POV-Ray : Newsgroups : povray.binaries.images : Ping Pong Server Time
13 Jun 2026 04:56:26 EDT (-0400)
  Ping Pong (Message 1 to 10 of 34)
Subject: Ping Pong
Date: 20 Mar 2008 03:45:39
Message: <47e22433$1@news.povray.org>
Hear's my suggestion for this ping-pong round.
-Nekar Xenos-
  Planet isosurface from Jaime Vives Piqueres's moon.
global_settings{
 assumed_gamma 1.0
 max_trace_level 20
#default{texture{finish{ambient 0}}}
#include "functions.inc"
#declare Modelling=off;
#declare ShowPlanet=on;
#declare ShowWater=on;
#declare ShowClouds=on;
#declare ShowRings=on;
// *** PLANET ***
// planet texture
#declare t_planet=
pigment{
          onion    warp { turbulence 0.1 /*lambda 33 */ }
          color_map{
                   [.7 rgb <.3,.2,.05>] // sand
                   [.8 rgb <0,.1,0>]    // green
                   [.99 rgb <.1,.05,.01>]//<.1,.2,.01>]      // green
                 scale 1/(<1.01,.995,1.01>)
#declare t_planet=
texture{
 pigment{
          onion    scale <1.01,.995,1.01>
          turbulence .05
          lambda 2.5
          omega 1.2
          pigment_map{
                   [0 rgb 1]
                   [.05  t_planet ]
                   [.95  t_planet ] // sand
                   [1 rgb 1]//<.1,.2,.01>]
#if(!Modelling)
        normal{granite .001 scale .00001}
finish{specular .1 }
#declare Scalar=<4,1,4>;
#declare Rotar=<-15,0,0>;
// Cloud texture
#declare t_clouds=
texture{
         pigment{
                  wrinkles  scale <100,50,100>*22
                  turbulence <1,2,1>
                  lambda 2.5
                  omega 1.3
                  warp { turbulence <10,0,10>*.1
                        //lambda 3
                        omega 1.2
                  color_map{
                           [0 rgb 1 transmit 1]
                           [.3 rgb 1 transmit .9]
                           [1 rgb 1 transmit 0]
                  rotate y*15
                  scale<0.021,0.02,0.021>/Scalar
                  rotate -Rotar
// Cloud texture
#declare t_clouds=
texture{ wrinkles  rotate Rotar
                  scale Scalar
                  //lambda 2.5
                  omega 1.3
                  texture_map{
                           [0 t_clouds ]
                           [.3 pigment {rgb 1 transmit 1}]
                           [.5 t_clouds]
                           [.7 pigment {rgb 1 transmit 1}]
                           [1 t_clouds ]
// Planet
#declare Planet=
union{
        isosurface{  // Copied from Jaime's LightSys Space Demo scene
                 function{(x*x+y*y+z*z-1)+f_granite(x*2,y*2,z*2)*f_agate(x,y,z)*.05}
                 max_gradient 3.8
                 contained_by{sphere{0,1}}
                 texture{t_planet scale .02}
                 scale y*1.002
       #if(ShowWater)
               sphere{0,1 // water
                      pigment{gradient y scale 2 translate y
                              turbulence .1
                               lambda 7
                             colour_map{
                                      [0 rgbt<1,1,1,0> ]
                                      [.15 rgb <0,.05,.2> transmit
.3*(!Modelling)]
                                      [.9 rgb <0,.05,.2> transmit
.3*(!Modelling)]
                                      [1 rgbt<1,1,1,0> ]
                      finish{specular .2  metallic brilliance 2}
                      #if(!Modelling)
                         interior{fade_distance .003 fade_color rgb
<0,0,.1>}
                      scale .996
      #if(!Modelling)
              sphere{0,1 // Atmosphere
                      pigment{colour rgbt 1}
                      interior{
                               media {
                                          // (---general values---)
                                          intervals 10           // number
of intervals used for sampling [10]
                                          samples 1,1            // minimum
and maximum number of samples taken per interval [1,1]
                                          confidence 0.9         //
statistic parameter higher->better quality [0.9]
                                          variance 1.0/128       //
statistic parameter lower->better quality [1.0/128]
                                          ratio 0.9              //
distribution between lit and unlit areas [0.9]
                                          // (---media types---)
                                          //absorption rgb<.1,.05,0>*.001
// absorbing media, block light of specified color
                                          scattering {2, rgb 10 }
                                          //method 3               //
adaptive sampling
                                          density {onion
                                                   color_map{
                                                           [.89 rgb .5]
// earth
                                                           [.93 rgb
<0,.5,.6>*.5]//
                                                           [.98 rgb
<0,0,.1>]//
                                                           [1 rgb 0 ]//
                      rotate y*90
                      scale 1.05
                      hollow
                      double_illuminate
       #if(ShowClouds)
               union{
                      sphere{0,1.01 texture{t_clouds }}
                      rotate y*45
                      hollow //double_illuminate
// placement
union{  #if(ShowRings)
        disc {<0, 0, 0>  y, 1.0, .7        // -O- RINGs -O-
                        pigment{spherical
                                cubic_wave
                                colour_map{
                                           [0 rgbft <0,0,0, 1,1>]
                                           [.01 rgbft <.4,.3,.2, 0,.1>]
                                           [.015 rgbft <.3,.3,.3, .1,.7>]
                                           [.03 rgbft <.35,.3,.25, 0,.1>]
                                           [.04 rgbft <.1,.21,.3, .1,.9>]
                                           [.07 rgbft <.3,.21,.1, .2,.5>]
                                           [.12 rgbft <.25,.2,.15, 0,.1>]
                                           [.18 rgbft <.2,.2,.25, .1,.7>]
                                           [.20 rgbft <.3,.2,.1, 0,.1>]
                                           [.22 rgbft <0,0,0, 1,1>]
                        finish{diffuse 1}
                        scale 2
                        hollow
                        double_illuminate
                        rotate <40,0,30>
        object{Planet }
        scale .3
        translate <0,0,0>
light_source{
         0,
         4
         fade_power 2
         translate <2,.1,.5>
camera{
 location <0,.5,0>
 up y
 look_at .5*x //<0,-.3,1> //<0,-.4,1>
Download 'Planet.png' (239 KB)
Preview of image 'Planet.png'
Subject: Re: Ping Pong
Date: 20 Mar 2008 08:45:02
Message: <web.47e2697941aa233d8c12d7010@news.povray.org>
So, do we just download the file, and upload a new copy, with our additions?
Date: 20 Mar 2008 08:49:22
Message: <47e26b62@news.povray.org>
"Nimish Ajmani" <nomail@nomail> wrote in message
news:web.47e2697941aa233d8c12d7010@news.povray.org...
> additions?
Yes.  You can change or add as you like.
I think the previous round it was suggested only 1 change per post. But I
don't think that really matters.
-Nekar Xenos-
Date: 20 Mar 2008 09:40:00
Message: <web.47e2773041aa233d5cffe8340@news.povray.org>
Without AA, I wasn't half way thru the isosurface after 30 minutes rendering.
10 minutes for a mapped sphere.
Any planetarium worth having should have POV scene export capability.
Guess I should add the feature now.
Thank you for posting scene code,
aQ
Download 'planete.jpg' (28 KB)
Preview of image 'planete.jpg'
Date: 20 Mar 2008 09:54:24
Message: <47e27aa0@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> wrote in message
news:web.47e2773041aa233d5cffe8340@news.povray.org...
> rendering.
I first tried rendering mine thought the night on the 500mHz Thinkpad . the
top part was quick, but when it hit the media, it went down to ~10pps. This
morning it was at 80%. When I rendered it here at work on the duelcore it
was finished it ~35min.  :-S
I dream of a procedural Pov planetarium... :-)
This is a ping-pong round - you're supposed to change and post the code  :)
-Nekar Xenos-
Date: 20 Mar 2008 10:35:01
Message: <web.47e2838a41aa233d5cffe8340@news.povray.org>
Me too. I have all the planetarium code in opengl/C and mircscript,
Orbital elements for all known moons, just an export option and we could skip
all the code translation.
http://members.aceweb.com/alphaquad/matrixcap.jpg
well if it has a map ... hmmm I could make jpg out 800k png, as opposed to
zipping for b.s.f ( I dont recall the limit over there )
the comments are wrapping, making for difficult reuse, I've attempted some
repair
****************************** CHANGES ***************************/*
global_settings{
 assumed_gamma 1.0
 max_trace_level 12
// *** PLANET ***
// planet texture
#declare t_planet=
pigment{
          color_map{
#declare t_planet=
texture{
 pigment{
          turbulence .05
          lambda 2.5
          omega 1.2
          pigment_map{
                   [0 rgb 1]
                   [.05  t_planet ]
#declare P_IM_Earth = pigment {
  image_map {
    jpeg "earth1024"
    map_type 1
    interpolate 2
#if(!Modelling)
// Cloud texture
#declare t_clouds=
texture{
         pigment{
                  turbulence <1,2,1>
                  lambda 2.5
                  omega 1.3
                        //lambda 3
                        omega 1.2
                  color_map{
                  rotate y*15
                  rotate -Rotar
// Cloud texture
#declare t_clouds=
                  scale Scalar
                  //lambda 2.5
                  omega 1.3
                  texture_map{
                           [0 t_clouds ]
                           [.5 t_clouds]
                           [1 t_clouds ]
// Planet
#declare PlanetE=
union {
sphere {
 0,1
 texture { pigment { P_IM_Earth } }
#if(!Modelling)
                      interior{
                               media {
  intervals 10 // number of intervals used for sampling [10]
  samples 1,1  // minimum and maximum number of samples taken per interval [1,1]
  confidence 0.9  // statistic parameter higher->better quality [0.9]
  variance 1.0/128   // statistic parameter lower->better quality [1.0/128]
  ratio 0.9      // distribution between lit and unlit areas [0.9]
  //method 3   // adaptive sampling
                           density {onion
                                  color_map{
                                       [.89 rgb .5] // earth
                                       [.93 rgb <0,.5,.6>*.5]//
                                       [.98 rgb <0,0,.1>]//
                                       [1 rgb 0 ]//
                      rotate y*90
                      scale 1.05
                      hollow
                      double_illuminate
#declare Planet=
union{
                 max_gradient 3.8
                 scale y*1.002
       #if(ShowWater)
               sphere{0,1 // water
                              turbulence .1
                               lambda 7
                          colour_map{
                             [0 rgbt<1,1,1,0> ]
                             [.15 rgb <0,.05,.2> transmit .3*(!Modelling)]
                             [.9 rgb <0,.05,.2> transmit .3*(!Modelling)]
                             [1 rgbt<1,1,1,0> ]
                      #if(!Modelling)
                         interior{fade_distance .003 fade_color rgb <0,0,.1>}
                      scale .996
      #if(!Modelling)
                      interior{
                           media {
                                density {onion
                                          color_map{
                                                           [1 rgb 0 ]//
                      rotate y*90
                      scale 1.05
                      hollow
                      double_illuminate
       #if(ShowClouds)
               union{
                      rotate y*45
// placement
        disc {<0, 0, 0>,  y, 1.0, .7        // -O- RINGs -O-
                        pigment{spherical
                                cubic_wave
                                colour_map{
                        finish{diffuse 1}
                        scale 2
                        hollow
                        double_illuminate
                        //rotate <40,0,30>
        object{PlanetE rotate <0,180,0> }
        scale .3
        rotate <0,0,24>
        translate <0,0,0>
light_source{
         <100,.1,100>,
         2
         fade_power 2
         //translate <2,.1,.5>
camera{
 location <0,.5,-3>
 //up y
 //look_at .5*x //<0,-.3,1> //<0,-.4,1>
 look_at <0.3,0.15,0>
 angle 12
Download 'earth1024.jpg' (215 KB)
Preview of image 'earth1024.jpg'
Date: 20 Mar 2008 11:55:01
Message: <web.47e2965d41aa233d5cffe8340@news.povray.org>
I now see that P_IM_Earth was pasted inside another declaration and it still
worked, my bad. It should be moved anyway I suppose.
  image_map {
    jpeg "earth1024"
    map_type 1
    interpolate 2
Date: 22 Mar 2008 07:19:54
Message: <47e4f96a@news.povray.org>
High!
