stbenge <^@hotmail.com> wrote:
> It's actually quite
> a simple effect to create.
That's a pretty amazing image. Bad, but in a good way. ;-)
When I was a kid, I had a camera that took pictures like this (on a large-format
negative!) Rather horrible results--but it was one of my most cherished
possessions!
Ken W.
> "Thomas de Groot" <t.d### [at] inter nlDOTnet> wrote:
>> news:47b2dd5d@news.povray.org...
>>> I wonder whether there is any positive correlation between being a
>>> raytracing geek and being bearded (like with other pastimes/occupations
>>> like programming in general or astronomy)...
>> There seems to be! I have a full beard :-)
> Yeah, I have a mous... mos... a mustache and a little beard--both of which are
> starting to turn white. Egads!
Permanent two-day beards count as "being bearded"? ;)
Jaime
"Jaime Vives Piqueres" <jai### [at] ignorancia org> schreef in bericht
news:49675ca1@news.povray.org...
Well... I am afraid that *permanent* and *two-day* are a bit in conflict
here, so the Beards Club Board of Directors will spend a session discussing
this issue. You will be notified.
> Thomas
I mean that I shave off everyday, but not fully. :)
Jaime
On Fri, 9 Jan 2009 16:46:19 +0100, "Thomas de Groot"
What about the white hair club, Thomas?
Regards
And let's not forget the no hair club.
>> Oops, I didn't realize what you were asking for. I just posted an
>> updated copy of the code to povray.text.scene-files. It's actually quite
>> a simple effect to create. It's not physically accurate, but should be
>> enough to get you started :)
> Nice. Not half bad for a demo scene. Let's see... film grain, bokeh, chromatic
> aberration, lens flare, lightsys... I guess JPEG artifacts are easy enough to
> add. That still leaves purple fringing, blue channel noise, crud on the
> sensor. Collect that into a coherent system, and we'd have a pretty
> comprehensive camera model!
Well we could go the extra mile and put a fingertip near the edge :)
>> Carlo C. wrote:
> If stbenge did not exist, we should invent it. ;-)
> Thanks for the time you've spent.
> Thank you!
You're welcome :)
Sam
>> It's actually quite
The houses? It's rubbish :( It's actually a test scene for a
neighborhood of houses setup I was working on the other day. I idea was
to test cells and place the appropriate unit block according to the
surrounding cells. It works, but adding complexity seems to multiply
certain problems like roof shingles not meeting up right.
> possessions!
My webcam takes aberrated shots similar to this. I had originally
designed the code so that I could add fake elements to scenes and tie
them into real photos. I can still do that, but I doubt I would be able
to fool any of you :)
Sam
stbenge, I tried your aberrate scene today and I can get the film grain to work
but not the chromatic abberation. I've tried using both the default settings
and some random ones on my own. Any advice as to what I might be missing would
be greatly appreciated. I really want to try abberatting some pictures because
it will contribute a lot to my undetailed amateur images. =) Thank you for the
work you put into this! If it matters, I'm using POV 3.6.1 on a windows
machine.
Bridgeofstraws
