POV-Ray : Newsgroups : povray.binaries.images : Interlocking heightfields Server Time
8 May 2026 15:43:31 EDT (-0400)
  Interlocking heightfields (Message 11 to 12 of 12)
Subject: Re: Interlocking heightfields
Date: 26 May 2008 07:24:25
Message: <483a9de9@news.povray.org>
Thomas de Groot wrote:
> "John VanSickle" <evi### [at] hotmailcom> schreef in bericht
> news:4835644f$1@news.povray.org...
>> The macro may need tweaking.  The rippling in the left-hand side of the
>> image appears to be an artifact.
> I have been wondering about that. It appears indeed in the close up height
> field blocks.
The macro (IIRC) calculates the number of pixels spanned in any
direction by the heightfield, and sets the height field's resolution to
that value.  It may be that when the line of view is parallel or
near-parallel to the diagonal of the height field, that this is not
quite enough.  Increasing the resolution of the HF (probably by no more
than 40%) should fix this.
The ripple may also be the result of aliasing, in which case the same
remedy--increasing the HF resolution--is called for, but there would
also need to be aa + jittering in the render for the rippling to be
eliminated, if this is the cause.
John
Date: 26 May 2008 11:26:46
Message: <483ad6b6$1@news.povray.org>
news:483a9de9@news.povray.org...
> The macro (IIRC) calculates the number of pixels spanned in any direction
> by the heightfield, and sets the height field's resolution to that value.
> It may be that when the line of view is parallel or near-parallel to the
> diagonal of the height field, that this is not quite enough.  Increasing
> the resolution of the HF (probably by no more than 40%) should fix this.
That is correct. I have introduced a multiplicator to the Details parameter
in the macro, which does a nice job, especially for larger images.
> remedy--increasing the HF resolution--is called for, but there would also
> need to be aa + jittering in the render for the rippling to be eliminated,
Tentatively, I introduced the smooth option in the macro, just to see what
it does. The rippling is further generated I think by the pigment I used,
where a downscaled wrinkle is present. The effect is somewhat lessened if  I
scale it a bit up. However in larger renders, one clearly sees the mesh of
rectangles so increasing the resolution works best.
All in all, using the macro is just to find the settings which will work
best together, which is fun to do.