What about adding an astronomically accurate starry sky?
// Begin addition by Yadgar
// (Atlas for Skywatchers) (C) 1997 Franckh-Kosmos Verlags-GmbH & Co.,
Stuttgart, Germany
yaz### [at] gmxde
// [0] Visual brightness in orders of magnitude
// [1] Rectascension, hours
// [2] Rectascension, minutes
// [3] Declination, degrees
                            // Flam- Bayer     Constel-   Name         Notes
#declare Cat=array[900][4] // steed           lation
   { 4.5,  2,  2,   70.91 } // 48              Cas
multiple
   { 4,    2,  3.4, 72.42 } // 50              Cas
   { 2,    2, 31.8, 89.26 } //  1    (alpha)   UMi (Polaris)
   { 4.8, 12, 49.2, 83.41 } // 78              Cam (32 Cam)
multiple
   { 4.3, 14, 27.5, 75.7  } //  5              UMi
   { 2.1, 14, 50.7, 74.16 } //  7    (beta)    UMi (Kokhab)
   { 3,   15, 20.7, 71.83 } // 13    (gamma)   UMi (Ferkad)
   { 4.3, 15, 44.1, 77.79 } // 16    (zeta)    UMi
   { 5,   16, 17.5, 75.76 } // 21    (eta)     UMi
   { 4.2, 16, 46,   82.04 } // 22    (epsilon) UMi
   { 4.4, 17, 32.2, 86.59 } // 23    (delta)   UMi
   { 5.1, 18,  0.1, 80    } // 40+41           Dra
multiple
   { 5.1, 20, 28,   81.43 } // 75              Dra
multiple
   { 2.1,  0,  8.4, 29.09 } // 21    (alpha)   And (Alferatz, Zirrah)
   { 3.3,  0, 39.3, 30.86 } // 31    (delta)   And
   { 4.5,  0, 49.8, 41.08 } // 35    (ny)      And
   { 3.9,  0, 56.8, 38.5  } // 37    (my)      And
   { 2.1,  1,  9.7, 35.62 } // 43    (beta)    And (Mirakh)
   { 4.1,  1, 36.8, 41.41 } // 50    (upsilon) And                     3
planets!
   { 3.6,  1, 38,   48.63 } // 51              And
   { 4  ,  1, 43.7, 50.69 } //       (phi)     Per
   { 3.4,  1, 53.1, 29.58 } //  2    (alpha)   Tri (Elmuthalleth)
   { 5,    1, 56,   37.26 } // 56              And
multiple
   { 2.1,  2,  3.9, 42.33 } // 57    (gamma)   And (Alamak)
multiple
   { 3,    2,  9.5, 34.99 } //  4    (beta)    Tri
   { 5.6,  2, 10.9, 39.04 } // 59              And
multiple
   { 4.9,  2, 12.4, 30.3  } //  6    (iota)    Tri
multiple
   { 4,    2, 17.3, 33.85 } //  9    (gamma)   Tri
   { 5.1,  2, 35.8, 34.7  } // 15              Tri
multiple
   { 8,    2, 37,   34.26 } //  R              Tri
fluctuating
   { 2.3   0,  9.2, 59.15 } // 11    (beta)    Cas (Kaf)
   { 4.7,  0, 31.8, 54.52 } // 14    (lambda)  Cas
   { 3.7,  0, 37,   53.9  } // 17    (zeta)    Cas
   { 2.2,  0, 40.5, 56.54 } // 18    (alpha)   Cas (Shedir)
   { 3.4,  0, 49.1, 57.82 } // 24    (eta)     Cas (Akhird)
multiple
   { 2.35, 0, 56.7, 60.72 } // 27    (gamma)   Cas
   { 4.8,  1, 20.1, 58.23 } // 34    (phi)     Cas
multiple
   { 2.7,  1, 25.8, 60.24 } // 37    (delta)   Cas (Rukhbah)
   { 3.4,  1, 54.4, 63.67 } // 45    (epsilon) Cas
   { 4.5,  2, 29.1, 67.4  } //        iota     Cas
multiple
   { 5.95  2, 52,   68.89 } // SU              Cas
fluctuating
   { 4.3,  4, 54.1, 66.34 } //  9    (alpha)   Cam
   { 4,    5,  3.4, 60.44 } // 10    (beta)    Cam
multiple
   { 4.8,  5,  6.2, 58.98 } // 11+12           Cam
multiple
   { 4.2,  2, 50.6, 38.32 } // 16              Per
   { 3.8,  2, 50.7, 55.9  } // 15    (eta)     Per
   { 3.9,  2, 54.3, 52.76 } // 18    (tau)     Per
   { 2.9,  3,  4.8, 53.51 } // 23    (gamma)   Per
   { 3.4,  3,  5.2, 38.84 } // 25    (rho)     Per
fluctuating
   { 2.75, 3,  8.2, 40.96 } // 26    (beta)    Per (Algol)
fluctuating
   { 4.1,  3,  9.1, 49.61 } //        iota     Per
   { 3.8,  3,  9.5, 44.86 } // 27    (kappa)   Per
   { 1.8,  3, 24.3, 49.86 } // 33    (alpha)   Per (Mirfak)
   { 3,    3, 42.9, 47.79 } // 39    (delta)   Per
   { 3.8,  3, 44.3, 32.39 } // 38    (omikron) Per (Atik)
   { 3.8,  3, 45.2, 42.58 } // 41    (ny)      Per
   { 2.8,  3, 54.1, 31.88 } // 44    (zeta)    Per
   { 2.9,  3, 57.9, 40.01 } // 45    (epsilon) Per
multiple
   { 4,    3, 59,   35.79 } // 46    (xi)      Per (Menkib)
   { 4,    4,  8.7, 47.71 } // 48    (upsilon) Per
   { 4.1,  4, 14.9, 48.41 } // 51    (my)      Per
   { 5.4   4, 32,   53.91 } //  1              Cam
multiple
   { 5.6,  4, 33.4, 43.05 } // 57              Per
multiple
   { 5.4,  4, 40,   53.47 } //  2              Cam
multiple
   { 2.7,  4, 57,   33.17 } //  3    (iota)    Aur
   { 4.9,  4, 59.3, 37.89 } //  4    (omega)   Aur
multiple
   { 3.4,  5,  2,   43.82 } //  7    (epsilon) Aur
fluctuating
   { 3.85, 5,  2.5, 41.08 } //  8    (zeta)    Aur
fluctuating
   { 3.2,  5,  6.5, 41.23 } // 10    (eta)     Aur
   { 4.9,  5, 15.4, 32.69 } // 14              Aur
multiple
   { 0.1,  5, 16.7, 46    } // 13    (alpha)   Aur (Capella)
   { 5.4,  5, 38.6, 30.49 } // 26              Aur
   { 4,    5, 51.5, 39.15 } // 32    (ny)      Aur
   { 3.7,  5, 59.5, 54.28 } // 33    (delta)   Aur
   { 1.9,  5, 59.5, 44.95 } // 34    (beta)    Aur (Menkalinan)
   { 2.6,  5, 59.7, 37.21 } // 37    (theta)   Aur
multiple
   { 5.8,  6, 11.6, 48.71 } // 41              Aur
multiple
   { 5.1,  6, 26.8, 58.42 } //  5              Lyn
multiple
   { 5.35, 6, 28.6, 30.49 } // 48              Aur (RT Aurigae)
fluctuating
   { 4.8,  6, 46.2, 59.44 } // 12              Lyn
multiple
   { 4.4,  6, 57.3, 58.42 } // 15              Lyn
   { 5.3,  7, 22.9, 55.29 } // 19              Lyn
multiple
   { 4.3,  8, 22.8, 43.19 } // 31              Lyn
   { 3.35, 8, 30.3, 60.72 } //  1    (omikron) UMa
fluctuating
   { 3.1,  8, 59.2, 48.02 } //  9    (iota)    UMa (Talitha)
   { 4,    9,  0.6, 41.78 } // 10              UMa
   { 3.6,  9,  3.6, 47.16 } // 12    (kappa)   UMa
   { 3.8,  9, 18.8, 36.8  } // 38              Lyn
multiple
   { 3.1,  9, 21.1, 34.39 } // 40    (alpha)   Lyn
   { 5.3,  9, 28.7, 45.6  } // 41              Lyn
multiple
   { 3.7,  9, 31.5, 63.06 } // 23              UMa
   { 3.2,  9, 32.9, 51.68 } // 25    (theta)   UMa
   { 4.5,  9, 34.5, 69.83 } // 24              UMa
   { 3.8,  9, 51,   59.04 } // 29    (ny)      UMa
   { 4.2, 10, 27.9, 36.71 } // 31    (beta)    LMi
   { 3.8, 10, 53.3, 34.21 } // 46    (omikron) LMi
   { 3.5, 10, 17.1, 42.91 } // 33    (lambda)  UMa (Tania Borealis)
   { 3.1, 10, 22.3, 41.5  } // 34    (my)      UMa (Tania Australis)
   { 6,   10, 45.1, 67.41 } // VY              UMa
fluctuating
   { 2.3, 11,  1.8, 56.38 } // 48    (beta)    UMa (Merak)
   { 1.8, 11,  3.7, 61.75 } // 50    (alpha)   UMa (Dubhe)
   { 3.0, 11,  9.7, 44.5  } // 52    (psi)     UMa
   { 3.7, 11, 46.1, 47.78 } // 63    (chi)     UMa
   { 2.4, 11, 53.8, 53.69 } // 64    (gamma)   UMa (Phegda, Phad)
   { 3.3, 12, 15.4, 57.03 } // 69    (delta)   UMa (Megrez)
   { 1.8, 12, 54,   55.96 } // 77    (epsilon) UMa (Alioth)
   { 4.9, 13,  0.7, 56.37 } // 78              UMa
fluctuating
   { 2,   13, 23.9, 54.93 } // 79    (zeta)    UMa (Mizar)
   { 4,   13, 25.2, 54.99 } // 80              UMa (Alkor)
   { 1.9, 13, 47.5, 49.31 } // 85    (eta)     UMa (Alkaid, Benetnasch)
   { 3.8, 11, 18.2, 31.53 } // 53    (xi)      UMa (Alula Australis)
multiple
   { 3.5, 11, 18.5, 33.09 } // 54    (ny)      UMa (Alula Borealis)
   { 4.2, 12, 33.7, 41.36 } //  8    (beta)    CVn
   { 5.4, 12, 45.1, 45.44 } //  Y              CVn
fluctuating
   { 2.8, 12, 56,   38.32 } // 12    (alpha)   CVn (Cor Caroli)
multiple
   { 5.3, 13,  9.9, 38.51 } // 17,15           CVn
multiple
   { 4.8, 13, 37.5, 36.29 } // 25              CVn
multiple
   { 4.4, 14, 13.5, 51.79 } // 17    (kappa)   Boo
multiple
   { 4.7, 14, 16.2, 51.37 } // 21    (iota)    Boo
multiple
   { 4,   14, 25.2, 51.85 } // 23    (theta)   Boo
   { 3,   14, 32.1, 38.31 } // 27    (gamma)   Boo (Ceginus)
   { 5.7, 14, 49.7, 48.72 } // 39              Boo
multiple
   { 3.5, 15,  1.9, 40.39 } // 42    (beta)    Boo (Nekkar)
   { 4.8, 15,  3.8, 47.65 } //  i              Boo
multiple, fluctuating
   { 3.4, 15, 15.5, 33.31 } // 49    (delta)   Boo
multiple
   { 4.2, 15, 24.5, 37.38 } // 51    (my)      Boo (Alkalurops)
multiple
   { 4.6, 15, 39.4, 36.64 } //  7    (zeta)    CrB
multiple
   { 4.2, 16,  8.8, 44.93 } // 11    (phi)     Her
   { 5.2, 16, 17.4, 33.86 } // 17    (sigma)   CrB
multiple
   { 3.9, 16, 19.7, 46.31 } // 22    (tau)     Her
   { 4.85,16, 28.6, 41.88 } // 30    (g)       Her
fluctuating
   { 4.2, 16, 34.1, 42.44 } // 35    (sigma)   Her
   { 2.8, 16, 41.3, 31.6  } // 40    (zeta)    Her
   { 3.5, 16, 42.9, 38.92 } // 44    (eta)     Her
