POV-Ray : Newsgroups : povray.binaries.images : Porous Rock Server Time
26 Mar 2026 00:54:49 EDT (-0400)
  Porous Rock (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Porous Rock
Date: 12 Jul 2008 07:20:32
Message: <in4h74tllnc5r82ropj3sg006boujelu77@4ax.com>
Wow, thats fantastic. Can I ask how the isosurface was defined ? i.e.
is it a sphere - this pattern ? Or am i way off base !
On Fri, 4 Jul 2008 21:06:51 +0100, "Tek" <tek### [at] evilsuperbraincom>
wrote:
>I was messing around with some multifractals and came up with this. It's
>based on a crackle form <1,0,0> repeated like a perlin multi-fractal over 8
>octaves. The heightfield renders pretty quick (19 minutes) but the isosurfae
>took an amazing 9 hours!
>Here's the code for the pattern, the Curve value adjusts how the holes look.
>Have a look at p.b.a to see what happens when I animate that value!:
>pigment {
> #local Curve=1/8; // small values make it look porous
> #local Omega=0.5;
> #local Lambda=2;
> #local Octaves=8;
> pigment_pattern {
>  average
>  pigment_map {
>   #local octave=0;
>   #while ( octave < Octaves )
>    [pow(Omega,octave)
>     pigment_pattern {
>      crackle form <.9,0,0>
>      scale pow(Lambda,-octave)
>      colour_map {[0 rgb 1][1 rgb 0]}
>     poly_wave 1/Curve
>    #local octave=octave+1;
>   #end
> poly_wave Curve
Date: 12 Jul 2008 14:08:22
Message: <4878f316$1@news.povray.org>
"Rob Richards" <ari### [at] btinternetcom> wrote in message
news:in4h74tllnc5r82ropj3sg006boujelu77@4ax.com...
You're exactly right, sphere - pattern.
Tek
http://evilsuperbrain.com
Date: 13 Jul 2008 19:28:48
Message: <487a8fb0@news.povray.org>
news:4878f316$1@news.povray.org...
> Tek
Hmmm, there must be something I'm doing really wrong then as all I can get
out of this is a flat textured shape, I dont get any porous effects at all!
If I render it as a hightfield it also looks totally wrong :(
Meh, goes back to fiddle some more...
Cheers Dre
Date: 13 Jul 2008 22:35:00
Message: <web.487abb1b1771580b302c26d00@news.povray.org>
> Cheers Dre
I'm guessing that you're supposed to use it as an object pattern. Basically, an
object pattern is a pattern turned into an object that you can use in CSG.
-Mike
Date: 13 Jul 2008 22:40:01
Message: <web.487abbde1771580b302c26d00@news.povray.org>
It looks incredible! I'm wondering what the results would be in terms of
rendering times if you used a mesh instead of an isosurface. I know there's an
external utitlity to replace parametric objects with meshes. I can't recall if
there's also one for isosurfaces.
Of course, the typical parametric curve tends to be much smoother than the
object you've created here. Not sure if this is the ideal application for
meshes.
-Mike
Date: 14 Jul 2008 00:05:15
Message: <487ad07b@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.487abb1b1771580b302c26d00@news.povray.org...
>> get
>> all!
>> Cheers Dre
> Basically, an
> -Mike
hmm, still above my abilities, I'll keep reading...
Thanks for the info though.
Cheers Dre
Date: 14 Jul 2008 01:05:01
Message: <web.487addc91771580b302c26d00@news.povray.org>
> > Basically, an
> > -Mike
> Cheers Dre
Doh! I got that completely backwards! An object pattern is an *object* that is
turned into a *pattern*, not the other way around. Sorry!
-Mike
Date: 14 Jul 2008 01:32:20
Message: <+9fE9HBAMueIFwOY@econym.demon.co.uk>
Wasn't it Dre who wrote:
>"Tek" <tek### [at] evilsuperbraincom> wrote in message
>> Tek
It goes something like this:
#version 3.6;
global_settings {assumed_gamma 1.0}
camera {location  <0,0,-10> look_at <0,0,0>}
background {rgb <.8,.8,1>}
light_source {<-30, 100, -30> color rgb 0.5}
light_source {<0, 10, -30> color rgb 0.5}
#declare P = function{pigment {
 #local Omega=0.5;
 #local Lambda=2;
 #local Octaves=8;
 pigment_pattern {
  average
  pigment_map {
   #local octave=0;
    [pow(Omega,octave)
     pigment_pattern {
     poly_wave 1/Curve
 poly_wave Curve
#declare  S = function {x*x + y*y + z*z - 1}
isosurface {
  function { S(x,y,z) - P(x,z,y).grey*2 }
        max_gradient 70
        contained_by{sphere{0,1.5}}
        pigment {rgb 1}
  scale 3
I've not done any radiosity or other fancy rendering on this, so it
renders a bit faster but doesn't look as good.
Try tweaking the numbers in "grey*2" and "scale 3".
Mike Williams
Gentleman of Leisure
Date: 14 Jul 2008 02:00:42
Message: <487aeb8a@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:+9fE### [at] econymdemoncouk...
>>> Tek
>>all!
> #version 3.6;
> #local Omega=0.5;
> #local Lambda=2;
> #local Octaves=8;
> pigment_pattern {
>  average
>  pigment_map {
>   #local octave=0;
>    [pow(Omega,octave)
>     pigment_pattern {
>     poly_wave 1/Curve
>   #end
> poly_wave Curve
> isosurface {
>        max_gradient 70
>        pigment {rgb 1}
>  scale 3
> Mike Williams
Whoa, okay so I was waaaaaaay off base here!
But I now know where I went wrong (massivly wrong, hehehe).  I'm still
learning how to use isosurfaces properly and that was my mistake, thanks
very much for that bit of code, thats cleared that up for me nicely.
Now to start playing around!
Cheers Dre
Date: 14 Jul 2008 02:01:21
Message: <487aebb1$1@news.povray.org>
news:web.487addc91771580b302c26d00@news.povray.org...
>> > Basically, an
>> > CSG.
>> > -Mike
>> Cheers Dre
> that is
> -Mike
Thats ok I was way off anyway, its been cleared up now though so all good!
Cheers Dre
