POV-Ray : Newsgroups : povray.binaries.images : butterfly tunnel Server Time
4 Nov 2024 22:18:03 EST (-0500)
  butterfly tunnel (Message 1 to 9 of 9)
Subject: butterfly tunnel
Date: 13 Mar 2008 22:00:00
Message: <web.47d9e95586031cb3302326b70@news.povray.org>
A single butterfly follows a spline curve through a marble tunnel.
If there had been three of these following one another, I would have had to bump
max_trace_level up to 8.
Download 'pentaknot_ii015.jpg' (43 KB)
Preview of image 'pentaknot_ii015.jpg'
Subject: Re: butterfly tunnel
Date: 14 Mar 2008 06:52:27
Message: <47da66fb@news.povray.org>
"Russell Towle" <rto### [at] inreachcom> wrote in message
news:web.47d9e95586031cb3302326b70@news.povray.org...
> to bump
I like the butterfly. I'm working on a scene with a wind chime and thought a
bird or butterfly on the fence post might add a nice touch to my scene. How
did you make the butterfly? I downloaded a couple butterfly pictures to use
a an image plane in Wings but haven't gotten a good start with that yet, so
any deatails about you model/method would be appreciated.
Nice job!
Jim
Date: 14 Mar 2008 07:19:05
Message: <47da6d39$1@news.povray.org>
"Jim Holsenback" <jho### [at] hotmailcom> wrote in message
news:47da66fb@news.povray.org...
> a bird or butterfly on the fence post might add a nice touch to my scene.
> How did you make the butterfly? I downloaded a couple butterfly pictures
> to use a an image plane in Wings but haven't gotten a good start with that
> yet, so any deatails about you model/method would be appreciated.
       Hi Jim, if you're interested, I've uploaded an .obj model that you
can play with and see how I did it in Wings. It's a very simple model that
you can do what you want with, but you'll see how I kind of drew the
patterns on the wings. It's based on a Peacock butterfly, and is good for
distance shots.
     http://myweb.tiscali.co.uk/3dextra/butterfly.zip  (117kb's)
         ~Steve~
> Nice job!
> Jim
Date: 14 Mar 2008 10:15:00
Message: <web.47da964a6058b50f5dd2a470@news.povray.org>
> > to bump
The butterfly is from a photo of mine in which I managed to carefully select
only the butterfly itself and then make everything else black. POV_Ray's
image_map syntax allows transparency. Here is how I did it:
box {< 0, 0, -.001>, < 1, 1, 0.001>
 image_map {
  gif "black3016.gif"
  transmit 0, 1
  map_type 0 //planar
  once
  interpolate 0 //none
finish{ambient .5}
Date: 14 Mar 2008 11:33:49
Message: <47daa8ed@news.povray.org>
news:web.47da964a6058b50f5dd2a470@news.povray.org...
> select
> pigment {
> image_map {
>  gif "black3016.gif"
>  transmit 0, 1
>  map_type 0 //planar
>  once
> finish{ambient .5}
ah .... thought it was a model (casts shadows) but i see that transmit 0,1
handles the black area .... thanks
Date: 14 Mar 2008 11:35:06
Message: <47daa93a@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:47da6d39$1@news.povray.org...
>  It's based on a Peacock butterfly, and is good for distance shots.
excellent .... thanks!!!
Date: 14 Mar 2008 12:45:00
Message: <web.47dab9396058b50fa8d0b25a0@news.povray.org>
Why the spline curve?  Are you planning on animating the little guy??
Dan
GoofyGraffix.com
Date: 14 Mar 2008 13:30:01
Message: <web.47dac3736058b50fd041265b0@news.povray.org>
> Dan
> GoofyGraffix.com
Definitely, in fact the image is one frame from an animation. I have done a
number of animations which involve butterflies following spline curves. I
sometimes, as in this image, use a union of cylinders and spheres of some
suitable radius, following the spline curve, and subtract that union from a
large sphere or cube, creating a tunnel or tunnels leading in and out of the
sphere or cube. Then I fly the camera through the tunnels and often the camera
is following several objects. Perhaps one or more butterflies.
I have found tho that I must take care to have many many frames or else the
action happens too fast.
Hence, once again, I need a render farm.
Date: 14 Mar 2008 15:24:28
Message: <47dadefc@news.povray.org>
news:47daa93a@news.povray.org...
  :)  No problem. Take a look at the underside of the wings, that's what the
top side looked like before I played with it. It was really a matter of
using 'bevel' a lot, deleting certain verts, and then adding certain verts
and then 'connecting' them in a logical manner to get the desired result. I
use this method fairly frequently, and it seems to work well so far. Have
fun with it. :)
      ~Steve~