   { 3.9, 17,  0.3, 30.93 } // 58    (epsilon) Her
   { 3.2, 17, 15,   36.81 } // 67    (pi)      Her
   { 5.15,17, 17.3, 33.1  } // 68    (u)       Her
fluctuating
   { 4.1, 17, 23.7, 37.15 } // 75    (rho)     Her
multiple
   { 3.8, 17, 39.5, 46.01 } // 85    (iota)    Her
   { 3.9, 17, 56.3, 37.25 } // 91    (theta)   Her
   { 3.8, 11, 31.4, 69.33 } //  1    (lambda)  Dra (Giauzar)
   { 3.9, 12, 33.5, 69.76 } //  5    (kappa)   Dra
   { 3.7, 14,  4.4, 64.38 } // 11    (alpha)   Dra (Thuban)
   { 3.3, 15, 24.9, 58.97 } // 12    (iota)    Dra (Edasich)
   { 4,   16,  1.9, 58.57 } // 13    (theta)   Dra
   { 2.7, 16, 24,   61.51 } // 14    (eta)     Dra
   { 4.5, 16, 36.2, 52.91 } // 17,16           Dra
multiple
   { 4.9, 17,  5.3, 54.47 } // 21    (my)      Dra
multiple
   { 3.2, 17,  8.8, 65.71 } // 22    (zeta)    Dra
   { 2.8, 17, 30.4, 53.3  } // 23    (beta)    Dra (Rastaben)
   { 4.1, 17, 32.2, 55.18 } // 25,24 (ny)      Dra
multiple
   { 5.2, 17, 35,   61.87 } // 26              Dra
multiple
   { 4.3, 17, 41.9, 72.15 } // 31    (psi)     Dra
multiple
   { 3.7, 17, 53.5, 56.87 } // 32    (xi)      Dra (Grumium)
   { 2.2, 17, 56.6, 51.49 } // 33    (gamma)   Dra (Ettanin)
   { 3.6, 18, 21.1, 72.73 } // 44    (chi)     Dra
   { 4.9, 18, 23.9, 58.8  } // 39              Dra
multiple
   { 3.1, 19, 12.6, 67.66 } // 57    (delta)   Dra (Altais)
   { 3.8, 19, 48.2, 70.27 } // 63    (epsilon) Dra
multiple
   { 4.3, 18, 19.9, 36.06 } //  1    (kappa)   Lyr
   { 0,   18, 36.9, 38.78 } //  3    (alpha)   Lyr (Vega)
   { 3.9, 18, 44.4, 39.64 } //  5,4  (epsilon) Lyr
multiple
   { 4.1, 18, 44.8, 37.6  } //  6,7  (zeta)    Lyr
multiple
   { 3.75,18, 50.1, 33.36 } // 10    (beta)    Lyr (Sheliak)
fluctuating, multiple
   { 4.2, 18, 54.5, 36.9  } // 12    (delta-2) Lyr
   { 4.15,18, 55.3, 43.95 } // 13    (R)       Lyr
fluctuating
   { 3.2, 18, 58.9, 32.69 } // 14    (gamma)   Lyr (Sulaphat)
   { 3.8, 19, 17.1, 53.37 } //  1    (kappa)   Cyg
   { 3.8, 19, 29.7, 51.73 } // 10    (iota)    Cyg
   { 2.9, 19, 30.7, 27.96 } //  6    (beta)    Cyg (Albireo)
multiple
   { 4.3, 19, 36.4, 50.22 } // 13    (theta)   Cyg
multiple
   { 5.4, 19, 41.8, 50.52 } // 16              Cyg
multiple
   { 2.9, 19, 45,   45.13 } // 18    (delta)   Cyg
multiple
   { 9,   19, 50.6, 32.91 } //       (chi)     Cyg
fluctuating
   { 4.9, 19, 55.6, 52.44 } // 24    (psi)     Cyg
multiple
   { 3.9, 19, 56.3, 35.08 } // 21    (eta)     Cyg
   { 3.4, 20, 13.6, 46.76 } // 31  (omikron-1) Cyg
multiple
   { 4.6, 20, 14.6, 36.8  } // 29              Cyg
multiple
   { 4,   20, 15.5, 47.71 } // 32  (omikron-2) Cyg
   { 4.8, 20, 17.8, 38.03 } // 34    (P)       Cyg
fluctuating
   { 2.2, 20, 22.2, 40.26 } // 37    (gamma)   Cyg (Sadr)
   { 4,   20, 29.4, 30.37 } // 41              Cyg
   { 5.1, 20, 31.2, 49.22 } // 46    (omega-2) Cyg
   { 1.3, 20, 41.4, 45.28 } // 50    (alpha)   Cyg (Deneb)
   { 4.2, 20, 45.7, 30.72 } // 52              Cyg
   { 2.5, 20, 46.2, 33.97 } // 53    (epsilon) Cyg
   { 4.5, 20, 47.4, 36.49 } // 54    (lambda)  Cyg
multiple
   { 5.75,20, 51.5, 28.25 } //  T              Vul
fluctuating
   { 3.9, 20, 57.2, 41.17 } // 58    (ny)      Cyg
   { 3.7, 21,  4.9, 43.93 } // 62    (xi)      Cyg
   { 3.2, 21, 12.9, 30.23 } // 64    (zeta)    Cyg
   { 3.4, 20, 45.3, 61.84 } //  3    (eta)     Cep
   { 7.8, 21,  9.5, 68.49 } //  T              Cep
fluctuating
   { 2.5, 21, 18.6, 62.59 } //  5    (alpha)   Cep (Alderamin)
   { 3.2, 21, 28.7, 70.56 } //  8    (beta)    Cep (Alfirk)
multiple
   { 4.2, 21, 43.5, 58.78 } //       my        Cep
fluctuating
   { 4.3, 22,  3.8, 64.63 } // 17    (xi)      Cep
multiple
   { 3.4, 22, 10.9, 58.2  } // 21    (zeta)    Cep
   { 4.2, 22, 15,   57.04 } // 23    (epsilon) Cep
   { 3.8, 22, 29.2, 58.42 } // 27    (delta)   Cep
   { 3.5, 22, 49.7, 66.2  } // 32    (iota)    Cep
   { 4.4, 23,  7.9, 75.39 } // 33    (pi)      Cep
multiple
   { 4.7, 23, 18.6, 68.11 } // 34    (omikron) Cep
multiple
   { 4.9, 23, 24.8, 62.28 } //  4              Cas
multiple
   { 4.8, 23, 30,   58.55 } // AR              Cas
multiple
   { 3.2, 23, 39.3, 77.63 } // 35    (gamma)   Cep (Errai)
   { 4.5, 23, 54.4, 57.5  } //  7    (rho)     Cas
fluctuating
   { 4.9, 23, 59,   55.76 } //  8    (sigma)   Cas
multiple
   { 4.8, 21,  6.9, 38.75 } // 61              Cyg
multiple
   { 3.7, 21, 14.8, 38.05 } // 65    (tau)     Cyg
   { 4.2, 21, 17.4, 39.39 } // 67    (sigma)   Cyg
   { 4,   21, 34,   45.59 } // 73    (rho)     Cyg
   { 5.8, 21, 36,   45.37 } //  W              Cyg
fluctuating
   { 5.4, 21, 43.5, 38.29 } // 79              Cyg
multiple
   { 4.4, 21, 44.2, 28.75 } // 78    (my)      Cyg
multiple
   { 4.1, 22, 16,   37.75 } //  1              Lac
   { 4.6, 22, 21,   46.54 } //  2              Lac
   { 4.4, 22, 23.6, 52.23 } //  3    (beta)    Lac
   { 4.6, 22, 24.5, 49.48 } //  4              Lac
   { 4.3, 22, 29.5, 47.71 } //  5              Lac
   { 3.8, 22, 31.3, 50.28 } //  7    (alpha)   Lac
   { 5.3, 22, 35.9, 39.63 } //  8              Lac
multiple
   { 3.6, 23,  1.9, 42.33 } //  1    (omikron) And
   { 3.85,23, 37.6, 46.46 } // 16    (lambda)  And
fluctuating
   { 4.3, 23, 38.1, 43.27 } // 17    (iota)    And
   { 4.1, 23, 40.4, 44.33 } // 19    (kappa)   And
   { 5.4,  0,  9.4,-27.99 } //       (kappa1)  Scl
multiple
   { 3.6,  0, 19.4, -8.82 } //  8    (iota)    Cet
   { 5.7,  0, 21.8,-20.06 } //  T              Cet
fluctuating
   { 2,    0, 43.6,-17.99 } // 16    (beta)    Cet (Deneb Kaitos)
   { 4.3,  0, 58.6,-29.36 } //       (alpha)   Scl
   { 3.5,  1,  8.6,-10.18 } // 31    (eta)     Cet
   { 5,    1, 14.4, -7.92 } // 37              Cet
multiple
   { 3.6,  1, 24,   -8.18 } // 45    (theta)   Cet
   { 5.7,  1, 36.1,-29.91 } //       (tau)     Scl
multiple
   { 3.5,  1, 44.1,-15.94 } // 52    (tau)     Cet
   { 4.5,  1, 49.6,-10.69 } // 53    (chi)     Cet
multiple
   { 3.7,  1, 51.5,-10.33 } // 55    (zeta)    Cet (Baten Kaitos)
   { 4,    2,  0,  -21.08 } // 59    (ny)      Cet
   { 5.5,  2, 12.8, -2.39 } // 66              Cet
multiple
   { 6.3,  2, 19.3, -2.98 } // 68    (omikron) Cet (Mira)
fluctuating
   { 4.9,  2, 33.8,-28.23 } //       (omega)   For
multiple
   { 4.1,  2, 39.5,  0.33 } // 82    (delta)   Cet
   { 3.5,  2, 43.3,  3.24 } // 86    (gamma)   Cet
multiple
   { 4.2,  2, 44.1,-13.86 } // 89    (pi)      Cet
   { 4.3,  2, 44.9, 10.11 } // 87    (my)      Cet
   { 2.5,  3,  2.3,  4.09 } // 92    (alpha)   Cet (Menkar)
   { 2.8,  0, 13.2, 15.18 } // 88    (gamma)   Peg (Algenib)
   { 5.8,  0, 15,    8.82 } // 35              Psc
multiple
   { 5,    0, 28,   17.89 } // 47              Psc (TV Piscium)
fluctuating
   { 4.1,  0, 47.3, 24.27 } // 34    (zeta)    And
   { 4.4,  0, 48.7,  7.59 } // 63    (delta)   Psc
   { 5.5,  0, 49.9, 27.71 } // 65              Psc
multiple
   { 5.5,  0, 55,   23.63 } // 36              And
multiple
   { 4.3,  1,  2.9,  7.89 } // 71    (epsilon) Psc
   { 4.7,  1,  5.7, 21.47 } // 74    (psi1)    Psc
multiple
   { 4.9,  1, 13.7,  7.58 } // 86    (zeta)    Psc
multiple
   { 3.6,  1, 31.5, 15.35 } // 99    (eta)     Psc
   { 4.4,  1, 41.4,  5.49 } //106    (ny)      Psc
   { 4.3,  1, 45.4,  9.16 } //110    (omikron) Psc
   { 5.8,  1, 50.1, 22.28 } //  1              Ari
multiple
   { 3.9,  1, 53.5, 19.29 } //  5    (gamma)   Ari (Mesarthim)
multiple
   { 4.6,  1, 53.6,  3.19 } //111    (xi)      Psc
   { 2.6,  1, 54.6, 20.81 } //  6    (beta)    Ari (Sheratan)
   { 4.7,  1, 57.9, 23.6  } //  9    (lambda)  Ari
multiple
   { 3.8,  2,  2,    2.76 } //113    (alpha)   Psc
multiple
   { 5.6,  2,  3.7, 25.94 } // 10              Ari
multiple
   { 2,    2,  7.2, 23.46 } // 13    (alpha)   Ari (Hamal)
   { 3.6,  2, 50,   27.26 } // 41              Ari
   { 4.6,  2, 59.2, 21.34 } // 48    (epsilon) Ari
multiple
   { 4.5,  2, 45.1,-18.57 } //  1    (tau1)    Eri
   { 4.4,  2, 49.1,-32.41 } //       (beta)    For
   { 3.9,  2, 56.4, -8.9  } //  3    (eta)     Eri
   { 3.9,  3, 12.1,-28.99 } //       (alpha)   For
multiple
   { 3.7,  3, 19.5,-21.76 } // 16    (tau4)    Eri
   { 3.7,  3, 32.9, -9.46 } // 18    (epsilon) Eri
   { 4.3,  3, 33.8,-21.63 } // 19    (tau5)    Eri
   { 3.5,  3, 43.2, -9.77 } // 23    (delta)   Eri
