POV-Ray : Newsgroups : povray.binaries.images : Brute force rendering Server Time
4 Sep 2025 08:01:15 EDT (-0400)
  Brute force rendering (Message 18 to 27 of 97)
Subject: Re: Brute force rendering
Date: 26 Feb 2008 05:25:01
Message: <web.47c3e8bc6d8b2453bba410650@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote:
> > Yes, the inside of a RL glass surface reflects about the same as
> > the outside, sometimes a bit more reflective, since grime can
> > build up on the outside, but not on the inside.
> Are you sure?  A watersurface seems a lot more reflective from underneath
> the water than from above the water. Could be an optical illusion though.
> <snip>
http://en.wikipedia.org/wiki/Total_internal_reflection
Date: 26 Feb 2008 06:40:01
Message: <web.47c3fa2a6d8b2453d8eae6c40@news.povray.org>
> > <snip>
We were not talking about total internal reflections, but normal specular
reflections. I have the impression that they happen about equally to both
directions.
Date: 26 Feb 2008 09:11:10
Message: <47c41dfe@news.povray.org>
Severi Salminen wrote:
> Warp wrote:
>>   Speaking of which, does it handle total internal reflection properly?
> Yeah, I think it does. But I don't have proper objects to test it
> properly so I'm not 100% sure yet.
  Try with the example at wikipedia:
http://en.wikipedia.org/wiki/Image:Total_internal_reflection.jpg
>>   (OTOH, that would also be something which should be specified with a
>> physically accurate BRDF instead of being hard-coded into the renderer...)
> I have no idea how to represent an arbitary BRDF or BSDF. But you get
> quite far even with traditional refraction/specular/diffuse models.
  The problem with the "traditional" lighting models is that they are
not physically accurate and thus do not produce completely realistic
results.
  The whole reason why the "traditional" lighting models were developed
was precisely to avoid having to send millions of rays from each
intersection point. They try to approximate (often poorly) what would
happen if you would send the millions of rays and have a physically
accurate BRDF, but they are only approximations.
  If you are bruteforce-rendering anyways, using these limited lighting
models kind of becomes moot. They were created precisely for
non-bruteforce rendering because bruteforce rendering was unfeasible.
Now that you are bruteforce-rendering, there's no need to use them. You
can use realistic BRDFs.
  In principle a BRDF is quite simple: It's a function which takes an
incoming direction vector and an outcoming direction vector as (const)
parameters, and returns a factor for each color component between 0.0
and 1.0. That's it. Its usage is equally simple: When you have
calculated a ray which intersects a surface and want to reflect that ray
to some direction, you shoot that reflected ray and then multiply the
color returned by that ray with the factor returned by the BRDF of that
surface. This will be the color returned by the original incoming ray.
  Of course implementing the BRDF to be physically accurate is not that
simple.
Date: 26 Feb 2008 09:55:00
Message: <web.47c427256d8b2453899afcd0@news.povray.org>
> > > <snip>
> directions.
I know that the discussion was about 'normal' reflection. I was only referring
to the post by Zeger Knaepen since total internal reflection is what's making
up the phenomenon he's describing in his post.
Regards Roman
Date: 26 Feb 2008 12:25:00
Message: <web.47c44b5f6d8b2453d8eae6c40@news.povray.org>
I really have now only spheres and planes. Boxes next.
I don't know. I think these are different things. Brute force helps to create
every lighting effect which depends on light bouncing multiple times. BRDF, on
the other hand, just represents the way light reflects. So they address
different problems. But it is true that both should be handled and taken into
account in a good renderer.
I think that is not the best way to implement it. Better way is to use a ray
distribution function that generates rays distributed according to BSDF. Now I
use cosine weighted function to create random rays at diffuse surface. This
minimizes useless rays and gives faster results - but is unbiased. And I create
pure specular rays at specular surface - no need to create other rays and give
them weight 0. The result is identical but faster. There are good functions for
different glossy surfaces also.
So basically I'm using certain ideal BSDF's but "ideal" is not necessarily
"physically possible"...
Date: 26 Feb 2008 13:12:44
Message: <47c4569c$1@news.povray.org>
  Of course you *can* perform brute-force rendering without using BRDFs.
The point is that it doesn't make too much sense because BRDFs are the
most accurate texture definition functions, while everything used in
non-brute-force rendering is only an inaccurate approximation.
Brute-force rendering allows using BRDFs, so why not use them?
