POV-Ray : Newsgroups : povray.binaries.images : Ruined Place - WIP 3 Server Time
8 May 2026 19:32:35 EDT (-0400)
  Ruined Place - WIP 3 (Message 11 to 20 of 30)
Subject: Re: Ruined Place - WIP 3
Date: 15 Feb 2008 04:49:09
Message: <47b56015@news.povray.org>
"Jim Charter" <jrc### [at] msncom> schreef in bericht
news:47b5144d$1@news.povray.org...
> Looking better and better.  I think it mostly needs more variation between
> stones and areas.
Thanks Jim. I am still not really happy with this although there is
improvement. Yes, variation is needed and easy to do (implemented now to
some extend; see below).
> Not sure what you mean by 'crackle solid' pattern.  Are you using a none
> standard form?  What this actually reminds me of is the 'cells' pattern
> which might be something worth trying too.
To simulate the lichen I used a color_map with crackle solid. Here is the
macro code (state of the art) I used for the tiles. You only need to define
a parameter T (here: 0.4), a seed value for the parameter RR, and include
rand.inc. Note that I lowered the diffuse value of the lichen to 0.5. A
quick render shows this to be much better. The lichen now blends better with
the surrounding stone.
//-- Start Code --
#macro StoneTex()
#declare PLichen =
  crackle solid
  color_map {
    [0.45 rgbf <1.0, 1.0, 1.0, 1.0> ]
    [0.50 rgb <249, 224, 142>/255 ]
    [0.55 rgb <163, 149,  26>/255 ]
     [0.555 rgbf <1.0, 1.0, 1.0, 1.0> ]
    [0.60 rgb <215, 172,  67>/255 ]
    [0.65 rgb <124,  82,   0>/255 ]
     [0.655 rgbf <1.0, 1.0, 1.0, 1.0> ]
    [0.70 rgb <255, 217, 126>/255 ]
    [0.75 rgb <155, 111,  50>/255 ]
     [0.755 rgbf <1.0, 1.0, 1.0, 1.0> ]
    [0.80 rgb <176, 155,  98>/255 ]
    [0.85 rgb <126, 106,  53>/255 ]
     [0.855 rgbf <1.0, 1.0, 1.0, 1.0> ]
    [0.90 rgb <249, 224, 142>/255 ]
    [0.95 rgb <163, 149,  26>/255 ]
  scale  <1.0, 1.0, 1.0>*0.02
  warp {turbulence 0.1}
#local Amount = RRand(T-0.1, T+0.1, RR);
#declare TLichen =
    granite
    pigment_map {
      [Amount color rgbf <1.0, 1.0, 1.0, 1.0> ]
      [Amount PLichen]
    //scale  <1.0, 1.0, 2.0>*0.1
    //warp {turbulence <1.0, 1.0, 1.0>}
  normal {
    crackle 10.0 solid
    bump_size 2.0
    scale 0.01
  finish {
    ambient 0.0
    diffuse 0.5
#declare LichenLimestone =
material {
   // Limestone:
         agate
         agate_turb 1.0
         pigment_map {
            [0.0   color rgb <1.0, 1.0, 1.0>*0.3]
            [0.4   color rgb <0.6, 0.6, 0.6>*0.3]
            [0.8   color rgb <0.9, 0.9, 0.9>*0.3]
            [1.0   color rgb <0.7, 0.7, 0.7>*0.3]
         scale  <3.0, 0.3, 1.0>*0.05
         rotate    <-10.0, 0.0, 15.0>
      normal {
         crackle 10 solid
         warp {turbulence 0.5}
         scale 0.2
      finish {
         ambient 0.0
         brilliance 0.5
         specular 0.3525
         roughness 0.005
   // Lichen:
   texture {TLichen}
//-- End Code --
> Now you've gotten me googling antique ruins.  They really are powerful
> images.
Fascinating indeed. High potential for interesting scenes but also fairly
difficult to do correctly is my own feeling.
Date: 15 Feb 2008 05:17:43
Message: <47b566c7@news.povray.org>
Hmm, I'm not completely convinced by this. Actual ruins look more
like: http://www.risawn.com/blog2/greece/gr3_29.jpg
Date: 15 Feb 2008 07:31:54
Message: <47b5863a@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:47b566c7@news.povray.org...