   { 4.2,  3, 46.8,-23.25 } // 27    (tau6)    Eri
   { 4.5,  3, 54.3, -2.95 } // 32              Eri
multiple
   { 3,    3, 58,  -13.51 } // 34    (gamma)   Eri (Zaurak)
   { 4,    4, 11.9, -6.84 } // 38    (omikron1)Eri
   { 4.9,  4, 14.4,-10.26 } // 39              Eri
multiple
   { 4.4,  4, 15.3, -7.64 } // 40    (omikron2)Eri
multiple
   { 3.6,  4, 17.9,-33.8  } // 41    (upsilon4)Eri
   { 4,    4, 24,  -34.02 } // 43    (upsilon3)Eri
   { 3.8,  4, 35.6,-30.56 } // 52    (upsilon2)Eri
   { 3.9,  4, 36.3, -3.35 } // 48    (ny)      Eri
   { 3.9,  4, 38.2,-14.3  } // 53              Eri
   { 4,    4, 45.5, -3.25 } // 57    (my)      Eri
   { 2.8,  5,  7.9, -5.09 } // 67    (beta)    Eri (Cursa)
   { 3.9,  5, 31.2,-35.47 } //       (epsilon) Col
   { 2.6,  5, 39.6,-34.07 } //       (alpha)   Col
   { 3.1,  5, 51,  -35.77 } //       (beta)    Col
   { 4.4,  5, 57.5,-35.28 } //       (gamma)   Col
   { 3.9,  6, 22.1,-33.44 } //       (delta)   Col
   { 3.6,  3, 24.8,  9.03 } //  1    (omikron) Tau
   { 3.7,  3, 27.2,  9.73 } //  2    (xi)      Tau
   { 3.7,  3, 44.9, 24.11 } // 17              Tau (Electra)
   { 4.3,  3, 45.2, 24.47 } // 19              Tau (Taygeta)
   { 3.8,  3, 45.8, 24.37 } // 20              Tau (Maia)
   { 4.1,  3, 46.3, 23.95 } // 23              Tau (Merope)
   { 2.8,  3, 47.5, 24.11 } // 25    (eta)     Tau (Alcyone)
   { 3.6,  3, 49.2, 24.06 } // 27              Tau (Atlas)
   { 5.05, 3, 49.2, 24.14 } // 28    (BU)      Tau (Pleione)
fluctuating
   { 3.65, 4,  0.7, 12.49 } // 35    (lambda)  Tau
fluctuating
   { 3.9,  4,  3.2,  5.99 } // 38    (ny)      Tau
   { 4.8,  4, 13.9,  9.26 } // 47              Tau
multiple
   { 3.6,  4, 19.8, 15.63 } // 54    (gamma)   Tau
   { 3.8,  4, 22.9, 17.54 } // 61    (delta1)  Tau
   { 4.3,  4, 25.5, 17.93 } // 68    (delta3)  Tau
multiple
   { 3.5,  4, 28.6, 19.18 } // 74    (epsilon) Tau
   { 3.8,  4, 28.6, 15.96 } // 77    (theta1)  Tau
   { 3.4,  4, 28.7, 15.87 } // 78    (theta2)  Tau
   { 4.2,  4, 35.7, 10.16 } // 88              Tau
multiple
   { 0.9,  4, 35.9, 16.51 } // 87    (alpha)   Tau (Aldebaran)
probably planet(s)!
   { 4.2,  4, 42.2, 22.96 } // 94    (tau)     Tau
multiple
   { 1.7,  5, 26.3, 28.61 } //112    (beta)    Tau (Elnath, Nath)
   { 5.5,  5, 29.3, 25.15 } //118              Tau
multiple
   { 3,    5, 37.6, 21.14 } //123    (zeta)    Tau
   { 7.85, 4, 59.6,-14.81 } //  R              Lep
fluctuating
   { 3.2,  5,  5.5,-22.37 } //  2    (epslion) Lep
   { 5.6,  5, 11.4,-11.85 } // RX              Lep
fluctuating
   { 3.3,  5, 12.9,-16.21 } //  5    (my)      Lep
fluctuating
   { 4.4,  5, 13.2,-12.94 } //  4    (kappa)   Lep
multiple
   { 0.1,  5, 14.5, -8.2  } // 19    (beta)    Ori (Rigel)
multiple
   { 3.6,  5, 17.6, -6.84 } // 20    (tau)     Ori
   { 2.8,  5, 28.2,-20.76 } //  9    (beta)    Lep (Nihal)
   { 2.6,  5, 32.7,-17.82 } // 11    (alpha)   Lep (Arneb)
   { 4,    5, 35.3, -5.4  } // 41,43 (theta)   Ori
quadruple
   { 4.1,  5, 35.4, -4.84 } // 42,45           Ori
multiple
   { 2.8,  5, 35.4, -5.91 } // 44    (iota)    Ori
multiple
   { 3.5,  5, 44.5,-22.45 } // 13    (gamma)   Ori
multiple
   { 3.6,  5, 47,  -14.82 } // 14    (zeta)    Ori
   { 2.1,  5, 47.8, -9.67 } // 53    (kappa)   Ori (Saiph)
   { 3.8,  5, 51.3,-20.88 } // 15    (delta)   Lep
   { 3.7,  5, 56.4,-14.17 } // 16    (eta)     Lep
   { 3.2,  4, 49.8,  6.96 } //  1    (pi3)     Ori
   { 3.7,  4. 51.2,  5.61 } //  3    (pi4)     Ori
   { 3.7,  4, 54.3,  2.44 } //  8    (pi5)     Ori
   { 5.3,  5,  7.9,  8.5  } // 14              Ori
multiple
   { 4.4,  5, 21.7, -0.39 } // 22              Ori
multiple
   { 4.9,  5, 22.8,  3.55 } // 23              Ori
multiple
   { 3.45, 5, 24.5, -2.4  } // 28    (eta)     Ori
   { 1.6,  5, 21.2,  6.35 } // 24    (gamma)   Ori (Bellatrix)
   { 4.2,  5, 30.8,  5.95 } // 32              Ori
multiple
   { 5.4,  5, 31.2,  3.29 } // 33              Ori
multiple
   { 2.2,  5, 32,   -0.3  } // 34    (delta)   Ori (Mintaka)
multiple
   { 5.5,  5, 33.5, -1.16 } // VV              Ori
fluctuating
   { 3.4,  5, 35.1,  9.93 } // 39    (lambda)  Ori
multiple
   { 1.7,  5, 36.2, -1.2  } // 46    (epsilon) Ori (Alnilam)
   { 3.6,  5, 38.8, -2.6  } // 48    (sigma)   Ori
multiple
   { 1.7,  5, 40.8, -1.94 } // 50    (zeta)    Ori (Alnitak)
multiple
   { 5.3,  5, 48,    6.45 } // 52              Ori
multiple
   { 0.6,  5, 55.2,  7.41 } // 58    (alpha)   Ori (Beteigeuze)
fluctuating
   { 3,    6, 20.3,-30.06 } //  1    (zeta)    CMa (Phurud)
multiple (perspectivic)
   { 2,    6, 22.7,-17.96 } //  2    (beta)    CMa (Mirzam)
   { 4,    6, 36.7,-19.26 } //  7    (ny2)     CMa
   {-1.5,  6, 45.1,-16.72 } //  9    (alpha)   CMa (Sirius)
   { 3.75, 6, 49.8,-32.51 } // 13    (kappa)   CMa
   { 3.9,  6, 54.1,-24.18 } // 16    (omikron1)CMa
fluctuating
   { 1.5,  6, 58.6,-28.97 } // 21    (epsilon) CMa (Adhara)
multiple
   { 3.5,  7,  1.7,-27.93 } // 22    (sigma)   CMa
   { 3,    7,  3,  -23.83 } // 24    (omikron2)CMa
   { 4.1,  7,  3.8,-15.63 } // 23    (gamma)   CMa
   { 1.8,  7,  8.4,-26.39 } // 25    (delta)   CMa (Wezen)
   { 4.55, 7, 14.3,-26.35 } // 27              CMa (EW CMa)
fluctuating
   { 3.9,  7, 14.8,-26.77 } // 28    (omega)   CMa
fluctuating
   { 4.5,  7, 16.6,-23.31 } //145              CMa
   { 5.05, 7, 18.7,-24.56 } // 29              CMa (UW CMa)
fluctuating
   { 2.4,  7, 24.1,-29.3  } // 31    (eta)     CMa (Aludra)
   { 5.1,  7, 34.3,-23.47 } //  n              Pup
multiple
   { 3.8,  7, 38.8,-26.8  } //  k    (kappa)   Pup
multiple
   { 3.9,  7, 43.8,-28.96 } //  3              Pup
   { 3.2,  7, 49.3,-24.86 } //  7    (xi)      Pup (Aspidiske)
   { 4.2,  7, 56.9,-22.88 } // 11              Pup
   { 2.8,  8,  7.5,-24.3  } // 15    (rho)     Pup
   { 3.3,  6, 14.9, 22.51 } //  7    (eta)     Gem (Tejat Prior)
fluctuating
   { 2.9,  6, 23,   22.51 } // 13    (my)      Gem (Tejat Posterior)
   { 4.1,  6, 29,   20.21 } // 18    (ny)      Gem
   { 1.9,  6, 37.7, 16.4  } // 24    (gamma)   Gem (Alhena)
   { 4.6,  6, 41,    9.9  } // 15              Gem
multiple
   { 3.1,  6, 43.9, 25.13 } // 27    (epsilon) Gem (Mebsuta)
   { 3.4,  6, 45.3, 12.9  } // 31    (xi)      Gem
   { 3.6,  6, 52.8, 33.96 } // 34    (theta)   Gem
   { 4.7,  6, 54.6, 13.18 } // 38              Gem
multiple
   { 3.9,  7,  4.1, 20.57 } // 43    (zeta)    Gem (Mekbuda)
multiple (perspectivic), fluctuating
   { 3.6,  7, 18.1, 16.54 } // 54    (lambda)  Gem
   { 3.5,  7, 20.1, 21.98 } // 55    (delta)   Gem (Wasat)
   { 3.8,  7, 25.7, 27.8  } // 60    (iota)    Gem
   { 4.2,  7, 29.1, 31.78 } // 62    (rho)     Gem
   { 1.6,  7, 34.6, 31.89 } // 66    (alpha)   Gem (Castor)
multiple
   { 4.1,  7, 35.9, 26.9  } // 69    (upsilon) Gem
   { 3.6,  7, 44.4, 24.4  } // 77    (kappa)   Gem
   { 1.1,  7, 45.3, 28.03 } // 78    (beta)    Gem (Pollux)
   { 4,    6, 14.9, -6.27 } //  5    (gamma)   Mon
   { 3.7,  6, 28.8, -7.03 } // 11    (beta)    Mon
multiple
   { 4.1,  6, 54.2,-12.04 } // 14    (theta)   CMa
   { 5,    6, 56.1,-14.04 } // 18    (my)      CMa
multiple
   { 4.2,  7, 11.9, -0.49 } // 22    (delta)   Mon
   { 6.6,  7, 30.8, -9.78 } //  U              Mon
fluctuating
   { 3.9,  7, 41.2, -9.55 } // 26    (alpha)   Mon
   { 5.7,  7, 45.5,-14.69 } //  2              Pup
multiple
   { 5.5,  7, 47.9,-12.19 } //  5              Pup
multiple
   { 4.4,  8,  8.6, -2.98 } // 29    (zeta)    Mon
   { 4.7,  8, 11.3,-12.93 } // 19              Pup
   { 4.3,  6, 23.8,  4.59 } //  8    (epsilon) Mon
multiple
   { 6.1,  6, 25.2,  7.09 } //  T              Mon
fluctuating
   { 2.9,  7, 27.2,  8.29 } //  3    (beta)    CMi (Gomeisa)
   { 4.3,  7, 28.2,  8.93 } //  4    (gamma)   CMi
   { 0.4,  7, 39.3,  5.22 } // 10    (alpha)   CMi (Procyon)
   { 4.7,  8, 12.2, 17.65 } // 16    (zeta)    Cnc
multiple
   { 3.5,  8, 16.5,  9.19 } // 17    (beta)    Cnc (Altarf)
   { 5.5,  8, 26.8, 26.94 } // 23    (phi2)    Cnc
multiple
   { 4.7,  8, 43.3, 21.47 } // 43    (gamma)   Cnc (Asellus Borealis)
   { 3.9,  8, 44.7, 18.15 } // 47    (delta)   Cnc (Asellus Australis)
   { 3.9,  8, 46.7, 28.76 } // 48    (iota)    Cnc
multiple
   { 5.3,  8, 52.5, 28.3  } // 55    (rho1)    Cnc
multiple (perspectivic), 4 planets!
