POV-Ray : Newsgroups : povray.binaries.images : Forest macro 2 Server Time
9 Nov 2026 14:00:26 EST (-0500)
  Forest macro 2 (Message 11 to 27 of 27)
<<< Previous 10 Messages Goto Initial 27 Messages
Subject: Re: Forest macro 2
Date: 11 Feb 2008 16:59:50
Message: <47b0c556$1@news.povray.org>
The final render is up on the TC-RTC
http://tc-rtc.co.uk/display/index.html
Under the title, "Systema Metropolis: In the Wild."
The code, including the tree macro, is posted to p.b.s-f.
Finally: Surprise!
How many of you saw *that* final scene coming? :-D
William Tracy
One time I put my car into reverse while traveling 70 mph on the
freeway. It was a very exciting learning experience.
     -- seen on Slashdot
Subject: Re: Forest macro 2 [800KB]
Date: 13 Feb 2008 12:14:39
Message: <47b3257f@news.povray.org>
I'm playing with this scene and huge resolutions :)
Of course, to render at super-high resolutions, tiled rendering is
needed (to distribute between computers/cores). But I can't split the
scene into tiles using the "normal method" (setting +w and +h to the
full res, and using +sc +ec +sr +er). I tried it with very high
resolutions (32768 x something) and POV-Ray crashed, or gave out of
memory error, apparently because it attempts to allocate memory for the
whole image. However, I successfully managed huge tiled renders with
zoomin.inc, where I can set +w and +h to the size of a single tile.
#include "zoomin.inc"
#macro Str(N) str(N,0,-1) #end
#declare Rows=4;
#declare Cols=4;
#macro ZoominParams(X,Y)
   concat(
     " +sr",Str(Y/Rows),
     " +er",Str((Y+1)/Rows),
     " +sc",Str(X/Cols),
     " +ec",Str((X+1)/Cols)
#declare Tile = frame_number;
#local X = mod(Tile, Cols);
#local Y = div(Tile, Cols);
Set_Zoom_Area(camera_location, camera_look_at, ZoominParams(X,Y))
Update_Camera_Zoom()
I rendered a 2048x1536 image, using 16 tiles, just for the sake of
testing. I can't really tell how much time it took, since I kept
changing some things while the tiles were being rendered, and then
re-rendered the ones that were left with old parameters.
Area lights and radiosity are disabled. I tested radiosity, and
confirmed it gets noticeable artifacts between one tile and the other.
All trees were loaded from linden-lowres5.inc, including bushes, to
decrease parse time to around 15 seconds.
I just noticed the PNG image is 5.3MB, even after optipng'ing it! JPEG
got it to 800KB while keeping more than acceptable quality. EDIT: and I
had to lower quality a bit more; I forgot how much overhead base64
causes, and the server gave a size limit error. Down to 700KB, retrying.
Download 'inthewild_big.jpg' (680 KB)
Preview of image 'inthewild_big.jpg'
Date: 13 Feb 2008 12:44:06
Message: <47b32c66$1@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2008/02/13 12:11:
When rendering at very large dimentions, add "+d" to suppress the prevew window.
This will save memory.
I believe that banking institutions are more dangerous to our liberties than
standing armies. Already they have raised up a monied aristocracy that has
set the government at defiance. The issuing power should be taken from the
banks and restored to the people to whom it properly belongs.
Thomas Jefferson
Date: 13 Feb 2008 12:47:53
Message: <47b32d49$1@news.povray.org>
> window. This will save memory.
With display enabled, I got an out of memory error. When using -d, I got
a crash.
zoomin will do :)
Date: 13 Feb 2008 15:05:50
Message: <47b34d9e$1@news.povray.org>
On the one hand, that is really cool.
On the other hand, all the little mistakes I'd hoped nobody would notice
are now magnified (several of the machines are levitating slightly ...).
Eek!
William Tracy
In Fig. 3.18 we define two local variables, four and twenty (no jokes
about blackbirds, please).
     -- Jeffrey D. Ullman, _Elements of ML Programming_
Date: 13 Feb 2008 15:19:18
Message: <47b350c6@news.povray.org>
> Eek!
Hey, most people would have faked the trees at the resolution you
originally used... (fake meaning they wouldn't be meshes with individual
leaves!)
Anyway, take it as an opportunity to do those little fixes :) It could
be even more res next time:
http://stuff.povaddict.com.ar.nyud.net/inthewild_tile52-100.png
tile <5,2> (on a 10x10 grid), all trees linden-lowres5, area lights on,
radiosity off
Date: 13 Feb 2008 17:25:43
Message: <47b36e67$1@news.povray.org>
> leaves!)
