POV-Ray : Newsgroups : povray.binaries.images : PoVEarth, day #6 - first obstacle! Server Time
26 Jul 2026 12:55:35 EDT (-0400)
  PoVEarth, day #6 - first obstacle! (Message 11 to 13 of 13)
Subject: Re: PoVEarth, day #6 - first obstacle!
Date: 31 Jul 2008 17:40:52
Message: <48923164@news.povray.org>
High!
Reactor schrieb:
> I can see some artifacts that may be from your radiosity settings.  Can you post
> your code?  If not, I recommend lowering your error bound to about 1/3 to 1/4 of
> what it is.  Since a lot of the light is to be reflected from the bright, fully
> lit corner, changing the error bound may increase the brightness in this case.
> There are some other settings changes that I think you should consider also.
I increased count to 200 and lowered error_bound to 0.45... but the
result (see attachment) did not improve significantly!
Perhaps it's because the rear walls are not close enough as I did not
yet add the interior walls separating the apartments and rooms...
The code:
// My Place in the World
// A sub-sub-subsection of the PoVEarth project
// E-mail: yaz### [at] gmxde
// RADIOSITY
#declare radio=1;
global_settings
   #if (!radio)
     ambient_light 0.15
   #else
     ambient_light 0
     radiosity
       brightness 1
       adc_bailout 0.01
       gray_threshold 0.8
       recursion_limit 20
       count 200
       error_bound 0.45
// TIME VARIABLES
// PIGMENTS
#declare P_Concrete =
pigment
   color rgb 0.9
// FINISHES
#declare F_Standard =
finish
   diffuse 1
   brilliance 0.15
// NORMALS
// TEXTURES
#declare T_Concrete =
texture
   pigment { P_Concrete }
   finish { F_Standard }
// LENGTH VARIABLES
#declare FrKarl_SideStreet_Width = 6.09;
#declare FrKarl_SideStreet_Pavement_Width = 1.32;
#declare GWG_FrKarl_Block238to252_Front_Way_Length = 4.09;
#declare GWG_FrKarl_Block238to252_Front_Doorstep_Depth = 0.427;
#declare GWG_FrKarl_Block238to252_Stair_Height = 0.168;
#declare GWG_FrKarl_Block238to252_Floor_Height = 16 *
GWG_FrKarl_Block238to252_Stair_Height;
#declare GWG_FrKarl_Block238to252_Floor_yOffset = 8 *
#declare GWG_FrKarl_Block238to252_Ceiling_Thickness = 0.148;
#declare GWG_FrKarl_Block238to252_Balcony_Spacing=9.19;
// OBJECT DEFINITIONS
#declare GWG_FrKarl_Block238to252_Raw=
box
   0, <11.08, 9.523, 53.49>
#declare GWG_FrKarl_Block238to252_Balcony_Raw=
difference
   box
     0, <1.155, 0.948, 3.24>
   box
     <0.165, 0.148, 0.155>, <1.65, 0.95, 3.085>
#declare GWG_FrKarl_Block238to252_Floor_Cutout =
box
   0, <10.34, 2.54, 52.75>
#declare GWG_FrKarl_Block238to252_Balcony_Door_Cutout =
box
   0, <0.38, 2.14, 1.14>
// CAMERA SETTINGS
// using microlocal coordinates
#declare view=5;
#switch(view)
   #case (0) // pedestrian view on side street, up building #246
     #declare camPos = <-8, 1.7, 10>;
     #declare camLook = <1, 7.2, 3>;
     #declare camAng = 40;
   #break
southward along side street
     #declare camPos = <-(FrKarl_SideStreet_Width / 2 +
FrKarl_SideStreet_Pavement_Width +
GWG_FrKarl_Block238to252_Front_Way_Length +
                        GWG_FrKarl_Block238to252_Front_Doorstep_Depth),
1.7, 70>;
     #declare camLook =<-(FrKarl_SideStreet_Width / 2 +
1.7, 0>;
     #declare camAng = 60;
   #break
   #case (2) // pedestrian view on side street, up building #244
     #declare camLook = <-30, 7.2, 0>;
   #break
   #case (3) // inside 1st floor of building #244, looking east
     #declare camPos = <-25.5, 5.9, 2.5>;
     #declare camLook =<-16, 4.6, 2.5>;
   #break
   #case (4) // inside 1st floor of building #244, balcony door
threshold close-up
     #declare camPos = <-17.9, 5.5, 2.5>;
     #declare camLook = <-17.76, 3.5, 2.5>;
   #break
   #case (5) // inside my apartment, looking west
     #declare dir = 270;
     #declare azi = -10;
     #declare camPos = <4.2, 40 * 0.168 + 1.7, 2.5>;
     #declare camLook = camPos + < sin(radians(dir))*cos(radians(azi)),
sin(radians(azi)), cos(radians(dir))*cos(radians(azi))>;
     #declare camAng = 50;
   #break
// ACTUAL SCENE
#declare detail=0;
#if (!detail) // full scene views
   // SCALE MODELS
   #declare models = array[5] { 0, 0, 0, 1, 0 }
   // models[0]: cosmic scale - whole Solar System, heliocentric
   // models[1]: global scale - Earth, geocentric, spherical terrain relief
   // models[2]: regional scale - 40 x 40 kms area around Cologne,
heightfield
   // models[3]: local scale - 500 x 500 metres around my apartment, plane
   // models[4]: microlocal - my apartment only, outside world only as
HDRI bitmaps
   #declare a=0;
   #declare i=0;
   #while (a<5)
     #if (models[a])
       #declare i=i+1;
     #declare a=a+1;
   #if (!i | i>1)
     #warning "Missing or ambiguous scale setting" // terminating POV script