   { 5.4,  8, 54.2, 39.58 } // 57              Cnc
multiple
   { 6.25, 8, 55.4, 17.23 } //  X              Cnc
fluctuating
   { 4.3,  8, 58.5, 11.86 } // 65    (alpha)   Cnc
   { 5.8,  9, 10.6, 30.96 } // RS              Cnc
fluctuating
   { 3.9,  8, 25.7, -3.91 } //  C              Hya
   { 4.1,  8, 37.7,  5.79 } //  4    (delta)   Hya
   { 4.4,  8, 38.8,  3.34 } //  5    (sigma)   Hya
   { 4,    8, 40.1,-35.31 } //       (beta)    Pyx
   { 4.3,  8, 43.2,  3.4  } //  7    (eta)     Hya
   { 3.7,  8, 43.6,-33.19 } //       (alpha)   Pyx
multiple
   { 3.4,  8, 46.8,  6.42 } // 11    (epsilon) Hya
multiple
   { 4.4,  8, 48.4,  5.84 } // 13    (rho)     Hya
   { 4,    8, 50.5,-27.71 } //       (gamma)   Pyx
   { 3.1,  8, 55.4,  5.95 } // 16    (zeta)    Hya
   { 3.9,  9, 14.4,  2.31 } // 22    (theta)   Hya
   { 4.7,  9, 20.5, -9.56 } // 27              Hya
multiple
   { 2,    9, 27.6, -8.66 } // 30    (alpha)   Hya (Alphard)
   { 4.5,  9, 29.1, -2.77 } // 31    (tau1)    Hya
multiple
   { 3.9,  9, 39.9, -1.14 } // 35    (iota)    Hya
   { 4.1,  9, 51.5,-14.85 } // 39    (upsilon1)Hya
   { 5.1,  9, 52.5, -8.11 } //  8    (gamma)   Sex
   { 4.5, 10,  7.9, -0.37 } // 15    (alpha)   Sex
   { 3.6, 10, 10.6,-12.35 } // 41    (lambda)  Hya
   { 3.8, 10, 26.1,-16.84 } // 42    (my)      Hya
   { 4.3, 10, 27.2,-31.07 } //       (alpha)   Ant
   { 4.9, 10, 37.6,-13.38 } //  U              Hya
fluctuating
   { 5.8, 10, 43.3,  4.75 } // 33              Sex
multiple
   { 3.1, 10, 49.6,-16.19 } //       (ny)      Hya
   { 5.4,  9, 28.5,  9.06 } //  2    (omega)   Leo
multiple
   { 4.3,  9, 31.7, 22.97 } //  4    (lambda)  Leo (Alterf)
   { 3.5,  9, 41.2,  9.89 } // 14    (omikron) Leo
   { 3,    9, 45.9, 23.77 } // 17    (epsilon) Leo
   { 7.9,  9, 47.6, 11.43 } //  R              Leo
fluctuating
   { 3.9,  9, 52.8, 26.01 } // 24    (my)      Leo
   { 3.5, 10,  7.3, 16.76 } // 30    (eta)     Leo
   { 1.4, 10,  8.4, 11.97 } // 32    (alpha)   Leo (Regulus)
multiple
   { 3.4, 10, 16.7, 23.42 } // 36    (zeta)    Leo (Aldhafera)
   { 2,   10, 20,   19.84 } // 41    (gamma)   Leo (Algieba)
multiple
   { 3.8, 10, 32.8,  9.31 } // 47    (rho)     Leo
   { 4.3, 10, 55.6, 24.75 } // 54              Leo
multiple
   { 2.6, 11, 14.1, 20.52 } // 68    (delta)   Leo (Zosma)
   { 3.3, 11, 14.2, 15.43 } // 70    (theta)   Leo (Coxa)
   { 4,   11, 23.9, 10.53 } // 78    (iota)    Leo
multiple
   { 2.1, 11, 49.1, 14.57 } // 94    (beta)    Leo (Denebola)
   { 4.1, 10, 59.8,-18.3  } //  7    (alpha)   Crt (Alkes)
   { 4.5, 11, 11.7,-22.83 } // 11    (beta)    Crt
   { 3.6, 11, 19.3,-14.78 } // 12    (delta)   Crt
   { 4.1, 11, 24.9,-17.68 } // 15    (gamma)   Crt
   { 4.9, 11, 27.9,  2.85 } // 84    (tau)     Leo
   { 4.9, 11, 32.3,-29.26 } //  N              Hya
multiple
   { 3.5, 11, 33,  -31.86 } //       (xi)      Hya
   { 4,   11, 45.9,  6.53 } //  3    (ny)      Vir
   { 3.6, 11, 50.7,  1.76 } //  5    (beta)    Vir (Zawijava)
   { 4.3, 11, 52.9,-33.91 } //       (beta)    Hya
   { 4,   12,  8.4,-24.73 } //  1    (alpha)   Crv (Alchiba)
   { 3,   12, 10.1,-22.62 } //  2    (epsilon) Crv
   { 2.6, 12, 15.8,-17.54 } //  4    (gamma)   Crv (Gienah)
   { 3.9, 12, 19.9, -0.67 } // 15    (eta)     Vir (Zaniah)
   { 2.9, 12, 29.9,-16.52 } //  7    (delta)   Crv (Algorab)
   { 2.7, 12, 34.4,-23.4  } //  9    (beta)    Crv
   { 4.6, 12, 39.2, -8    } // 26    (chi)     Vir
   { 2.7, 12, 41.7, -1.45 } // 29    (gamma)   Vir (Porrima)
multiple
   { 3,   13, 18.9,-23.17 } // 46    (gamma)   Hya
   { 6.95,13, 29.7,-23.28 } //  R              Hya
fluctuating
   { 5.8, 12,  4.3, 21.46 } //  2              Com
multiple
   { 4.4, 12, 26.9, 28.27 } // 15    (gamma)   Com
   { 5,   12, 28.9, 25.91 } // 17              Com
multiple
   { 4.8, 12, 35.1, 18.38 } // 24              Com
multiple
   { 5.8, 12, 52.3, 17.09 } // 32,33           Com
   { 4.9, 12, 53.3, 21.24 } // 35              Com
multiple
   { 4.3, 13, 10,   17.53 } // 42    (alpha)   Com (Diadem)
   { 4.2, 13, 11.9, 27.88 } // 43    (beta)    Com
   { 4.1, 13, 49.5, 15.8  } //  5    (upsilon) Boo
   { 2.7, 13, 54.7, 18.4  } //  8    (eta)     Boo (Muphrid)
   { 0,   14, 15.7, 19.18 } // 16    (alpha)   Boo (Arcturus)
   { 3.6, 14, 31.8, 30.37 } // 25    (rho)     Boo
   { 4.5, 14, 40.7, 16.42 } // 29    (pi)      Boo
multiple
   { 3.8, 14, 41.1, 13.73 } // 30    (zeta)    Boo
   { 4.8, 14, 43.4, 26.53 } // 34              Boo (W Bootis)
fluctuating
   { 2.4, 14, 45,   27.07 } // 36    (epsilon) Boo (Izar)
multiple
   { 3.7, 14, 46.2,  1.89 } //109              Vir
   { 4.5, 14, 51.4, 19.1  } // 37    (xi)      Boo
multiple
   { 5,   15, 23.2, 30.29 } //  2    (eta)     CrB
multiple
   { 3.7, 15, 27.8, 29.11 } //  3    (beta)    CrB (Nusakan)
   { 4.1, 15, 32.9, 31.36 } //  4    (theta)   CrB
   { 2.2, 15, 34.8, 26.71 } //  5    (alpha)   CrB (Alphekka, Gemma)
   { 3.8, 15, 42.7, 26.3  } //  8    (gamma)   CrB
multiple
   { 6,   15, 48.6, 28.16 } //  R              CrB
fluctuating
   { 4.6, 15, 49.6, 26.07 } // 10    (delta)   CrB
   { 4.1, 15, 57.6, 26.88 } // 13    (epsilon) CrB
   { 3.4, 12, 55.6,  3.4  } // 43    (delta)   Vir
   { 2.8, 13,  2.2, 10.96 } // 47    (epsilon) Vir (Vindemiatrix)
   { 4.4, 13,  9.9, -5.54 } // 51    (theta)   Vir
   { 1,   13, 25.2,-11.16 } // 67    (alpha)   Vir (Spica)
   { 3.4, 13, 34.7, -0.6  } // 79    (zeta)    Vir
   { 4.3, 13, 51.8,-32.99 } //  3              Cen
multiple
   { 4.2, 14,  1.6,  1.54 } // 93    (tau)     Vir
   { 3.3, 14,  6.4,-26.68 } // 49    (pi)      Hya
   { 3.9, 14, 43.1, -5.66 } //107    (my)      Vir
   { 5,   14, 46,  -25.44 } // 54              Hya
multiple
   { 5.3, 14, 49.3,-14.15 } //  7    (my)      Lib
multiple
   { 2.6, 14, 50.9,-16.04 } //  9,8  (alpha)   Lib (Zubenelgenubi)
multiple
   { 5.4, 15,  1,   -8.52 } // 19    (delta)   Lib
fluctuating
   { 3.3, 15,  4.1,-25.28 } // 20    (sigma)   Lib
   { 2.6, 15, 17,   -9.38 } // 27    (beta)    Lib (Zubeneschemali)
   { 3.8, 15, 34.8,-10.54 } // 13    (delta)   Ser
multiple
   { 3.9, 15, 35.5,-14.79 } // 38    (gamma)   Lib
   { 3.6, 15, 37,  -28.13 } // 39    (upsilon) Lib
   { 3.7, 15, 38.7,-29.78 } // 40    (tau)     Lib
   { 2.6, 15, 44.3,  6.43 } // 24    (alpha)   Ser (Unukalhai)
   { 3.7, 15, 46.2, 15.42 } // 28    (beta)    Ser
   { 4.1, 15, 48.7, 18.14 } // 35    (kappa)   Ser
   { 3.5, 15, 49.6, -3.43 } // 32    (my)      Ser
   { 9.5, 15, 50.7, 15.13 } //  R              Ser
fluctuating
   { 3.7, 15, 50.8,  4.48 } // 37    (epsilon) Ser
   { 4,   15, 51,  -33.63 } //  5    (chi)     Lup
   { 3.9, 15, 56.5, 15.66 } // 41    (gamma)   Ser
   { 4.6, 15, 56.9,-33.97 } //       (xi)      Lup
multiple
   { 4.1, 16,  4.4,-11.37 } //       (xi)      Sco
multiple
   { 2.7, 16, 14.3, -3.69 } //  1    (delta)   Oph (Yed Prior)
   { 3.2, 16, 18.3, -4.69 } //  2    (epsilon) Oph (Yed Posterior)
   { 4.45,16, 27,  -18.46 } //  7    (chi)     Oph
fluctuating
   { 3.8, 16, 30.9,  1.98 } // 10    (lambda)  Oph (Marfik)
multiple
   { 2.5, 16, 37.2,-10.57 } // 13    (zeta)    Oph
   { 3.2, 16, 57.7,  9.38 } // 27    (kappa)   Oph
   { 2.4, 17, 10.4,-15.72 } // 35    (eta)     Oph (Sabik)
   { 2.1, 17, 34.9, 12.56 } // 55    (alpha)   Oph (Rasalhague)
   { 3.5, 17, 37.6,-15.4  } // 55    (xi)      Ser
   { 2.8, 17, 43.5,  4.57 } // 60    (beta)    Oph (Cebalrai)
   { 5.6, 17, 44.6,  2.58 } // 61              Oph
multiple
   { 3.8, 17, 47.9,  2.71 } // 62    (gamma)   Oph
   { 9.5, 17, 57.8,  4.69 } // Pfeilstern          (Barnards Stern)
   { 3.3, 17, 59,   -9.77 } // 64    (ny)      Oph
   { 3.9, 18,  0.6,  2.93 } // 67              Oph
multiple
   { 4.8, 18,  3.1, -8.18 } // 69    (tau)     Oph
multiple
   { 4,   18,  5.5,  2.5  } // 70              Oph
multiple
   { 3.7, 18,  7.4,  9.56 } // 72              Oph
   { 3.9, 15, 56.9,-29.21 } //  5    (rho)     Sco
   { 2.9, 15, 58.9,-26.11 } //  6    (pi)      Sco
   { 2.3, 16,  0.3,-22.62 } //  7    (delta)   Sco
   { 2.4, 16,  5.4,-19.8  } //  8    (beta)    Sco (Acrab)
