488a58c9$1@news.povray.org>
I tried these setting Thomas and it took an hour to render 1/8th of the picture.
Honestly, there MUST be a better way.
Date: 26 Jul 2008 05:32:45
Message: <488aef3d$1@news.povray.org>
news:488a58c9$1@news.povray.org...
>picture.
Hmm. Mostly the sky and buildings would take time I suppose. The lower half
should be faster. Nonetheless, the slowness seems not too prohibitive to me.
In a two pass render, it would perhaps be more efficient.
Date: 26 Jul 2008 14:23:39
Message: <488b6bab$1@news.povray.org>
Bryan Valencia nous illumina en ce 2008-07-25 18:46 -->
> could get the results I wanted.
>     media {
>         method    3
>       intervals 1
>       samples 10, 1000
This does the same: samples 10
>       confidence 0.9999
>       variance 1/1000
>       ratio 0.9
> gives this.
Geting beter, at least, now, you can see the sky.
You may try using 2 medias:
The current one and one, thinner, using scattering{4, rgb<0,0.2,1>*0.00001 ...}
   My wife is such a bad cook, in my house we pray after the meal.
   	Rodney Dangerfield
Subject: Re: The Last Man On Earth (I give up)
Date: 28 Jul 2008 00:19:40
Message: <488d48dc$1@news.povray.org>
I give up.
No matter what I try (and I have wasted about 16 hours on it) the atmosphere effect I
want is always gone well before I
can see any sky.  Geez, this is just too f'ing hard.
Date: 28 Jul 2008 16:20:01
Message: <web.488e29a9c102e2e8dc0a30e20@news.povray.org>
> > First W.I.P.
> > I wish there was a way to make the atmosphere thin enough to still see
> With various patterns, you can make thick enough near the ground but thin enough
> Try the planar pattern. It evaluate as 1 on the x-z plane and drop linearly to
> zero one unit up and down. You just need to scale it apropiately. You can also
> use some of the wave forms variations to change the rate ov change.
> scalop_wave will stay high near the ground and drop sharply near the top for
> example.
> Alain
> Agnostic: What is this shit?
The Agnostic is not living a significant life. Such was only meant to be known
on a personal level. Whats worse is, if you had a reason to know but forgot.
Date: 29 Jul 2008 13:51:36
Message: <488f58a8@news.povray.org>
web.488e29a9c102e2e8dc0a30e20@news.povray.org...
please define "significant life"
Marc
Date: 29 Jul 2008 16:18:55
Message: <488f7b2f@news.povray.org>
alphaQuad nous illumina en ce 2008-07-28 16:18 -->
An agnostic don't beleive in a God. It don't mean that he don't beleive in some
Greater Power. An agnostic will NEVER say that there is no God, like an atheist
does...
You know you've been raytracing too long when you call in sick in order to render.
David Kraics
