The best greebles I've seen so far!
-Nekar Xenos-
"Nekar Xenos" <nek### [at] gmail com> schreef in bericht
news:483a4f88@news.povray.org...
...because Zeger is the king of greebles! :-)
Very well done! An extension to the existing macros?
"William Tracy" <wtr### [at] calpoly edu> wrote in message
news:483a4a38$1@news.povray.org...
>I think you have outdone yourself.
well, it's not finished yet, so hopefully it'll become even better :)
cu!
_(0x+y.5+y/2x)_(0x-y.5+y/2x) // ZK http://www.povplace.com
"Nekar Xenos" <nek### [at] gmail com> wrote in message
thank you!!
cu!
"Thomas de Groot" <t.d### [at] inter nlDOTnet> wrote in message
news:483a6461$1@news.povray.org...
originally I was going to rewrite all greeble-macros, to make them more
consistent in use, but then I realized it might be a better idea to
generalize them all into a Parametric-Greebles-macro. Only the
polygon-greebles can't be emulated with this macro.
cu!
Lol, the name "Zeger's Greebles" is forever imprinted into my brain...
BTW, nice greebles, Zeger. It would be nice to see some other
structures, like the Millenium Falcon has. Good work, getting them to
twist with the helix like that.
Sam
Wow! That's incredible!
Can the macro/scene be configured to output the necessary maps for importing
into other software?
-Mike
"Zeger Knaepen" <zeg### [at] povplace com> wrote:
> Syntax is like this:
> ---START CODE---
> //This macro defines the shape, it should be defined before using
> GreebledPatch(..)
> //and redefined everytime you want a different shape
> #macro PatchAt(U,V)
> #local R=[Surface-definition in function of U and V];
> //for example, a cylinder from y=0 to y=1 with radius .2 would be:
> //#local R=vrotate(x*.2+y*U,y*360*V);
> R
> #end
> mesh {
> GreebledPatch(U_Start,V_Start, U_End,V_End, RecursionDepth,
> Recursion_U_Probability, Recursion_V_Probability)
> uv_mapping
> texture {YourTexture}
> ---END CODE---
> Hope you like it :)
love it
Understood most of it except the part about actually implementing PatchAt, not
called in this example. Over my head but so close I got a haircut.
"SharkD" <nomail@nomail> wrote in message
news:web.4867cc1a23a83e25feb17ab00@news.povray.org...
thank you!
> importing
I suppose it would be possible, as it's one big trianglemesh
As soon as I find the time to finish the macros, I'll see what I can do :)
cu!
"alphaQuad" <alp### [at] earthlink net> wrote in message
news:web.48691a5123a83e2534ef70380@news.povray.org...
> love it
thanks !
> not
the PatchAt-macro is actually more like a function that is used by the
greebles-system. The macro accepts 2D-coordinates as input, and outputs the
3D-coordinates corresponding with the given 2D-coordinates
cu!