multiple
   { 3.9, 16,  6.8,-20.67 } //  9    (omega1)  Sco
   { 3.9, 16, 12,  -19.46 } // 14    (ny)      Sco
multiple
   { 2.9, 16, 21.2,-25.59 } // 20    (sigma)   Sco
   { 4.4, 16, 25.6,-23.44 } //  5    (rho)     Oph
multiple
   { 1,   16, 29.4,-26.43 } // 21    (alpha)   Sco (Antares)
   { 2.8, 16, 35.9,-28.22 } // 23    (tau)     Sco
   { 2.3, 16, 50.2,-34.29 } // 26    (epsilon) Sco
   { 8,   16, 56.6,-30.58 } // RR              Sco
fluctuating
   { 4.3, 17, 15.3,-26.6  } // 36              Oph
multiple
   { 4.9, 17, 18,  -24.29 } // 39    (omikron) Oph
multiple
   { 3.3, 17, 22,  -25    } // 42    (theta)   Oph
   { 4.7, 16, 18.1, 17.05 } //  7    (kappa)   Her
multiple
   { 3.7, 16, 21.9, 19.15 } // 20    (gamma)   Her
   { 2.8, 16, 30.2, 21.49 } // 27    (beta)    Her (Ruticulus)
   { 3,   17, 14.6, 14.39 } // 64    (alpha)   Her (Rasalgethi)
   { 3.1, 17, 15,   24.84 } // 65    (delta)   Her
   { 3.4, 17, 46.5, 27.72 } // 86    (my)      Her
   { 3.7, 17, 57.8, 29.25 } // 92    (xi)      Her
   { 4.3, 18,  1.5, 21.6  } // 95              Her
multiple
   { 3.8, 18,  7.5, 28.76 } //103    (omikron) Her
   { 5.1, 18,  7.8, 26.1  } //100              Her
multiple
   { 3.2, 18, 21.3, -2.9  } // 58    (eta)     Ser
   { 3.8, 18, 23.7, 21.77 } //109              Her
   { 5.2, 18, 27.2,  0.2  } // 59d             Ser
multiple
   { 3.9, 18, 35.2, -8.24 } //       (alpha)   Sct
   { 5.6, 18, 46.5, -0.96 } //  5              Aql
multiple
   { 4.2, 18, 47.2, -4.75 } //       (beta)    Sct
   { 5.75,18, 47.5, -5.7  } //  R              Sct
   { 4,   18, 56.2,  4.2  } // 63    (theta)   Ser
multiple
   { 3,   18,  5.8,-30.42 } // 10    (gamma)   Sgr (Alnasl)
   { 3.8, 18, 13.8,-21.06 } // 13    (my)      Sgr
   { 2.7, 18, 21,  -29.83 } // 19    (delta)   Sgr (Kaus Media)
   { 1.8, 18, 24.2,-34.38 } // 20    (epsilon) Sgr (Kaus Australis)
   { 2.8, 18, 28,  -25.42 } // 22    (lambda)  Sgr (Kaus Borealis)
   { 3.2, 18, 45.7,-26.99 } // 27    (phi)     Sgr
   { 2,   18, 55.3,-26.3  } // 34    (sigma)   Sgr (Nunki)
   { 3.5, 18, 57.5,-21.11 } // 37    (xi2)     Sgr
   { 2.6, 19,  2.6,-29.88 } // 38    (zeta)    Sgr
   { 3.8, 19,  4.7,-21.74 } // 39    (omikron) Sgr
   { 3.3, 19,  6.9,-27.67 } // 40    (tau)     Sgr
   { 2.9, 19,  9.8,-21.02 } // 41    (pi)      Sgr
   { 4,   18, 59.6, 15.07 } // 13    (epsilon) Aql
   { 4,   19,  1.7, -5.74 } // 12              Aql
   { 5.2, 19,  5,   -4.03 } // 15              Aql
   { 3,   19,  5.4, 13.86 } // 17    (zeta)    Aql
   { 3.4, 19,  6.2, -4.88 } // 16    (lambda)  Aql
   { 7.9, 19,  6.4,  8.23 } //  R              Aql
fluctuating
   { 3.4, 19, 25.5,  3.11 } // 30    (delta)   Aql
   { 4.4, 19, 28.7, 24.66 } //  6    (alpha)   Vul
   { 4.4, 19, 40.1, 18.01 } //  5    (alpha)   Sge
   { 4.4, 19, 41,   17.48 } //  6    (beta)    Sge
   { 2.7, 19, 46.3, 10.61 } // 50    (gamma)   Aql (Tarazed)
   { 3.7, 19, 47.4, 18.53 } //  7    (delta)   Sge
   { 5.7, 19, 48.7, 11.82 } // 52    (pi)      Aql
multiple
   { 0.8, 19, 50.8,  8.87 } // 53    (alpha)   Aql (Altair)
   { 3.95,19, 52.5,  1.01 } // 55    (eta)     Aql
fluctuating
   { 5.3, 19, 54.6, -8.23 } // 57              Aql
multiple
   { 3.7, 19, 55.3,  6.41 } // 60    (beta)    Aql (Alschain)
   { 3.5, 19, 58.8, 19.49 } // 12    (gamma)   Sge
   { 5.2, 20,  2,   24.94 } // 16              Vul
multiple
   { 5.4, 20,  4.1, 17.08 } // 15              Sge
   { 3.2, 20, 11.3, -0.82 } // 65    (theta)   Aql
   { 4,   20, 33.2, 11.3  } //  2    (epsilon) Del
   { 3.6, 20, 37.5, 14.6  } //  6    (beta)    Del
   { 3.8, 20, 39.6, 15.91 } //  9    (alpha)   Del
   { 4.4, 20, 43.5, 15.07 } // 11    (delta)   Del
   { 3.9, 20, 46.7, 16.12 } // 12    (gamma)   Del
multiple
   { 3.9, 19, 21.7,-17.85 } // 44    (rho1)    Sgr
   { 4.3, 20, 17.6,-12.51 } //  5    (alpha1)  Cap (Algiedi Secundus)
   { 3.6, 20, 18.1,-12.54 } //  6    (alpha2)  Cap (Algiedi Primus)
known from "Dune" (Harkonnen system)
   { 3,   20, 21,  -14.78 } //  9    (beta)    Cap
multiple
   { 4.6, 20, 28.9,-17.82 } // 11    (rho)     Cap
   { 5.5, 20, 29.9,-18.58 } // 12    (omikron) Cap
multiple
   { 4.1, 20, 46.1,-25.27 } // 16    (psi)     Cap
   { 4.1, 20, 51.8,-26.92 } // 18    (omega)   Cap
   { 4.1, 21,  5.9,-17.23 } // 23    (theta)   Cap
   { 4.3, 21, 22.2,-16.83 } // 32    (iota)    Cap
   { 3.8, 21, 26.7,-22.41 } // 34    (zeta)    Cap
   { 3.7, 21, 40.1,-16.66 } // 40    (gamma)   Cap
   { 2.95,21, 47,  -16.13 } // 49    (delta)   Cap (Deneb Algiedi)
fluctuating
   { 5.4, 22,  0.8,-28.45 } // 12    (eta)     PsA
multiple
   { 4.3, 22, 31.5,-32.35 } // 17    (beta)    PsA
multiple
   { 4.2, 22, 40.7,-27.04 } // 18    (epsilon) PsA
   { 4.5, 22, 52.5,-32.88 } // 22    (gamma)   PsA
multiple
   { 4.2, 22, 55.9,-32.54 } // 23    (delta)   PsA
   { 1.2, 22, 57.6,-29.62 } // 24    (alpha)   PsA (Fomalhaut)
   { 5.2, 20, 59.1,  4.29 } //  1    (epsilon) Equ
multiple
   { 4.7, 21, 10.3, 10.13 } //  5    (gamma)   Equ
   { 4.5, 21, 14.5, 10.01 } //  7    (delta)   Equ
   { 3.9, 21, 15.8,  5.25 } //  8    (alpha)   Equ (Kitalphar)
   { 4.1, 21, 22.1, 19.8  } //  1              Peg
   { 2.4, 21, 44.2,  9.88 } //  8    (epsilon) Peg (Enif)
   { 4.1, 21, 44.6, 25.65 } // 10    (kappa)   Peg
   { 3.8, 22,  7,   25.35 } // 24    (iota)    Peg
   { 4.3, 22, 10,   33.18 } // 29    (pi)      Peg (pi2 Pegasi)
   { 3.5, 22, 10.2,  6.2  } // 26    (theta)   Peg (Baham)
   { 5.5, 22, 30,    4.43 } // 37              Peg
   { 3.4, 22, 41.5, 10.83 } // 42    (zeta)    Peg (Homam)
   { 2.9, 22, 43,   30.22 } // 44    (eta)     Peg (Matar)
   { 4,   22, 46.5, 23.57 } // 47    (lambda)  Peg
   { 4.2, 22, 46.7, 12.17 } // 46    (xi)      Peg
   { 3.5, 22, 50,   24.6  } // 48    (my)      Peg (Sadalbari)
   { 2.5, 23,  3.8, 28.08 } // 53    (beta)    Peg (Scheat)
fluctuating
   { 4.5, 23,  3.9,  3.82 } //  4    (beta)    Psc
   { 2.5, 23,  4.8, 15.21 } // 54    (alpha)   Peg (Markab)
   { 3.7, 23, 17.2,  3.28 } //  6    (gamma)   Psc
   { 4.3, 23, 28,    6.38 } // 10    (theta)   Psc
   { 5,   23, 34,   31.33 } // 72              Peg
multiple
   { 4.1, 23, 39.9,  5.63 } // 17    (iota)    Psc
   { 4.5, 23, 42,    1.78 } // 18    (lambda)  Psc
   { 5,   23, 46.4,  3.49 } // 19              Psc (TX Piscium)
fluctuating
   { 4,   23, 59.3,  6.86 } // 28    (omega)   Psc
   { 3.8, 20, 47.7, -9.5  } //  2    (epsilon) Aqr
   { 5.5, 21,  4.1, -5.82 } // 12              Aqr
multiple
   { 4.5, 21,  9.6,-11.37 } // 13    (ny)      Aqr
   { 2.9, 21, 31.6, -5.57 } // 22    (beta)    Aqr (Sadalsuud)
   { 3,   22,  5.8, -0.32 } // 34    (alpha)   Aqr (Sadalmelik)
   { 5.3, 22, 14.3,-21.07 } // 41              Aqr
multiple
   { 3.9, 22, 21.7, -1.39 } // 48    (gamma)   Aqr (Sadachbia)
   { 3.7, 22, 28.8, -0.02 } // 55    (zeta)    Aqr
multiple
   { 4,   22, 35.4, -0.12 } // 62    (eta)     Aqr
   { 4,   22, 49.6,-13.59 } // 71    (tau2)    Aqr
   { 3.7, 22, 52.6, -7.58 } // 73    (lambda)  Aqr
   { 3.3, 22, 54.6,-15.82 } // 76    (delta)   Aqr
   { 3.7, 23,  9.4,-21.17 } // 88              Aqr
   { 5.1, 23, 19.1,-13.46 } // 94              Aqr
multiple
   { 4,   23, 23,  -20.1  } // 98              Aqr
   { 4.7, 23, 33.3,-20.91 } //101              Aqr
multiple
   { 4.8, 23, 41.8,-17.81 } //104              Aqr
   { 8,   23, 43.8,-15.28 } //  R              Aqr
fluctuating
   { 5.3, 23, 46,  -18.68 } //107              Aqr
multiple
   { 3.9,  0,  9.4,-45.75 } //       (epsilon) Phe
   { 2.8,  0, 25.8,-77.25 } //       (beta)    Hyi
   { 3.9,  0, 26.2,-43.68 } //       (kappa)   Phe
   { 2.4,  0, 26.3,-42.31 } //       (alpha)   Phe (Ankaa)
   { 3.7,  0, 31.6,-62.96 } //       (beta)    Tuc
multiple
   { 3.3,  1,  6.1,-46.72 } //       (beta)    Phe
   { 3.15, 1,  8.4,-55.25 } //       (zeta)    Phe
   { 3.4,  1, 28.4,-43.32 } //       (gamma)   Phe
   { 3.9,  1, 31.3,-49.07 } //       (delta)   Phe
   { 0.5,  1, 37.7,-57.24 } //       (alpha)   Eri (Achernar)
   { 5,    1, 39.8,-56.2  } //  p              Eri
multiple
   { 3.7,  1, 56,  -51.61 } //       (chi)     Eri