  I didn't say anything about which direction the reflected ray should
go. The BRDF doesn't care.
  You can, of course, send more rays towards directions for which the
BRDF gives larger factors.
Date: 26 Feb 2008 13:17:32
Message: <47c457bc$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/02/25 11:32:
> you're using photon mapping for the caustics, right?  Ever since these
> guys have been posting these bruteforce renders, I've been noticing an
> interesting pattern about photon mapping:  the caustics don't match the
> shape of the source of light, you look at your render and to that of
> Severi and you notice your caustics are focused in one point while his
> are large and in the shape of the light sphere.  And that is to be
> expected, since photon mapping reacts to the (point)light source, not to
> a physical object emitting light, like in the bruteforce methods.
> But radiosity works ok for that purpose.  Like here, just first
> radiosity pass as I don't have the time right now for a complete
> render... there are a few radiosity artifacts left, you could raise the
> count a bit...
With photons, you can have broad caustics. You need to add "area_light" in the
photons block of the area_light.
Here's an area_light that will emit photons from a "spherical" area:
light_source{Location, rgb 1 area_light 3*x,3*y 17,17 autostop 0 circular orient
photons{area_light}// the key of having soft caustics
EVERYTHING HAS A GENDER
You may not know this but many nonliving things have a gender...
A Subway is Male, because it uses the same old lines to pick people up.
Date: 26 Feb 2008 22:39:15
Message: <47c4db63@news.povray.org>
> Glass has about 4% reflection coefficient when angle of incidence is 0.
> I guess this 4% holds true both when entering glass and exiting it?
It's more complicated than that in reality. Light doesn't reflect from
the surface of the glass. It reflects inside the glass. It only seems
like it reflects from the surface because different paths that reflect
at different depths in the glass cancel out. A piece of glass the proper
thickness has no "surface reflection" at all, and a half wavelength
thicker and it has 16% reflection. So, technically speaking, there's no
"reflection off the back" at all - it's just that the math works out to
make it look like there is. (And I have no idea where I left the book I
have that explains the math well enough to indicate whether the math
works out to make it look like a 4% reflection off the back, too. ;-)
(Similarly, a mirror reflects all over its surface, but only the paths
where incidence = reflection don't tend to cancel out. Diffraction
gratings and holograms take advantage of this, for example.)
I mean, if you're talking about "physically-accurate" tracing. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 27 Feb 2008 13:08:20
Message: <47c5a714@news.povray.org>
Thanks for the clarification. The important part is the actual net
effect that affects the image. If the 4% (or whatever n1 and n2 gives)
holds true in most cases and is accurate within some margin - that is
suitable for now.
Definitely :=)
But at this point I'm mostly interested in reproducing the effects that
make bigger difference in final image. For example:
having no shadows is worse than having inaccurate sharp shadows
inaccurate sharp shadows < inaccurate area_light approximation
Lack of accurate GI < lack of dispersion
lack of dispersion < slightly inaccurate refraction model (light bends a
bit too far etc.)
etc.
So things must be fixed in priority order. Here is the same scene with
5% reflection in the spheres - including the light that tries to exit
the sphere :) 46000 passes. Quite smooth rendering.
I'm now experimenting with Halton sequence that replaces totally random
rays. It is deterministic but should give more uniform distribution. So
less samples are needed for certain noise level. Not working properly yet...
Download 'kuva10.jpg' (38 KB)
Preview of image 'kuva10.jpg'
Date: 27 Feb 2008 14:17:12
Message: <47c5b738$1@news.povray.org>
Depending on definition, even POV-Ray is using BRDFs. Maybe I just don't
know what is your definition of "BRDF" when considering ray tracers.
(see below)
And that is the best way to do it. Like I said, sending rays to all
direction when the material is 100% mirror, is not so clever.
The problem here is I have no idea, how the user would assign an
_arbitary_ BRDF to a object. What does it look like and how would the
program generate a distribution function out of it. Should it be just a
bunch of weight/angle pairs and the renderer interpolates and renders
accordingly? Or something else?
And of course, I use BRDFs even now if end result is considered. They
just look a bit different and are "special cases", like 100% diffuse
material, 100% specular surface etc, transmissive surface following
Snell's law etc. Luxrenderer also "uses BRDFs" the way I do. So maybe
I'm using BRDFs after all :)
http://www.luxrender.net/index.php?option=com_content&view=article&id=49&Itemid=59
