POV-Ray : Newsgroups : povray.binaries.images : crackle flagstone floor question Server Time
1 Aug 2026 01:37:21 EDT (-0400)
  crackle flagstone floor question (Message 11 to 17 of 17)
Subject: Re: crackle flagstone floor question
Date: 22 Mar 2008 23:12:10
Message: <47e5d89a@news.povray.org>
Edouard Poor wrote:
> Looks great!
Thanks!
> I may be misunderstanding what you are trying to do, but can you use the
> "solid" keyword with the crackle pattern? That sets each crackle to be a
> solid colour chosen from random from the colour map.
That's exactly what I needed.  I've been able to get pretty similar
results without having to resort to image-editing!  I'm still tweaking
though.
Charles
Date: 22 Mar 2008 23:23:02
Message: <47e5db26@news.povray.org>
Tek wrote:
> Looks good to me! I think the wrinkle looks just right, nice and subtle. I
> think the edges look a bit odd, I'd expect them to be more vertical in
> places (obviously awkward in a height_field).
 From the work I've seen of yours, that's something.  :)  Yeah, the
insides of the cracks seem a bit 'round' to me.  I can narrow the cracks
and I noticed that the amount of turbulence seems to have a pretty big
affect on the size of the rubbley areas.  But I kinda like having
rubbley areas...   I'll try your code to see what it looks like
(Thanks!), although I do generally like to write my own.  I've been
playing with 'form' some today which seems to be a quicker way of
shaping the stones than what I'd been doing before with more pigment_map
entries.
Charles
Date: 23 Mar 2008 00:16:41
Message: <47e5e7b9@news.povray.org>
It's a little darker, but now it's pure POV albeit still using two
images to avoid re-generate it each time.  Thanks again everyone.
Charles
Download 'crackle flagstone floor without gimp.jpg' (171 KB)
Preview of image 'crackle flagstone floor without gimp.jpg'
Date: 23 Mar 2008 04:49:21
Message: <47e627a1$1@news.povray.org>
"Charles C" <"nospam a nospam.com"> wrote in message
news:47e5db26@news.povray.org...
> I'll try your code to see what it looks like (Thanks!), although I do
Good for you! I was just writing that 'cause I felt I could explain more
clearly in code :)
>  I've been playing with 'form' some today which seems to be a quicker way
> of shaping the stones than what I'd been doing before with more
> pigment_map entries.
metric is also fun to play with. High values like metric 100 give  more
organized patterns, not suitable for flagstones but useful for other stuff.
Tek
http://evilsuperbrain.com
Date: 23 Mar 2008 04:52:17
Message: <47e62851$1@news.povray.org>
Nice work, it looks practically identical!
Tek
news:47e5e7b9@news.povray.org...
> Charles
Date: 23 Mar 2008 16:03:07
Message: <47e6c58b$1@news.povray.org>
Charles C wrote:
> After actually trying it though, on this particular machine it's taking
> longer to re-generate it than it is to load an image so I may end up
> sticking to images.
I did some experiments a while back with patterns that were around one
gigabyte when written as a TGA. At that point, doing everything in
memory was significantly faster. ;-)
William Tracy
"Once again, the world is saved by the inscrutible machinations of
contract law."
     -- Ubersoft.net
Date: 23 Mar 2008 19:36:16
Message: <47e6f780@news.povray.org>
Charles C wrote:
> This is a height_field (multiple actually, tiled, but not tile-able)
> made from a nine* megapixel .png made of course from an orthogonal view
> of crackle pattern pigment on a plane.  The pigment used for the
> height_field is a *different* .png which is basically the original after
> a few bucket-fills in GIMP with different colors to different 'stones.'
> I could keep-it-in-POV-Ray (no image based height_fields or image_maps)
> if I knew how to give individual stones different colors using crackle.
>  Unfortunately it looks like there's a choice between patterns that can
> give borders to cells, or patterns which can give different colors to
> different cells.
It's simple:  Use the solid cell pattern as the coloring for the centers
of the regions in the mortared cell pattern.
pigment { crackle
   pigment_map {
     [.1 rgb .75]
     [.1 crackle solid
       color_map { [0 rgb <.9,.8,.7>][1 rgb <.7,.6,.5>] }
//  scale, rotate, and transform to taste
If you base the height_field off of a pigment instead of an image file,
then you can use a suitable solid pattern to color the stones.  Then use
another pigment_based height_field to generate the mortar.
Hope this helps,
John
