POV-Ray : Newsgroups : povray.binaries.images : Man of the Ages (100k jpeg) Server Time
14 Apr 2026 17:59:10 EDT (-0400)
  Man of the Ages (100k jpeg) (Message 48 to 57 of 67)
Subject: Re: Man of the Ages (100k jpeg)
Date: 9 Jan 2009 21:45:58
Message: <49680be6@news.povray.org>
Bridgeofstraws wrote:
> stbenge, I tried your aberrate scene today and I can get the film grain to work
> but not the chromatic abberation.  I've tried using both the default settings
> and some random ones on my own.  Any advice as to what I might be missing would
> be greatly appreciated.  I really want to try abberatting some pictures because
> it will contribute a lot to my undetailed amateur images. =)  Thank you for the
> work you put into this!  If it matters, I'm using POV 3.6.1 on a windows
> machine.
Hello,
I tried it with 3.6 and it didn't work for me either. So I came up with
this workaround. Replace the last object with this:
sphere{<0,0,10>,12
  pigment{
   #if(Noise>0)
    crackle solid
    scale .001
    color_map{
     [0 rgb 0 transmit 1-Noise]
     [1/6 rgb y transmit 1-Noise]
     [2/6 rgb 0 transmit 1-Noise]
     [3/6 rgb x transmit 1-Noise]
     [4/6 rgb 0 transmit 1-Noise]
     [5/6 rgb z transmit 1-Noise]
    #else
    rgbt 1
  interior{
   ior 1.0
   dispersion Aberration
   dispersion_samples Aberration_Samples
Sam
Date: 9 Jan 2009 22:14:42
Message: <496812a2@news.povray.org>
I went ahead and uploaded a complete 3.6 version to p.t.scene-files.
Sam
Date: 9 Jan 2009 22:15:00
Message: <web.496811f988cac559c5ec9c90@news.povray.org>
Thank you very much!  Your work around makes the chromatic abberation work as
shown in your previous pics.
I went through your code and just a few minutes ago saw that it was the effects
plane that was causing the problems.  As a temporary fix I just changed the
plane to box{2,-2 ....[the rest of the code in the plane block]...} .  It seems
to work too, but because you understand your macro more in depth than I do at
the moment I shall use the code posted by you.  Thanks again.
Bridgeofstraws
Date: 10 Jan 2009 00:36:43
Message: <496833eb@news.povray.org>
> Hi,
Ah, good idea. It actually renders more slowly than the sphere, though.
If I had thought of using a box I would have released it that way.
Either way, the time saved using a sphere is negligible :)
Sam
Date: 10 Jan 2009 03:00:01
Message: <web.4968556788cac559f3c0a050@news.povray.org>
stbenge <^@hotmail.com> wrote:
> Carlo C. wrote:
> > Obviously the source had already examined very carefully. ;-)
> > Excuse me, I was referring to "little chromatic aberration and film grain
> > effect", which I find *very* attractive...
> Oops, I didn't realize what you were asking for. I just posted an
> updated copy of the code to povray.text.scene-files. It's actually quite
> a simple effect to create. It's not physically accurate, but should be
> enough to get you started :)
What's so special about this effect? I see this with *every* picture =B)
(takes off high-refractive-index-plastic glasses... =;)... wipes them, puts them
back on to see again... =B)...)
Date: 10 Jan 2009 03:16:46
Message: <4968596e$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> schreef in bericht
news:49677615$1@news.povray.org...
>  I mean that I shave off everyday, but not fully. :)
The fact that you *shave* is telling!  Shame on you. A real beard wearer
uses scissors, and then only parciminously... So, I am afraid that the Board
of Directors.....
Date: 10 Jan 2009 03:18:59
Message: <496859f3$1@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> schreef in bericht
news:7ivem450adh1d3hvta1d77g4s35pb6ghbs@4ax.com...
> What about the white hair club, Thomas?
They have been a little quiet these days, haven't they? Last I heard was
about some kind of dye....
Date: 10 Jan 2009 03:20:39
Message: <49685a57$1@news.povray.org>
"Rich" <ri.### [at] attnet> schreef in bericht
news:4967c0f0$1@news.povray.org...
> And let's not forget the no hair club.
So many clubs...
I am not a member (yet?) of that one, so I don't know...  :-)
[PS Could be an idea for a POV scene....]
Date: 10 Jan 2009 04:35:04
Message: <bsqgm4dgj2trmkvojng324tj89uc05922c@4ax.com>
On Sat, 10 Jan 2009 09:18:59 +0100, "Thomas de Groot"
If that is a hint then it doesn't work for me. My hair doesn't take dye very
well. Admittedly the last time I tried was 30 years ago and I noticed my first
silver thread when I was 13. So I learned to live with it. :)
Regards
Date: 10 Jan 2009 06:05:00
Message: <web.49687fbc88cac559d32df7340@news.povray.org>
> Sam
But it was not necessary to put into poetry!
Download '0y0x0z.jpg' (38 KB)
Preview of image '0y0x0z.jpg'