Oh yes indeed! or this:
http://jfbradu.free.fr/GRECEANTIQUE/turquie/didymes/didymes1.htm for
instance.
However, I am not really trying to reproduce something photo realistic, but
to make an evocation of some ancient place. Tings should be properly
balanced one way or another and that needs some further tweaking.
Subject: Re: Ruined Place - WIP 3b
Date: 15 Feb 2008 07:35:07
Message: <47b586fb@news.povray.org>
A further balancing of texture parameters. Coarser stones, more random
lichen. Stone textures could be lighter though, although this depends on the
source material and even black pillars could be envisioned here.
Download 'IonianTempleRuins_2_05.png' (475 KB)
Preview of image 'IonianTempleRuins_2_05.png'
Date: 15 Feb 2008 08:02:29
Message: <47b58d65$1@news.povray.org>
Thomas de Groot wrote:
> well, the radiosity used is mainly default and it may enhance artifacts
> here. Maybe that is the reason.
hmm, I didn't notice it was used.  If it's the default, then it is
already very smooth and very slight, I don't think it's causing
artifacts.  Is ambient 0 for all objects other than sky?  The shadow
areas are too flat, there should be some occlusion effect along edges
and groves...
I really think the texture makes it all look too grainy.  Perhaps some
slight camera blur in the distance would make some of it go away?
Date: 15 Feb 2008 08:22:30
Message: <47b59216$1@news.povray.org>
you know, from those photos, I think the problem is partially that
povray doesn't support mip-mapping of textures and anisotropic
filtering.  I don't know how these could support procedural textures,
but they'd certainly help in making the graininess go away.
Only geometry near the camera would show the little pointy granite
grain.  Those far away would only permit the larger crackle pattern to
be visible.  Besides, the ground would show a smooth transition from
detail up close and be slightly blurred and less grainy in the distance.
I still think, though, that camera blur would be of some help here.
Date: 15 Feb 2008 08:40:22
Message: <47b59646$1@news.povray.org>
"nemesis" <nam### [at] nospamgmailcom> schreef in bericht
news:47b58d65$1@news.povray.org...
> hmm, I didn't notice it was used.  If it's the default, then it is already
> very smooth and very slight, I don't think it's causing artifacts.  Is
> ambient 0 for all objects other than sky?  The shadow areas are too flat,
> there should be some occlusion effect along edges and groves...
Ambient 0 for objects is standard in all my scenes.
Interestingly, what makes the graininess go away is to put the sun behind
the camera :-)  The more dramatic lighting effect is thereby lost somewhat
of course, but the stone shows off better. I shall upload an example as soon
as the render is done.
Date: 15 Feb 2008 08:45:06
Message: <47b59762$1@news.povray.org>
news:47b59216$1@news.povray.org...
> you know, from those photos, I think the problem is partially that povray
> doesn't support mip-mapping of textures and anisotropic filtering.  I
> don't know how these could support procedural textures, but they'd
> Only geometry near the camera would show the little pointy granite grain.
> Those far away would only permit the larger crackle pattern to be visible.
> Besides, the ground would show a smooth transition from detail up close
One thing about the photographs is also that those classic ruins we visit
may often have been "cleaned" of all offensive lichens and growths that
threaten their survival.
You might well be right about mip-mapping here... My knowledge about that is
slight however.
Date: 15 Feb 2008 08:57:44
Message: <47b59a58$1@news.povray.org>
> slight however.
it's just a technique for substituting less detailed textures for richer
textures the closer something is to the camera.  First time I saw it in
full glory was in the N64 game Goldeneye.  From the distance, walls
looked detailed enough, but once you came near them, *real* detail began
to smoothly blend in to the larger granite texture, like tiny crackles
and ridges... that was amazing for the time...
Date: 15 Feb 2008 09:42:51
Message: <47b5a4eb@news.povray.org>
Allright. Last example for the time being, showing the place under a
different lighting. Note that the graininess is much less.
Download 'IonianTempleRuins_2.png' (510 KB)
Preview of image 'IonianTempleRuins_2.png'