   #else
     #if (models[0])
       #declare f=1000000 // 1 unit = 1000 kms
     #if (models[1])
       #declare f=1000; // 1 unit = 1 km
     #if (models[2] | models[3] | models[4])
       #declare f=1; // 1 unit = 1 metre
     #if (models[3])
       #declare trans=<251.565, 0, 250.325>;
    // #declare f=1;
     #if (models[3])
       light_source
         <0, 500, -1000>
         color rgb 1
     #if (models[2] | models[3])
       plane
         y, 0
         texture // bare sandy soil
           pigment { color rgb <0.5, 0.35, 0.2> }
     #if (models[3])
       sky_sphere
         pigment
           gradient y
           color_map
             [0 rgb <0.7, 1, 1>]
             [0.25 rgb <0, 0.5, 1>]
             [1    rgb <0, 0.5, 1>]
#250 and #252
       union
         object
           scale 1/f
         #declare a=0;
         #while (a<3) // 3 floors with balconies
           #declare b=0;
           #while (b<2) // 2 balconies per floor
             object
               scale 1/f
               translate <-1.155 +b * 0.515,
GWG_FrKarl_Block238to252_Floor_yOffset + a *
GWG_FrKarl_Block238to252_Floor_Height - 0.148, 1.045 + b *
                          GWG_FrKarl_Block238to252_Balcony_Spacing>/f
             #declare b = b + 1;
           #declare a = a + 1;
       #declare a=0;
       #while (a<3)
         object
           scale 1/f
           translate <0.37, GWG_FrKarl_Block238to252_Floor_yOffset + a *
GWG_FrKarl_Block238to252_Floor_Height, 0.37>
         #declare a = a + 1;
       #declare a=0;
       #while (a<3)
         #declare b=0;
         #while (b<2)
           object
             scale 1/f
             translate <-0.005,
		      GWG_FrKarl_Block238to252_Floor_yOffset + 0.00001 + a *
                       1.86 + b *
GWG_FrKarl_Block238to252_Balcony_Spacing + 0.4>/f
           #declare b = b + 1;
         #declare a = a + 1;
       translate trans/f
       texture { T_Concrete }
#242 and #244
       union
         object
           scale 1/f
         #declare a=0;
           #declare b=0;
             object
               rotate y*180
               scale 1/f
               translate <11.08 + 1.155 - b * 0.515,
			1.045 + 3.24 + b * GWG_FrKarl_Block238to252_Balcony_Spacing>/f
             #declare b = b + 1;
           #declare a = a + 1;
       #declare a=0;
       #while (a<3)
         object
           scale 1/f
         #declare a = a + 1;
       #declare a=0;
       #while (a<3)
         #declare b=0;
         #while (b<2)
           object
             scale 1/f
             translate <10.705,
                       1.86 + b *
           #declare b = b + 1;
         #declare a = a + 1;
       translate (< -((FrKarl_SideStreet_Pavement_Width +
                    GWG_FrKarl_Block238to252_Front_Doorstep_Depth)*2 +
                    FrKarl_SideStreet_Width)-11.08,
                    0,
                    0 > + trans)/f
     camera
       location camPos/f +trans
       look_at camLook/f +trans
       angle camAng
#else // single detail views
   sky_sphere
     pigment { color rgb 1 }
   plane
     y, 0
     texture
   light_source
     <1000, 2000, -4000>
     color rgb 1
   object
     GWG_FrKarl_Block238to252238to252_Balcony_Raw
   camera
      location <8, 1.5, 1.6>
      look_at  <0, 0.5, 1.6>
      angle 40
Download '2008-07-31 inside my apartment, take 2 (yadgar).jpg' (15 KB)
Preview of image '2008-07-31 inside my apartment, take 2 (yadgar).jpg'
Date: 1 Aug 2008 10:40:01
Message: <web.48931f7951b8f74a5206c9930@news.povray.org>
=?ISO-8859-1?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> High!
> The code:
Unfortunately, I wasn't able to get the indoors much brighter without
brightening the outdoors.  I was playing with 'exposure' under MegaPov 1.21.
The only thing I can recommend is using a different diffuse value for indoors
(like 1.00) and outdoors (like 0.50), and boosting the brightness in the
radiosity block.
HTH
-Reactor
Date: 1 Aug 2008 11:17:26
Message: <48932906$1@news.povray.org>
Just as an aside:
density of light that falls on a surface. This is what light
meters measure. For example, average indoor lighting
ranges from 100 to 1,000 lux, and average outdoor
sunlight is about 50,000 lux.
expressed as candelas per square meter of light emitting
surface. [...] For
example, the luminance of a heavily overcast sky is about
1,000 candelas per square meter, and the luminance of
a typical frosted light bulb is about 100,000 candelas
per square meter.
http://www.energybooks.com/pdf/D1150.pdf
There might be a good reason getting this to work takes some extreme
values. :-)  Eyeballs are pretty amazing devices.