   { 2.9,  1, 58.8,-61.57 } //       (alpha)   Hyi
   { 3.6,  2, 16.5,-51.51 } //       (phi)     Eri
   { 4.1,  2, 40.7,-39.86 } //       (iota)    Eri
   { 8.85, 2, 53.9,-49.89 } //  R              Hor
fluctuating
   { 2.9,  2, 58.3,-40.3  } //       (theta)   Eri (Acamar)
multiple
   { 4.3,  3, 48.6,-37.62 } //  f              Eri
multiple
   { 3.8,  3, 44.2,-64.81 } //       (beta)    Ret
   { 3.3,  3, 47.2,-74.24 } //       (gamma)   Hyi
   { 4.6,  3, 58.7,-61.4  } //       (delta)   Ret
   { 3.9,  4, 14,  -42.29 } //       (alpha)   Hor
   { 3.3,  4, 14.4,-62.47 } //       (alpha)   Ret
   { 4.3,  4, 16,  -51.49 } //       (gamma)   Dor
   { 4.4,  4, 16.5,-59.3  } //       (epsilon) Ret
   { 3.3,  4, 34,  -55.05 } //       (alpha)   Dor
   { 5.2,  4, 50.9,-53.46 } //       (iota)    Pic
multiple
   { 3.75, 5, 33.6,-62.49 } //       (beta)    Dor
fluctuating
   { 3.9,  5, 47.3,-51.07 } //       (beta)    Pic
   { 4.5,  5, 49.8,-56.17 } //       (gamma)   Pic
   { 4,    5, 59.1,-42.82 } //       (eta)     Col
   {-0.7,  6, 24,  -52.7  } //       (alpha)   Car (Canopus)
known from "Dune" (planet Arrakis)
   { 3.2,  6, 37.8,-43.2  } //       (ny)      Pup
   { 3.2,  6, 48.2,-61.94 } //       (alpha)   Pic
   { 2.9,  6, 49.9,-50.61 } //       (tau)     Pup
   { 3.6,  7,  8.7,-70.5  } //       (gamma)   Vol
multiple
   { 4,    7, 16.8,-67.96 } //       (delta)   Vol
   { 3.9,  7, 41.8,-72.61 } //       (zeta)    Vol
   { 3.5,  7, 56.8,-52.98 } //       (chi)     Car
   { 4.7,  8, 19.9,-71.51 } //       (kappa)   Vol
multiple
   { 1.9,  8, 22.5,-59.51 } //       (epsilon) Car (Avoir)
   { 3.8,  8, 25.7,-66.14 } //       (beta)    Vol
   { 3.8,  8, 55,  -60.64 } //  c              Car
   { 4,    9,  2.4,-66.4  } //       (alpha)   Vol
   { 4.5,  7, 13.5,-44.64 } //  L2             Pup
fluctuating
   { 2.7,  7, 17.1,-37.1  } //       (pi)      Pup
   { 4.1,  7, 18.4,-36.74 } //  y    (upsilon) Pup
multiple
   { 3.3,  7, 29.2,-43.3  } //       (sigma)   Pup
   { 3.6,  7, 45.3,-37.97 } //  c              Pup
   { 3.7,  7, 52.2,-40.58 } //  a              Pup
   { 2.2,  8,  3.6,-40    } //       (zeta)    Pup
   { 1.6,  8,  9.5,-47.34 } //       (gamma)   Pup (Suhail al-Muhlif)
   { 3.6,  8, 40.3,-52.92 } //       (omikron) Pup
   { 3.8,  8, 40.6,-46.65 } //  b              Vel
   { 4,    8, 44.4,-42.65 } //  d              Vel
multiple
   { 1.9,  8, 44.7,-54.71 } //       (delta)   Vel
   { 3.9,  8, 46,  -46.04 } //  a              Vel
   { 3.8,  9,  4.2,-47.1  } //  c              Vel
   { 2.2,  9,  8,  -43.43 } //       (lambda)  Vel (Suhail al-Wazn)
   { 2.5,  9, 22.1,-55.01 } //       (kappa)   Vel
   { 3.6,  9, 30.7,-40.47 } //       (psi)     Vel
   { 3.5,  9, 56.9,-54.57 } //       (phi)     Vel
   { 3.9, 10, 14.7,-42.12 } //  q              Vel
   { 3.8, 10, 37.3,-48.23 } //  p              Vel
   { 4.1, 10, 39.3,-55.6  } //  x              Vel
multiple
   { 2.7, 10, 46.8,-49.42 } //       (my)      Vel
   { 4.1,  8, 18.5,-76.92 } //       (alpha)   Cha
   { 4.7,  8, 57,  -59.23 } //  b1             Car
multiple
   { 3.4,  9, 11,  -58.97 } //  a              Car
   { 4,    9, 11.3,-62.32 } //  i              Car
   { 1.7,  9, 13.2,-69.72 } //       (beta)    Car (Miaplacidus)
   { 2.2,  9, 17.1,-59.28 } //       (iota)    Car
   { 3.2,  9, 31.2,-57.03 } //  N              Vel
   { 6.85, 9, 32.2,-62.79 } //  R              Car
fluctuating
   { 3.7,  9, 45.2,-62.51 } //  l              Car (ZZ Carinae)
fluctuating
   { 2.9,  9, 47.1,-65.07 } //       (upsilon) Car
multiple
   { 3.3, 10, 13.7,-70.04 } //       (omega)   Car
   { 3.4, 10, 17.1,-61.33 } //  q              Car
   { 3.9, 10, 24.4,-74.02 } //  I              Car
   { 3.8, 10, 27.9,-58.74 } //  s              Car
   { 3.3, 10, 32,  -61.69 } //  p              Car
   { 4.1, 10, 35.5,-78.61 } //       (gamma)   Cha
   { 2.7, 10, 43,  -64.39 } //       (theta)   Car
   { 4.1, 10, 45.6,-80.52 } //       (delta)   Cha
multiple
   { 3.7, 10, 53.5,-58.86 } //  u              Car
   { 3.9, 11,  8.6,-58.97 } //  x              Car
   { 4.7, 11, 59.7,-78.22 } //       (epsilon) Cha
   { 3.9, 11, 21,  -54.49 } //       (pi)      Cen
   { 4.4, 11, 31.8,-59.48 } //       (omikron) Cen
   { 3.1, 11, 35.8,-63.02 } //       (lambda)  Cen
   { 3.6, 11, 45.6,-66.73 } //       (lambda)  Mus
   { 2.4, 12,  8.3,-50.71 } //       (delta)   Cen
multiple
   { 4,   12, 11.7,-52.37 } //       (rho)     Cen
   { 2.8, 12, 15.1,-58.75 } //       (delta)   Cru
   { 4.15,12, 17.6,-67.96 } //       (epsilon) Mus
fluctuating
   { 4.1, 12, 18.4,-64    } //       (zeta)    Cru
   { 3.55,12, 21.4,-60.4  } //       (epsilon) Cru
fluctuating
   { 0.7, 12, 26.6,-63.1  } //       (alpha)   Cru (Acrux)
multiple
   { 3.9, 12, 28,  -50.23 } //       (sigma)   Cen
   { 1.6, 12, 31.2,-57.11 } //       (gamma)   Cru (Gacrux)
   { 3.8, 12, 32.5,-72.13 } //       (gamma)   Mus
   { 2.7, 12, 37.2,-69.14 } //       (alpha)   Mus
   { 3.9, 12, 37.7,-48.54 } //       (tau)     Cen
   { 2.2, 12, 41.5,-48.96 } //       (gamma)   Cen
   { 3,   12, 46.3,-68.11 } //       (beta)    Mus
multiple
   { 1.3, 12, 47.7,-59.69 } //       (beta)    Cru (Mimosa)
   { 3.7, 12, 54.6,-57.18 } //       (my)      Cru
multiple
   { 3.6, 13,  2.3,-71.55 } //       (delta)   Mus
   { 2.8, 13, 20.6,-36.71 } //       (iota)    Cen
   { 4.3, 13, 22.6,-60.99 } //  J              Cen
multiple
   { 3.9, 13, 31,  -39.41 } //  d              Cen
   { 2.3, 13, 39.9,-53.47 } //       (epsilon) Cen
   { 5,   13, 41.7,-54.56 } //  Q              Cen
multiple
   { 3.4, 13, 49.5,-41.69 } //       (ny)      Cen
   { 3.25,13, 49.6,-42.47 } //       (my)      Cen
   { 2.5, 13, 55.5,-47.29 } //       (zeta)    Cen
   { 3.8, 13, 58.3,-42.1  } //       (rho)     Cen
   { 3.9, 13, 58.7,-44.8  } //       (upsilon1)Cen
   { 0.6, 14,  3.8,-60.37 } //       (beta)    Cen (Hadar, Agena)
   { 2.1, 14,  6.7,-36.37 } //  5    (theta)   Cen
   { 7.9, 14, 16.6,-59.91 } //  R              Cen
fluctuating
   { 2.3, 14, 35.5,-42.16 } //       (eta)     Cen
   {-0.3, 14, 39.6,-60.83 } //       (alpha)   Cen (Rigil Kentaurus)
multiple
   { 4,   14, 42,  -37.79 } //  b              Cen
   { 3.2, 14, 42.5,-64.98 } //       (alpha)   Cir
   { 3.1, 14, 59.2,-42.1  } //       (kappa)   Cen
   { 4.6, 15, 16.8,-60.94 } //       (delta)   Cir
multiple
   { 4.1, 15, 17.5,-58.8  } //       (beta)    Cir
   { 4.5, 15, 23.4,-59.32 } //       (gamma)   Cir
   { 3.5, 14, 19.4,-46.06 } //       (iota)    Lup
   { 2.3, 14, 41.9,-47.39 } //       (alpha)   Lup
   { 2.7, 14, 58.5,-43.13 } //       (beta)    Lup
   { 3.9, 15,  5.1,-47.05 } //       (pi)      Lup
multiple
   { 3.7, 15, 11.9,-48.74 } //       (kappa)   Lup
multiple
   { 3.4, 15, 12.3,-52.1  } //       (zeta)    Lup
multiple
   { 4.1, 15, 18.5,-47.88 } //       (my)      Lup
quadruple
   { 3.2, 15, 21.4,-40.65 } //       (delta)   Lup
   { 3.6, 15, 21.8,-36.26 } //       (rho1)    Lup
   { 3.4, 15, 22.7,-44.69 } //       (epsilon) Lup
   { 2.8, 15, 35.1,-41.17 } //       (gamma)   Lup
   { 4.5, 15, 35.9,-44.96 } //  d              Lup
multiple
   { 3.4, 16,  0.1,-38.4  } //       (eta)     Lup
multiple
   { 4,   16, 19.8,-50.16 } //       (gamma2)  Nor
   { 4.4, 16, 27.2,-47.55 } //       (epsilon) Nor
multiple
   { 3.8, 16, 49.8,-59.04 } //       (eta)     Ara
   { 3.1, 16, 58.6,-55.99 } //       (zeta)    Ara
   { 4.1, 16, 59.6,-53.16 } //       (epsilon1)Ara
   { 2.8, 17, 25.3,-55.53 } //       (beta)    Ara
   { 3.3, 17, 25.4,-56.38 } //       (gamma)   Ara
   { 3.6, 17, 31.1,-60.68 } //       (delta)   Ara
   { 2.9, 17, 31.8,-49.88 } //       (alpha)   Ara
   { 3.7, 18,  6.6,-50.09 } //       (theta)   Ara
   { 3.05,16, 51.9,-38.05 } //       (my1)     Sco
fluctuating
   { 3.6, 16, 52.3,-38.02 } //       (my2)     Sco
   { 3.6, 16, 54.6,-42.36 } //       (zeta2)   Sco
   { 3.3, 17, 12.2,-43.24 } //       (eta)     Sco
   { 2.7, 17, 30.8,-37.39 } // 34    (upsilon) Sco (Lesath)
   { 1.6, 17, 33.6,-37.1  } // 35    (lambda)  Sco (Shaula)
