A view people ask me how I did this:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4798a383d450dfce811410630%40news.povray.org%3E/?mtop=259872
Well now I tried to code such a cube in PovRay.
Here it is:
//Take a coffee now!!
global_settings {assumed_gamma 3 radiosity {pretrace_start 1 pretrace_end
0.0000001 count 50 error_bound 0.05 recursion_limit 10 brightness 0.5}}
ultra_wide_angle
location <0.0, 0.1, -1.0>*1.5
direction 1.5*z
angle 90
look_at <0.0, 0.65, 0.0>
light_source {<-30, 30, -30> color rgb 1}
#declare resolution=60;
#declare densiti=0.125;
#declare chaos=2;
#declare bloks=union{
#declare zet=0;
#while (zet<resolution)
#declare hf=object{height_field {
function resolution,resolution {
agate
color_map {
[0 color rgb 0]
[1 color rgb 1]
turbulence chaos
scale 1
translate <0,0,1/resolution*zet>
scale resolution
#declare zet=zet+1;
#declare iks=0;
#while (iks<resolution)
#declare iks=iks+1;
#declare ueps=0;
#while (ueps<resolution)
#declare ueps=ueps+1;
#if (inside(hf,<iks,(resolution/(1/(1-(densiti)))),ueps>))
box{-0.4,0.4 translate<iks,zet,ueps>}
object{bloks
pigment{color rgb 1}
finish{ambient 0 diffuse 1}
scale 1/resolution
translate <-0.5,0,-0.5>
rotate <0,60,0>
sky_sphere {
gradient y
color_map {
[0.0 rgb <0.6,0.7,1.0>]
[0.5 rgb <0.0,0.1,0.8>]
[1 rgb 0]
plane {
y, 0
pigment { color rgb 1 }
Download 'block.jpg' (259 KB)
Preview of image 'block.jpg'
"H. Karsten" <h-karsten()web.de> wrote:
> pretrace_end 0.0000001 count 50 error_bound 0.05
oh, man!
Looks like a neat start for some really awesome spaceship greebling. :-D
William Tracy
afi### [at] gmailcom -- wtr### [at] calpolyedu
:D1ck :u like the site
:D1ck :what wil u give it out of 10
:Sp07 :.654564
-- script kiddies in an IRC chat
Interesting!
...and by playing with the size of the component blocks, one gets this for
instance. Very close to your original one.
by the way, I just used the default values for radiosity.
Download 'HKarsten_GreebleBlock.png' (136 KB)
Preview of image 'HKarsten_GreebleBlock.png'
Another interesting example. I randomized the individual block sizes and the
pigments; used marble instead of agate; densiti=0.25; chaos=0.5
Download 'HKarsten_GreebleBlock.jpg' (98 KB)
Preview of image 'HKarsten_GreebleBlock.jpg'
You can also play with the pattern.
Use wrinkles or leopard instead of agate.
On Tue, 5 Feb 2008 13:45:52 +0100, "Thomas de Groot" <t.d### [at] internlDOTnet>
>Thomas
I like that
Regards
> Thomas
the smaller preview image makes it look like an iceberg! :)
> > Thomas
And the bigger one for an instance like many sugar cubes. Hmmmm. :-)
Looks nice.
Regards
bluetree
Legos! :-D
William Tracy
"I don't hink it helps to make analagies between the physical and
social worlds," Sax said primly.
"Shut up, Sax. Go back to your virtual reality."
-- Kim Stanley Robinson, _Red Mars_
