POV-Ray : Newsgroups : povray.binaries.images : Brute force rendering Server Time
28 Aug 2025 11:34:20 EDT (-0400)
  Brute force rendering (Message 68 to 77 of 97)
Subject: Re: Brute force rendering
Date: 5 Mar 2008 16:58:29
Message: <47cf1785$1@news.povray.org>
Nicolas Alvarez wrote:
>> and this:
>> http://www.winosi.onlinehome.de/Gallery_t15.htm
> But in terms of impressiveness, Gallery_t15.htm sure wins :)
True. But in the world of brute force renderers that is not _that_
impressive - quite impressive still. As all sources of light rays are
equal it is no wonder that we see regularly diffuse caustics and other
similar indirect effects. Light is always considered light - no matter
where it came from. This is the basis of all those very realistic images.
The same way I remember the time when 3dMax didn't know how to render
refraction or similar "simple" effects and POV-Ray could do it. After
using POV for quite some time it doesn't feel _that_ impressive :)
Ok, I admit it: it is quite impressive.
Date: 5 Mar 2008 16:59:48
Message: <47cf17d4$1@news.povray.org>
> impressive
You still haven't shown me your renderer do it >:)
Date: 5 Mar 2008 18:55:15
Message: <47cf32e3$1@news.povray.org>
Severi Salminen wrote:
> Hmm. What kind of "interesting ideas" you mean? Do you have any links to
> sample images?
Here's the thread that gave me the idea:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4360929f30852916731f01d10@news.povray.org%3E/?mtop=10
Currently, there's a cap on how big things can be in Povray. More
importantly, there's a limit on putting big things and little things in
the same scene.
With high-precision geometry, you are free to model entire solar systems
to scale. With arbitrary-precision geometry, you could model entire
galaxies to scale! :-D
William Tracy
Now we know everything there is to know about ML, except how to program!
     -- Jeffrey D. Ullman, _Elements of ML Programming_
Date: 5 Mar 2008 18:56:50
Message: <47cf3342$1@news.povray.org>
And the render time would be similar to flying to another galaxy with
current technology? :)
Date: 6 Mar 2008 01:50:41
Message: <47cf9441@news.povray.org>
>> impressive
Here you are :) A bit grainy still and a different setup but still shows
indirect caustics - as it should.
Download 'kuva13.jpg' (19 KB)
Preview of image 'kuva13.jpg'
Date: 6 Mar 2008 03:30:00
Message: <web.47cfaabf6d8b2453943b35b60@news.povray.org>
> W000t! Where can I get my prize? :-)
I haven't rendered it yet :P
> 2. What was the actual color value you specified for the green glass?
> Maybe the glass is so dark that multiple layers simply don't let enough
> light through?
RGB <59, 255, 96> refraction with White 100% reflection also, an IOR of 1.56 and
fresnel falloff.
When I did the MLT/PT render that I posted initially the light passed through no
problems.. since then some setting must have changed. I don't know :)
> 3. My image seems to have less noise on the table and more noise on the
> floor.
That is correct for PT because directly lit surfaces will receive more light and
so smooth out much faster than indirectly lit or occluded (the floor) surfaces.
> So this is not very scientific result. At some point I'll make a better
> test scene and post the dimensions. Or anyone else can do it. Maybe in
> Pov-SDL so we can compare results from it too. And we can keep this even
> remotely on-topic :-)
I wait eagerly both for the chance to do some comparisons with the same data but
also for the time when we can try out your renderer ourselves!
Date: 6 Mar 2008 03:55:00
Message: <web.47cfb0fe6d8b2453943b35b60@news.povray.org>
Just had a look in the settings.. MLT goes up to 100 bounces with a stay-alive
probability of 0.7 (the same termination method yours does, but also with a
hard limit), but PT has a default max of 6!!
Taking it to 20 is enough to get the glass to render transparent. :blush:
OK, now you can get back on topic. Sorry.
Date: 6 Mar 2008 09:13:07
Message: <47cffbf3$1@news.povray.org>
fidos wrote:
> Here a rendering of 1h on one core of a Q6600 2.4 GHz with my MegaPov Montecarlo
> Path tracing patch. Noise is important but there is no spikes.
  I find the almost complete lack of color bleeding from the colored
walls to the white walls/ceiling rather suspicious.
  Don't tell me your patch only reflects brightness, not color?
Date: 6 Mar 2008 11:42:22
Message: <47d01eee@news.povray.org>
Quite possibly.
I haven't been able to dredge up any material of the performance of
arbitrary-precision numbers versus simple primitives (not that I've
looked very hard yet). I don't know if I'm dealing with something twice
as slow, or a full order of magnitude speed difference, or something
that gets exponentially worse.
But, yeah, it's definitely going to be slow. :-)
William Tracy
    It occurred to him that now he was going to be not only the first
man on Mars, but the first detective. He grinned at the thought, and the
last action of the omegendorph set his nerves aglow.
     -- Kim Stanley Robinson, _Red Mars_
Date: 6 Mar 2008 12:34:44
Message: <47d02b34@news.povray.org>
GMP is a very fast arbitrary-size number library. But it's integer only
so I don't think that can help you much :)