   { 1.9, 17, 37.3,-43    } //       (theta)   Sco (Sargas)
   { 2.4, 17, 42.5,-39.03 } //       (kappa)   Sco
   { 3,   17, 47.6,-40.13 } //       (iota1)   Sco
   { 3.2, 17, 49.9,-37.04 } //  G              Sco
   { 3.1, 18, 17.6,-36.76 } //       (eta)     Sgr
multiple
   { 3.5, 18, 27,  -45.97 } //       (alpha)   Tel
   { 4.1, 18, 28.8,-49.07 } //       (zeta)    Tel
   { 5.2, 18, 33.4,-38.72 } //       (kappa)   CrA
multiple
   { 4.85,18, 58.7,-37.11 } //       (epsilon) CrA
fluctuating
   { 4.7, 19,  3.1,-42.1  } //       (zeta)    CrA
   { 4.2, 19,  6.4,-37.06 } //       (gamma)   CrA
multiple
   { 4.6, 19,  8.3,-40.5  } //       (delta)   CrA
   { 4.1, 19,  9.5,-37.9  } //       (alpha)   CrA
   { 4.1, 19, 10,  -39.34 } //       (beta)    CrA
   { 3.9, 19, 22.6,-44.46 } //       (beta1)   Sgr
multiple
   { 4,   19, 23.9,-40.62 } //       (alpha)   Sgr
   { 4.3, 14, 26.9,-83.67 } //       (delta)   Oct
   { 3.8, 14, 47.9,-79.04 } //       (alpha)   Aps
   { 2.9, 15, 18.9,-68.68 } //       (gamma)   TrA
   { 4.1, 15, 36.7,-66.32 } //       (epsilon) TrA
   { 2.8, 15, 55.1,-63.43 } //       (beta)    TrA
   { 3.9, 16, 15.4,-63.59 } //       (delta)   TrA
   { 4.2, 16, 20.4,-78.69 } //       (delta)   Aps
multiple
   { 3.9, 16, 33.5,-78.9  } //       (gamma)   Aps
   { 4.2, 16, 43.1,-77.52 } //       (beta)    Aps
   { 1.9, 16, 48.7,-69.03 } //       (alpha)   TrA
   { 3.6, 17, 45.7,-64.72 } //       (eta)     Pav
   { 4,   18, 43,  -71.43 } //       (zeta)    Pav
   { 4.2, 18, 52.2,-62.19 } //       (lambda)  Pav
   { 3.35,18, 56.9,-67.23 } //       (kappa)   Pav
fluctuating
   { 4,   20,  0.6,-72.91 } //       (epsilon) Pav
   { 3.6, 20,  8.7,-66.18 } //       (delta)   Pav
   { 1.9, 20, 25.6,-56.74 } //       (alpha)   Pav (Peacock)
   { 3.1, 20, 37.6,-47.29 } //       (alpha)   Ind
   { 3.4, 20, 45,  -66.2  } //       (beta)    Pav
   { 3.7, 20, 54.8,-58.45 } //       (beta)    Ind
   { 4.4, 21, 19.9,-53.45 } //       (theta)   Ind
multiple
   { 3.7, 21, 41.5,-77.39 } //       (ny)      Oct
   { 3,   21, 53.9,-37.37 } //       (gamma)   Gru
   { 1.7, 22,  8.2,-46.96 } //       (alpha)   Gru (Alnair)
   { 2.9, 22, 18.5,-60.26 } //       (alpha)   Tuc
   { 5.2, 22, 23,  -45.93 } //       (pi)      Gru
   { 4,   22, 29.3,-43.5  } //       (delta1)  Gru
   { 4.1, 22, 29.8,-43.75 } //       (delta2)  Gru
   { 2.1, 22, 42.7,-46.88 } //       (beta)    Gru
   { 4.1, 22, 46.1,-81.38 } //       (beta)    Oct
   { 3.5, 22, 48.6,-51.32 } //       (epsilon) Gru
   { 3.9, 23, 10.4,-45.25 } //       (iota)    Gru
   { 4,   23, 17.4,-58.24 } //       (gamma)   Tuc
// #declare minmag=6;                  // magnitude of the faintest
stars to be visible
// #declare w=800;                    // image width
// #declare an=50;                     // field of view
// #declare m=0.00058/(w/800)/(50/an); // radius of the faintest stars
adjusted to image width and field of view
// #declare fac=2;                     // logarithmic factor for orders
of magnitude,
                                     // should be smaller at low
resolutions to prevent bright stars
                                     // from being unnaturally large
#macro Stars(minmag, w, an, fac)
   #local stars=union
     #local m=0.00058/(w/800)/(50/an);
     #local a=0;
     #while (a<dimension_size(Cat, 1))
       #local rad=m*pow(fac, (minmag-Cat[a][0])/2);
       #local rec=-Cat[a][1]*15-Cat[a][2]*0.25;
       #local dec=Cat[a][3];
       sphere { <sin(rec*(pi/180))*cos(dec*(pi/180)), sin(dec*(pi/180)),
cos(rec*(pi/180))*cos(dec*(pi/180))>, rad }
       #declare a=a+1;
   sky_sphere
     pigment
       object { stars color rgb 0 color rgb 1 }
     rotate y*90
     rotate x*23.4333
// End addition by Yadgar
global_settings{
  assumed_gamma 1.0
  max_trace_level 20
Stars(7, 1024, 40, 1.3)
// *** PLANET ***
// planet texture
#declare t_planet=
pigment{
           color_map{
#declare t_planet=
texture{
  pigment{
           turbulence .05
           lambda 2.5
           omega 1.2
           pigment_map{
                    [0 rgb 1]
                    [.05  t_planet ]
#if(!Modelling)
// Cloud texture
#declare t_clouds=
texture{
          pigment{
                   turbulence <1,2,1>
                   lambda 2.5
                   omega 1.3
                         //lambda 3
                         omega 1.2
                   color_map{
                   rotate y*15
                   rotate -Rotar
// Cloud texture
#declare t_clouds=
                   scale Scalar
                   //lambda 2.5
                   omega 1.3
                   texture_map{
                            [0 t_clouds ]
                            [.5 t_clouds]
                            [1 t_clouds ]
// Planet
#declare Planet=
union{
                  max_gradient 3.8
                  scale y*1.002
        #if(ShowWater)
                sphere{0,1 // water
                               turbulence .1
                                lambda 7
                              colour_map{
                                       [0 rgbt<1,1,1,0> ]
.3*(!Modelling)]
.3*(!Modelling)]
                                       [1 rgbt<1,1,1,0> ]
                       #if(!Modelling)
<0,0,.1>}
                       scale .996
       #if(!Modelling)
                       interior{
                                media {
                                           intervals 10           //
                                           samples 1,1            //
                                           confidence 0.9         //
                                           variance 1.0/128       //
                                           ratio 0.9              //
                                           //method 3               //
adaptive sampling
                                           density {onion
                                                    color_map{
                                                            [.89 rgb .5]
// earth
                                                            [.93 rgb
<0,.5,.6>*.5]//
                                                            [.98 rgb
<0,0,.1>]//
                                                            [1 rgb 0 ]//
                       rotate y*90
                       scale 1.05
                       hollow
                       double_illuminate
        #if(ShowClouds)
                union{
                       rotate y*45
// placement
                         pigment{spherical
                                 cubic_wave
                                 colour_map{
                         finish{diffuse 1}
                         scale 2
                         hollow
                         double_illuminate
                         rotate <40,0,30>
         object{Planet }
         scale .3
         translate <0,0,0>
light_source{
          0,
          4
          fade_power 2
          translate <2,.1,.5>
camera{
  location <0,.5,0>
  up y
// End of file
See you on www.khyberspace.de!
Yadgar
Download 'pingpong.png' (624 KB)
Preview of image 'pingpong.png'
Date: 22 Mar 2008 08:07:35
Message: <47e50497@news.povray.org>
Damn hard to think of anything on that scene. It feels so ready with so
low amount of objects. But it's the end of the world as we know it,
while the nuclear flame is taking the planet and all life down.
Eero "Aero" Ahonen
    http://www.zbxt.net
Download 'pingpong.jpg' (74 KB) Download 'us-ascii' (8 KB)
Preview of image 'pingpong.jpg'
Date: 22 Mar 2008 17:50:00
Message: <web.47e58b9d41aa233d1b8ed7370@news.povray.org>
making 3000 star cat with more data but running into typecast issues.
#declare catalog2 = array[1][7] {
{ "5.1","23","2.606","41.757778","A3","107.18092300280163","And 02" }
works. typecast (float)string, then ok but I am not finding that.
#declare catalog = array[1][7] {
{ 5.1,23,2.606,41.757778,"A3",107.18092300280163,"And 02" }
fails of course.
whats the solution besides 2 arrays, a string and float array?