I was running out of modeling time, and had the choice of trying to fake
the trees with a texture on the ground, or using (mostly) pre-modeled
trees from Povtree. normal{bumps} wasn't cutting it at this resolution,
so I used Povtree trees.
What are the specs on the machine you're running this on? You've
inspired me to try a 2048x1536 RSOCP render; I'm finding that I have
more than enough memory to do it in one shot, but it is taxing my processor.
William Tracy
And the Format source code tells me that *really* the indicator of an
error is whether the index has changed value or not. If it has *not*
changed value, then some of the Format class' innards assume that since
parsing didn't happen, an error must have occurred. (Pause for
Buddhist-like contemplation of this leap of logic and faith.)
     -- Laird Nelson, blogging on the "dank recesses" of java.text
Date: 13 Feb 2008 17:38:58
Message: <47b37182$1@news.povray.org>
> processor.
AMD Athlon 64 X2 Dual Core 4200+, 2.20GHz
2GB RAM
Running Windows XP SP2 32-bit, so 32-bit POV-Ray as well
I did the 2048x1536 render with 16 tiles, manually making sure both
cores were always busy with one tile or the other :)
Date: 14 Feb 2008 00:07:55
Message: <47b3ccab$1@news.povray.org>
> Eek!
I'm now seeing trees that are mostly below the landscape surface.
Date: 14 Feb 2008 00:43:05
Message: <47b3d4e9@news.povray.org>
> radiosity off
http://stuff.povaddict.com.ar.nyud.net/inthewild_tile82-100.png
The rust texture looks pretty good even at that res...
Date: 14 Feb 2008 19:30:00
Message: <47b4dd08$1@news.povray.org>
Are they near the base of the machine at the far left or the one in the
foreground? If so, I already know. Otherwise, you found a new bug in my
tree macro. :-P
William Tracy
I saw a poster that read:
"Simpsons: The Movie: Rent it or own it."
I'm not sure, but I think it's a threat.
Date: 14 Feb 2008 20:46:13
Message: <47b4eee5$1@news.povray.org>
> tree macro. :-P
Well, I changed the random seeds, so I'm probably not seeing the same
landscape as you.
Date: 14 Feb 2008 20:57:38
Message: <47b4f192$1@news.povray.org>
> landscape as you.
The random seeds shouldn't affect that.
I was having trouble posing those particular machines, so I added some
blob shapes to make the ground effectively conform to their legs (rather
than posing the legs to conform to the ground). The tree placement macro
doesn't take those blobs into account, and any trees landing in those
places will intersect the blobs.
Do a quick render without any trees or bushes, and you'll clearly see
the extra objects. I hand-placed some bush clumps to hide the line where
they intersect the landscape mesh. ;-)
William Tracy
Who could pollute the entire world?
     -- Nausicaa
Date: 14 Feb 2008 22:35:53
Message: <47b50899@news.povray.org>
I'm now the proud owner of a 35MB PNG file. Did I go too far?
(5120x3840, 5 hours of CPU time, although real time is half that thanks
to dualcore)
Date: 15 Feb 2008 00:00:47
Message: <47b51c7f$1@news.povray.org>
> to dualcore)
Well, Zazzle posters go up to 5200x7800 resolution. ;-)
There are enough people involved in this image that I would need to dig
into licensing details before going ahead with a print.
Still, that would be cool.
William Tracy
    When you expect to live another two hundred years, you behave
differently from when you expect to live only twenty.
     -- Kim Stanley Robinson, _Red Mars_
Date: 15 Feb 2008 16:32:02
Message: <47b604d2@news.povray.org>
Your server seems to be struggling, so I've temporarily mirrored here
the two tiles that you shared:
http://users.csc.calpoly.edu/~wtracy/povray/inthewild_tile52-100.png
http://users.csc.calpoly.edu/~wtracy/povray/inthewild_tile82-100.png
William Tracy
    The point is not to make another Earth. Not another Alaska or Tibet,
not a Vermont nor a Venice, not even an Antarctica. The point is to make
something new and strange, something Martian.
     -- Kim Stanley Robinson, _Green Mars_
Date: 15 Feb 2008 16:51:30
Message: <47b60962$1@news.povray.org>
My "server" is my home machine with 128kbps upstream, running Apache. I
used CoralCDN as a caching proxy (by adding nyud.net to the image URLs)
to make the downloading speed a bit more sane...
